WE are a very small non-profit and can't afford a tech to come in and fix it right now. I purchased a used Cannon NP 6030 and I made one copy fine. Then the error message ''E010 Turn copier off and then on''. After several attemps, I made sure there isn't a jam in it, I opened every door and paper drawer there is to verify this, and have turned it on and off several times and even unplugged it a couple of times. PLEASE can anyone help me? Up a creek without a paddle :>) Thanks so much!
  • 1,959 Answers
There are several things to try for the E10 error. E10 indicates " main motor lock, main motor rotation sensor,main board". It's a general fault which can be caused by
  • Dirty Corona wire
  • Dirty Drum
  • Dirty Optics on mirrors/glass
These would be the first things to try. After that, you're looking at a bad main board. Hope you find this answer to solve your problem.
Posted on Nov 16, 2009
Testimonial: "Thank you! Yes the unit is extremely dusty inside and now I am having jams that I was aware were a problem but ithink I have a fix for that. Thank you"
My canon np 6030 copier is printing faint copies what could be the problemmy canon np 6030 copier is printing faint copies what could be the problem
clean the optical system i.e.first mirror,second mirror,reflector,lens etc to get dark copies.
checklife of photoconductor drum if it is over replace the drum.
Jul 26, 2011 | Canon Office Equipment & Supplies
I have a cannon 6030 copier in my office that is not serviced anymore. I recently changed the toner, following all the directions from the manual. Now It only copies blank pages. It has no other error...
manually jam the paper & see if there is any images on your drum. if no image is there, problem will be in your primary charging. Corona wire may be broken repair it.
if there is image on your drum check if your transfer is ok. replace your transfer corona wire
Apr 14, 2011 | Canon NP 6035 Copier
I want to download technical support manual for canon np 6030 what should i do?
you can do a search online to see if there is someplace that sells the service manual for the NP6030 and purchase it from them. other than that i don't know of any other way to get a copy of it of if there is even a pdf file for the service manual for that machine. It is a analog copier and has been out of service for a long time
Jun 18, 2010 | Canon NP 6035 Copier
What is a fixing web on a cannon 6551 Black and white copier
The Fixing Web is a roll of oil impregnated fabic that sits on top of the upper fixing roller. Its purpose is clean the fixing rollers between copies. It lasts somewhere around 250,000 copies. Needs to replaced by a service tech and have the counter reset. If the Web runs out you get a E-005 error code.
When you open the front door and release handle and pull out the Paper Transport fixing assembly. The Web is under the yellow cover on the left side.
Mar 19, 2010 | Canon NP 6551 Black and White Copier
Copies fine on bottom, but fade to nothing at top
Could be one of many things. Possible new transfer roller - make sure the transfer roller is not jammed.
Check the developer roller (at exit from toner hopper), to see if it is rotating properly. Check all connections to/from drum and transfer rollers.
This is most likely a dev unit problem. Not sure if dev/hopper and transfer are all in one unit - if so, replace the lot, or you'll be chasing one problem after the other.
Apr 10, 2009 | Canon Office Equipment & Supplies
Error U3 on a Sharp AR-5132 Copier
The problem is on the mirror section on the scanner unit. It might be the motor, sensor, scanner wire or just need lubricating. I think you better call your local tech.
Apr 07, 2009 | Sharp AR-5316 Advanced Digital Imager...
Cannon NP 6551 (Danka A50) Touch Screen Lost Brightness
SOMEONE TURNED THE CONTRAST BUTTON ON YOUR DISPLAY, YOU JUST NEED TO READJUST BY PRESSING AND TURNING TO DESIRED CONTRAST
Apr 03, 2009 | Canon NP 6551 Black and White Copier
Canon COpier NOP 6030 error code E064
hi.... sir
i've an erorr code for copier np 6030 is 064 how to solve it
Oct 28, 2008 | Canon Office Equipment & Supplies
Minolta copier SN 312039
Basicly, a Cob71 deals with the toner bottle. Have you replaced it resently? try to take it out again and let the copier warm up to ready and reinstall the toner bottle back in. See what happens... Also, it helps if we know what mode it is for more info.
Jun 10, 2008 | Minolta Office Equipment & Supplies
k24674
jasbo
jasbo
