RCA dta800 converter remote code for magnavox tv
I need code for the remote to work on magnavox tv
freetek
  • 5568 Answers
SOURCE: need tv codes for rca dta800 for maganvox tv
Your Magnavox could have been built by either Philips or Funai who now owns the name rights to both in the US.
Try any codes you might have for either of those names.
In addition:
I wish someone would bring a suit against any of these manufacturers using the term 'universal.'
At best, they are 'multibrand' and, with the proliferation of 'brands,' there never will be one that can rightfully claim to be 'universal.'
There may never be a code for your brand available in every remote.
Posted on Feb 08, 2009
ltfrc
  • 227 Answers
SOURCE: codes for magnavox tv for rca converter box
005 007 045 049 050 054 055 064 097 098 099 153 154 160 170 174 177 181 210 230 234 252 258 259 272 274 283
Hope one of these works for you.
Posted on Feb 22, 2009
ramon49
  • 111 Answers
SOURCE: Magnavox universal remote isn't working.
RCA:060,0035,0149,0226,0807,0880,1035,1060
Try these.
Please rate...
Posted on Mar 13, 2009
  • 30 Answers
SOURCE: have rca remote systemlink3 need codes for magnavox tv
http://www.universal-remote.net/philipsmagnavox.html
Posted on Sep 13, 2009
  • 1218 Answers
SOURCE: Programming RCA converter box remote control with Phil/Mag TV---
Good day,
You should have the instruction guide. If not look below. It's there but look closely for the guide itself and how to increase it's size to readable.
Check on the back of the TV to see if there is a 3 and 4 setting, If so, set to 3.
With nothing connected to the tv, and using the tv's remote, scan for channels. It should come up with only channel 3.
Then using the remote with advanced options, set the the input to either antenna or auto.
Connect the antenna cable to input on the converter box. Using the supplied cable connect the output from the converter box to
the TV. Turn the TV on first, followed by the converter box.
Then follow the instructions.
Not really easy so you'll have to fight your way thru it.
Finding the right setting for the antenna will probably take the most time, requiring a station scan after each adjustment.
http://dtvconverterboxes.blogspot.com/2009/05/rca-dta800b1-owners-manual.html
Posted on Dec 28, 2009
Code to program my JVC tv to the DTA800 Digital box
Hi debbie,
I see yiu need a code for your JVC TV to program ti the DTA800.
You can try The codes for JVC TV to program universal remote are 159, 013, 012, 182, 054, 060, 065, 066, 067, 123, 157, and 158. You can check these codes one by one.
I hope this helps.
mvincentc
May 28, 2011 | RCA (DTA800B1) Video Converter
RCA DTA800 TV Converter Box I need TV codes for the remote to work. The TVs are a GE, phillips magnabox
Good day,
I might be missing something, but you are describing a converter box that converts digital signals from an antenna to analog.
The converter box will be set to channel 3, and you should set your tv's to channel 3 as well.
Using the remotes that came with the tv's go into setup and if available as an option, you will find an option to select cable/antenna or automatic. Select automatic or antenna and save. If there is a selector switch on the back of the tv's, set to 3.
Connect antenna cable into input, and use supplied cable to connect from the output of the converter to your tv.
plug in power supply for converter box, tune tv to channel 3 then follow instructions to setup converter box including channel scan.
When done, the converter remote will control everything. However, the tv volume control will work even though the converter remote will have volume as well. The tv remote as well is needed to shut off or turn on tv. These functions can on most tv's be performed on the set as well.
No codes are required. The converter remote will work on any tv.
If you want to use both tv's then you will need a splitter on the output of the converter to send the signal to both tv's. Only one channel can be viewed at a time.
Viewing separate Chanel's requires a second converter box and a splitter connected to the antenna cable for viewing separate channels.
More options are possible, but I hope this helps you get started.
The converter box takes place of the tv's tuner and in essence disables it.
Nov 05, 2009 | Tablets & eReaders
Need Program Code!!!
the code is just 0000. It worked for me.
Apr 17, 2009 | Apex Digital AT1308 13" TV
Lost code for rca DTA800B1 digital converter box
I have an RCA DTA800 converter box but I need the codes for my Magnavox...need help
Feb 19, 2009 | Jensen JER-422 Universal Remote Control
Need tv codes for rca dta800 for maganvox tv
In addition:
Feb 08, 2009 | RCA 3-Device Universal Remote
I have a ILO TV and need the codes for a RCA DTA800 converter
Already found solution with codes from Orian that worked.
Thanks
Jan 04, 2009 | Hitachi 57F510 57" Rear Projection...
Haier / Celera TV & RCA Converter Box remote code
hi guys,
pgm-->tv code-->ok-->you are done
try this link for codes.
http://www.1800customersupport.com/productdocuments/DTA800_code.pdf
hope you got it.
Satya.
Jul 18, 2008 | Televison & Video
Need a progam code for rca dta800
I just tried their web site and it worked! They have the codes. www.1800customersupport.com/rca
or here is the direct link: http://www.1800customersupport.com/productdocuments/DTA800B1_Program_Codes.pdf
Hope this helps others who have had the same problem. Mine did not even come with these codes!!!
Jul 07, 2008 | Hitachi 57F510 57" Rear Projection...
Remote control programming codes
i have a GE t.v. and just bought the RCA DTA800 converter box. none of the codes that were in the manual worked for my t.v. can anyone help?
Jun 19, 2008 | Televison & Video
Televison & Video Logo
81 people viewed this question
Top Televison & Video Experts
Electro Med Services...
