Question about Symbol (LS3070-I100US) Handheld
I have a Symbol LS3070 that has stopped sending a return after UPC-A scans. I added a suffix of 7013, and got no change. Any Ideas?
  • soundsfine Nov 20, 2009
    Thanks, That was what was missing.
  • Symbscanners May 11, 2010
    You must scan the barcodes Scan Options, Data Suffix, Enter to add the suffix. Have you tried scanning that?
    Scholar:
  • 74 Answers
Scanning Scan Options, Data Suffix, Enter from Adobe pages 141 and 142 of 214 the LS3070 Product Reference Guide resolves this issue. The suffix is already set to 7013 so scanning the barcodes above should be all you should have to do to send the return or enter key after every barcode scanned..
Posted on Nov 20, 2009
After scanning a bar code I need it to enter and go to next row in excel
This can be possible, therefore it is not an Excel setting. You would need
to use the software that comes with your bar-code reader to configure this.
Try looking in your bar-code reader documentation for "Append Enter" or
"Append Carriage Return"
May 21, 2011 | Symbol LS 4000i Handheld
I'm using Symbol LS1004 with SirsiDynix Symphony 3.3.1 Workflows. How can I tab over after each scan, without having to hit <Enter>? Thanks, -john
Here is what I did to fix the problem of the bar-code scanner not going to next line after a successful scan. (Symbol ls4000i,This fix should work for other models as well)
1. Get the manual for your scanner or here is a link to the Symbol LS400i
https://docs.symbol.com/manuals/3789802a.pdf
You will want to print off few pages that have the proper bar-codes for programming.
2. I usually start with setting scanner to the Default Parameter, this should be in section 5-7,page 50 of the manual.PRINT IT
Warning! If you set scanner to default, you need to be aware of which bar-code types you use. (We use UPC-A) Also if you have it programed for other things already you may not want to set all settings to default. You can skip to step 4. If you do not wish to reset all values to default.
Now scan the Default bar-code.
3. Now program scanner to Enable your bar-code type. (For us Enable UPC-A bar-code is in section 5-22,page 66. PRINT IT
Now Scan the Enable (your bar-code type UPC-A, UPC-E,etc etc)
4.Next You need to set a Suffix Value. The scan Suffix bar-code is found in section 5-80, page 124. PRINT IT
Now Scan the Scan Suffix bar-code
This prepares the scanner for the code of the whatever Suffix you want to add.
5. The Suffix you want to add to fix this particular problem is ENTER. So that it goes to the next line. There is a prefix/suffix value chart on page 162 table A-4. The code for ENTER Is 7013. In order to enter this code you will need to print off the Numeric Bar Codes found in section 5-109,5-110,pages 153,154. PRINT IT
Now scan in 7013 one number at a time to program ENTER as the suffix.
6.Now you have to program the Scan Data Transmission Format found in section 5-81,5-82, pages 125,126 . PRINT IT
(This lets the scanner know to transmit the Suffix after the data.)
First scan the Scan Options Bar-code.
Second scan the <DATA><SUFFIX> bar-code.
Last scan the ENTER Bar-Code.
YOUR DONE !
Your scanner should be working now. Also look through the manual there are some nice functions that can be turned on and off with a simple bar code scan. Such as volume and tone of beep etc etc.
Hope this helps
Nate N7w7
Apr 06, 2011 | Symbol Spark LS 1004
How do i program the LS2208 not to send the EAN-13 check digit and send ENTER key / carriage return
LS2208 needs a ADF Rule added to it to send the "Enter" on the end of all code. Scan123 is also an easy solution. Download it if you don't have it. Basically in Scan123 select the type of scanner you are working with, then select the ADF Rules tab. Make a new rule that says ANY Code, Any Length, and then under actions I put Line 1 "Send all that remains" Line 2 "Send Numeric Key <Enter>. Save the rule. Then select the Symbologies Tab, Select UPC/EAN Tab and select what options you want. Then select the Print Icon, Tick Symbologies , ADF Rules & Programming BarCodes boxes. Print them out and then scan them into your scanner. Job done
Feb 15, 2011 | Symbol LS2208 Handheld
LS3070 (ls3070-i000a) Handheld: My scanner stopped scanning. It beeps four times. ...
The four times beep means that there is an problem in the connection to the PC, please check the cables and configuration.
May 18, 2010 | Symbol LS3070 (ls3070-i000a) Handheld
How can I enable to PDT 8100 to scan data with carriage return fuction after scanning?
Goto scanwedge....config....Setup...
check box "send ENTER key after suffix"
Mar 21, 2010 | Symbol PDT 8100
Hi, i am trying to configure my barcode scanner LS2208 to put a {TAB} in when scanning
There should have been a sheet or book of bar codes that came with your scanner. These codes will allow you to program your scanner to do most anything, including adding a tab. You simply look at the bar codes and read what they do. you simply scan the one that adds a tab and it will forever add the tab unless you re program it.
If you have lost your book/bar code page, you should be able to go to the manufacturer website and download/print a document with the programmable bar codes.
Feb 26, 2010 | Symbol LS2208 Handheld
Problems with M2004 Barcode Scanner
If your M2004 is connected with an RS-232 cable such as the CBA-R01-S07ZAR or the 25-32465-20R the scanner defaults to sending data at 9600 baud, 8 data bits, 1 stop bit, no parity, software or hardware handshaking. Is it possible the software needs to see a carriage return after the data? If so, Scan Options, Data Suffix, Enter from Adobe page 135 and 136 of 310 of the M2000 Series Product Reference Guide will make the scanner send a carriage return line feed (7013). If your program needs just a CR then scan the Scan Suffix barcode from page 134 of 310 followed by a 1, a 0, a 1 and a 3 from page 175 of 310.
If this does not help or if you are connected any other way and the CRLF does not help it may be a good idea to contact the Motorola support center for assistance. Their phone number is 800-653-5350.
Oct 22, 2009 | Cyclone Symbol M2004 Omni-Directional...
Need carriage return sent after data
Download the product reference guide forr this scanner from www.symbol.com
Find the following barcodes, print them annd then scan then in this order:
scan options.
data > suffix
Enter.
This should resolve your problem.
Jun 12, 2009 | Symbol LS2208 Handheld
Symbol ls3070
You can download the manual here :
http://www.gsv-service.com/download/ls3070.pdf
You're welcome, but don't just sit there clapping, throw money at me :)
Jan 21, 2008 | Symbol (LS3070-I100US) Handheld
Symbol (LS3070-I100US) Handheld Logo
421 people viewed this question
Top Symbol Computers & Internet Experts
Michael
Oloyede Monsuru
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
