Question about Canon imageCLASS D320 Digital Copier
Error code ...e805 what a problem - Canon imageCLASS D320 Digital Copier
Canon copier coping black and the another has a new catridge but coping dull .
What is the problem?
Posted on Dec 04, 2009
Canon 405 error code e805
http://www.copytechnet.com/forums/canon/9744-canon-gp-405-error-e805.html
Quoting:
  1. Canon GP 405 error E805
    E805 (The fan rotation is faulty.)
    If no detail code is indicated,
    suspect the feeder fan (FM1) or the
    reversing guide cooling fan (FM9).
    Is the connection of these fans
    normal? Is the drive signal of the fan
    identified in the previous step about
    22 VDC while the fan is rotating orabout 12 VDC otherwise?
  2. 05-14-2008 #3 songela Senior Tech 100+ Posts
    Join Date Mar 2008 Location dar es salaam
    That is one side with the fans,
    Secondly, if the fans are found right, then for sure you need to change the DC Controller.
    Regards!
  3. 08-02-2013 #4 mehta Junior Member Re: Canon GP 405 error E805
    Originally Posted by logimix
    Could somebody tells me... what this error (E805 - Canon GP 405) is... and how to resolve it? thanks a lot. john pl check detail code after 805 .Fan related fault. Also power supply(composite)
Apr 29, 2018 | Canon Office Equipment & Supplies
The canon Copier Brand iR2018 on the screen indicates a System Error E805, when machine is switched on.
Canon iR2018 Error Codes
This weblink states:
Code
E805-0000
Description
Fan failure
The fan is faulty.
Remedy
- Check the fan connector. - Replace the fan. - Replace the DC controller PCB.
Feb 16, 2018 | Canon Office Equipment & Supplies
Error e805 ir 400
my cannon ir400 xerox machine is on but no working power supply is full but not run machine
Dec 21, 2013 | Canon imageRUNNER 400S Copier
Canon gp 335 erorr code e805 what is the problem
Canon GP 405 error E805 E805 (The fan rotation is faulty.)
suspect is feeder fan (FM1) or reversing guide cooling fan (FM9).
try Check
Mar 25, 2012 | Office Equipment & Supplies
Canon ir400 E0805-0014
Hi
this is not the same sub code but it's a start.
getfile.asp?rid=1258 September 27, 2002 getfile.asp?rid=3215 Product : imageRUNNER 330 / 400 Title : E805-0002 Error Code Error :
E805 with a 0002 Sub Code
Workaround :
This may be caused by a pinched wire that goes to connector J108 B-18 on the DC Controller. The wire was pinched to the frame near the riser to the DADF-A1 exit side hinge. Inspect the harness indicated by the arrow in the picture. getfile.asp?rid=4772 Canon USA, Inc. Systems & Technical Support Division
Dec 28, 2010 | Canon imageRUNNER 5570 Copier
System Error E805 in Canon iR2018
E805 is Fan failure
The fan is faulty. - Check the fan connector.
- Replace the fan.
Jan 08, 2010 | Office Equipment & Supplies
I have a Canon laser class 700 and it has a E805 error message. Can anyone help me?
E805 error code refers to a fan failure. Either the fan is locked up or unplugged.
Sep 02, 2009 | Canon Office Equipment & Supplies
Add'l question on errror e805
Hello sir; There have whole bunch fans , I don't know which fan you talking about, the error code e805 have sub code press print findout the sub code.
Aug 27, 2009 | Canon imageRUNNER 400S Copier
Error code e805
The fan wiring is faulty (short circuit, open circuit). The heat dischargefan is fautly.
check wiring of heatdischarge fan
The machine is equipped with a single fan for discharge of heat from inside it.
Mar 04, 2009 | Canon imageRUNNER 2000 Copier
E805
J'ai un problème e805 photocopie canon gp 405
Quelle est la solution de détails, s'il vous plaît
Aug 24, 2008 | Canon imageRUNNER 400S Copier
Canon imageCLASS D320 Digital Copier Logo
183 people viewed this question
old marine
old marine
