Question about Logitech Z-2300 Computer Speakers
What type of audio connection is on this system?
  • 3 Answers
3.5mm jack headphone
Posted on Dec 06, 2009
I have a Panasonic Model TC-p42X1 TV hooked up to a Panasonic SC-PT480 Home Theater system by an HDMI cable from HDMI 1 on TV to HDMI on Theater unit. System setup test okay for speaker sound connections...
It's possible that you have the wrong type of HDMI cable. You need one that has Audio Return if you want to feed your Home Theater system with audio from the TV. There are several types of HDMI cable,some with audio return and some without. The two basic types (not including Ethernet) are described below - you need the High Speed version, which does have Audio Return.
hdmi-standard.jpgHDMI Standard This is the most basic HDMI standard which all cables have to meet. Cable should contain all the connections required for HD transmission, and have to deliver at least a resolution of 720p, (Video mode of 1280 x 720 meaning 720 Horizontal lines). These cables do not contain an Ethernet connection, or audio return.
hdmi-high-speed.jpgHDMI High Speed HDMI High Speed cables will support higher resolutions of 1080p. This means at least 1080 Horizontal lines, and cables rated at this specification may well support high resolutions of up to 4096 x 2160 (2160 Horizontal lines), check individual cables specifications for this data. Cables in this specification will also support a data transfer speed of 10.2Gbs (not to be confused with ethernet data speeds which are different), and a clock speed of 320Mhz. These cables do not contain an Ethernet connection, but do include an Audio Return Channel.
Feb 03, 2011 | Panasonic SCPT480 Theater System
Dynex dx-32l151a11 the picture is black and white with the dvd player
With a Black and White picture it sounds like you're trying to connect the DVD Player's "Composite" connection to the TV's Component Connection.
Composite is a 3 wire system with Yellow for the video, and red and white for the audio. On your TV this connection is located on the side.
Component is a 5 wire system, with Blue, Green & Red for Video, and Red and White for audio. On your TV this connection type is located on the rear panel.
Check to make sure you are hooking the DVD player & the TV to the same input types.
Dec 26, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
I can't get the TV sound to play on the HT speakers
Ensure that you have an audio connection to your LG theater system from the TV, that is labeled as "audio out" or similar to "variable out" to an audio input on the LG system. You may use a pair of RCA type cables or sometimes known as composite audio cables. Then on the LG system, select the input to use that you connected your audio cables from the TV into. Disable the TV speakers. Decrease volume on the LG system, then increase the volume on the TV all the way up. You now can use the LG system as the master volume for TV.
Nov 12, 2010 | LG LHT854 Theater System
How do I connect my Logitech music system to the TV. What connection and plugs is required? Kindly advise.
If your music system is only audio,then you need two RCA type audio cables pair for left& right audio channels(male pin jacks).Connect them at Music system audio output with left & right channels accordingly while on yr TV,connect the other ends to the audio Input jacks(female type). If there is a video out also from your music system then add the yellow video cable as well in the same way.
Aug 23, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
I have hooked up the audio to my tv from the audio out and connected it to the dvd player audio in and cannot get sound out through the external speakers. I have connected all the speakers correctly. ...
It goes Audio Out of DVD to Audio IN of TV or Amp. The audio out of a TV must go into an amplifier, not just a player. A player does not have an amp built in. Not the add on type that you have.
Aug 19, 2010 | RCA RTD3133 Theater System
How to connect my audio system directly to sony bravia
There is usually three ways to connect a TV to a Surround Sound system:
1. Optical Audio Cable (Fiber Optic)
2. Coaxial Audio Cable (Orange)
3. Composite Audio Cables (Left - White, Right - Red)
Once you select a cable to use that is compatible with both devices, you must then connect it to the output on the TV set, and one of the inputs on the Surround Sound Receiver (preferably the Video Input or whatever type you selected to use). Then you must change the input on the Receiver to the proper input that you connected the cable to (most Receivers will have a Source Button if not individual source buttons i.e. Tuner, Tape, CD, Video, Aux, etc.).
Note: Some Receivers if using a certain type of input will not have sound out of all 5 speakers unless the input is 5.1 compatible.
Jul 02, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Any possibility of integrating an ipod into an x type 2004 audio system?
I’ve been looking for some time at installing an auxiliary audio input device to compliment the x-type audio system and a generic mp3 player.
From my searches it looks like the x-type has an unusual laser driven stereo system making aux-in a difficult topic. Also, I'm not a fan of the mp3 to radio transmitters where you tune in your radio to the same frequency as the device - these seem to suffer from poor signal and interference issues.
I chose to install a separate amplifier that is located between the stereo and the speakers. The device I chose is named “io_connect” ~£40. http://www.nexxia.co.uk/Car_Audio/iO_Play.htm in addition I bought a SOT lead suitable for this application from ebay ~£10 and a mobile phone cradle and charger ~£8. Here’s what I think is good about this method:-
Jaguar stereo remains untouched
Easy installation
Clear mp3 & SatNav playback
SatNav plays over speakers with music continuing also.
Can upgrade for Bluetooth connectivity
Tidy finish.
Jun 12, 2010 | 2004 Jaguar X-Type
Why can't we get the sound to work by hooking the DVD player directly to the tv?
The JVC system is designed to output audio only via the speaker terminals at the rear of the system. There is NO provision to send audio directly to the TV from the system.
Page 14 of the manual (link provided below - free to download) details the connections available to a TV. These connections are limited to three types of connections: 1) "Video" for standard TVs which is "good" 2) "S-Video" for TVs that have an S-Video input jack which is "better" (both #1 and #2 are considered "composite" types).
The third type is called "Component" which is used for TV's that are capable of "progressive scan" video input which is "best" for the system. Notice that the jacks on the DVD player are labeled "Y", "Pb" and "Pr", not "Video", "Left" and "Right". This type video signal requires the use of three cables - they do not send audio as you may be used to see on all but the newer TVs. TVs capable of displaying "progressive scan" video have a better looking picture when using these jacks. Incorrectly connecting the video from the DVD to the TV audio inputs (Left & Right) will likely result in noise or hiss from the TV speaker.
To recap - audio can only be played through the JVC system's speakers. Use the highest quality video jacks that BOTH your TV and the DVD player supports.
I hope this was Very Helpful and enjoy your DVD and TV!
http://www.retrevo.com/support/JVC-TH-M505C-Home-Theater-Systems-manual/id/318bh527/t/2/
Dec 21, 2009 | JVC TH-M505 System
Does this system have a optical input
Here are the list of connections on this system
• Audio inputs/outputs 2 analogue input sources,
1 analogue output connection
- TV : in
- VCR : in
- CDR : out
- Headphone : 3.5 mm
• Digital audio in/output : 2 digital output connection
(coax, optical)
• Video outputs : 3 output connections (1 S-Video)
- TV : out
- VCR : out
- Monitor : out
• Speaker Connections suitable for speakers ≥ 6 Ohm
- left, right, center : click-fit connection
- rear left, right : click-fit connection
• Miscellaneous connections
- TV center speakers pre-out : 1
- Subwoofer pre-out : 1
- AM antenna : loop type
- FM antenna : coax
please mark this fixya if it has answered your question.
Dec 14, 2009 | Philips LX3000D System
Compatibility fo TV and Sound system
TV has audio outputs, the RCA cable type. If you connect the audio output (red,white) from the TV(look on the back), and connect the RCA cable to Input of home theater system,you should get TV sound from home theater system. You may have to set the audio on the TV for external source. Go to menu, to audio setup, to options. On the Home Theater system, you may have to select the audio source, i.e. audio input 1, etc.
Aug 09, 2009 | Samsung Theater System
Logitech Z-2300 Computer Speakers Logo
82 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
