Question about Nokia 6300 Cellular Phone
Screen has lines coming when i make phone calls
The screen has lines passing through horizontal lines every time i make phone calls or use the wap service please help
    Problem Solver:
Its your battery.. make it full charge..
Posted on Jan 13, 2008
SAMSUNG SCH MICF399 SOLUTION
Setting answer options - Samsung Convoy (SCH-u640)
  1. From the main screen, press OK to choose MENU.
  2. Select Settings & Tools then press OK.
  3. Select Call Settings then press OK.
  4. Select Answer Options then press OK.
  5. Select the desired option, press OK to choose MARK then press the left soft key to choose Done. Flip Open Answer calls when the phone is opened.
    linote.gif Speakerphone is automatically activated. Any Key Answer calls by pressing any key. Auto w / Handsfree Automatically answer calls with a handsfree device On the main screen type *#06#
    Information you get from the IMEI (International Mobile Equipment Identity)
    XXXXXX XX XXXXXX X
    TAC FAC SNR SP
    TAC = Type approval code of your samsung Mobile
    FAC = Final assembly code of your cellphone
    SNR = Serial number of your samsung Phone
    SP = Spare
*#06# IMEI code
*#9998*4357# Help Menu
*#9998*5282# Java menu (GRPS/CSD settings for JAVA server)
*#9999#0# Monitor Mode
*#9999# or *#9998*9999# Software Version
*#8888# or *#9998*8888# Hardware Version
*#9998*746# or *#9998*0746# or *#0746# Sim Infos
*#9998*523# or *#9998*0523# or *#0523# Display Contrast
*#9998*842# or *#9998*0842# or *#0842# Vibration On (until you push OK)
*#9998*289# or *#9998*0289# or *#0289# Buzzer On (until you push OK)
*#9998*288# or *#9998*0288# or *#0288# Battery & Field Infos
*#9998*377# or *#9998*0377# Error log
*#9998*778# or *#9998*0778# or *#0778# Sim Service table
*#9998*782# show date and alarm clock
*#8999*638# show network information
*#9998*5646# change operator logo at startup
*#9998*76# production number
*#9998*968# view melody for alarm
*#9998*585# Non-Volatile Memory (NVM)
*#3243948# Digital Audio Interference Off
*#32436837# Digital Audio Interference On
*#1111# S/W Version
*#1234# Firmware Version
*#2222# H/W Version
*#8999*8376263# All Versions Together
*#8999*8378# Test Menu
*#4777*8665# GPSR Tool
*#8999*523# LCD Brightness
*#8999*377# Error LOG Menu
*#8999*327# EEP Menu
*#8999*667# Debug Mode
*#92782# PhoneModel (Wap)
#*5737425# JAVA Mode
*#2255# Call List
*#232337# Bluetooth MAC Adress
*#5282837# Java Version
Type in *#0000# on a Samsung A300 to reset the language
Master reset(unlock) #*7337# (for the new samsungs E700 x600 but not E710)
Samsung E700 type *#2255# to show secret call log (not tested)
Samsung A300, A800 phone unlock enter this *2767*637#
Samsung V200, S100, S300 phone unlock : *2767*782257378#
#*22671# AMR REC START
#*22672# Stop AMR REC (File name: /a/multimedia/sounds/voice list/ENGMODE.amr)
#*22673# Pause REC
#*22674# Resume REC
#*22675# AMR Playback
#*22676# AMR Stop Play
#*22677# Pause Play
#*22678# Resume Play
#*77261# PCM Rec Req
#*77262# Stop PCM Rec
#*77263# PCM Playback
#*77264# PCM Stop Play
#*22679# AMR Get Time
*#8999*364# Watchdog ON/OFF
*#8999*427# WATCHDOG signal route setup
*2767*3855# = Full Reset (Caution every stored data will be deleted.)
*2767*2878# = Custom Reset
*2767*927# = Wap Reset
*2767*226372# = Camera Reset (deletes photos)
*2767*688# Reset Mobile TV
#7263867# = RAM Dump (On or Off)
#*4773# Incremental Redundancy
#*7785# Reset wakeup & RTK timer cariables/variables
#*7200# Tone Generator Mute
#*3888# BLUETOOTH Test mode
#*7828# Task screen
#*#8377466# S/W Version & H/W Version
#*2562# Restarts Phone
#*2565# No Blocking? General Defense.
#*3353# General Defense, Code Erased.
#*3837# Phone Hangs on White screen.
#*3849# Restarts Phone
#*7337# Restarts Phone (Resets Wap Settings)
#*2886# AutoAnswer ON/OFF
#*7288# GPRS Detached/Attached
#*7287# GPRS Attached
#*7666# White Screen
#*7693# Sleep Deactivate/Activate
#*2286# Databattery
#*2527# GPRS switching set to (Class 4, 8, 9, 10)
#*2679# Copycat feature Activa/Deactivate
#*3940# External looptest 9600 bps
#*4263# Handsfree mode Activate/Deactivate
#*2558# Time ON
#*3941# External looptest 115200 bps
#*5176# L1 Sleep
#*7462# SIM Phase
#*7983# Voltage/Freq
#*7986# Voltage
#*8466# Old Time
#*2255# Call Failed
#*5376# DELETE ALL SMS!!!!
#*6837# Official Software Version: (0003000016000702)
#*2337# Permanent Registration Beep
#*2474# Charging Duration
#*2834# Audio Path (Handsfree)
#*3270# DCS Support Activate/Deactivate
#*3282# Data Activate/Deactivate
#*3476# EGSM Activate/Deactivate
#*3676# FORMAT FLASH VOLUME!!!
#*4760# GSM Activate/Deactivate
#*4864# White Screen
#*7326# Accessory
#*7683# Sleep variable
#*3797# Blinks 3D030300 in RED
#*7372# Resetting the time to DPB variables
#*3273# EGPRS multislot (Class 4, 8, 9, 10)
#*7722# RLC bitmap compression Activate/Deactivate
#*2351# Blinks 1347E201 in RED
#*2775# Switch to 2 inner speaker
#*7878# FirstStartup (0=NO, 1=YES)
#*3838# Blinks 3D030300 in RED
#*2077# GPRS Switch
#*2027# GPRS Switch
#*0227# GPRS Switch
#*0277# GPRS Switch
*#7465625# = Check the phone lock status
*7465625*638*Code# = Enables Network lock
#7465625*638*Code# = Disables Network lock
*7465625*782*Code# = Enables Subset lock
#7465625*782*Code# = Disables Subset lock
*7465625*77*Code# = Enables SP lock
#7465625*77*Code# = Disables SP lock
*7465625*27*Code# = Enables CP lock
#7465625*27*Code# = Disables CP lock
*7465625*746*Code# = Enables SIM lock
#7465625*746*Code# = Disables SIM lock
*7465625*228# = Activa lock ON
#7465625*228# = Activa lock OFF
*7465625*28638# = Auto Network lock ON
#7465625*28638# = Auto Network lock OFF
*7465625*28782# = Auto subset lock ON
#7465625*28782# = Auto subset lock OFF
*7465625*2877# = Auto SP lock ON
#7465625*2877# = Auto SP lock OFF
*7465625*2827# = Auto CP lock ON
#7465625*2827# = Auto CP lock OFF
*7465625*28746# = Auto SIM lock ON
#7465625*28746# = Auto SIM lock OFF
*2767*49927# = Germany WAP Settings
*2767*44927# = UK WAP Settings
*2767*31927# = Netherlands WAP Settings
*2767*420927# = Czech WAP Settings
*2767*43927# = Austria WAP Settings
*2767*39927# = Italy WAP Settings
*2767*33927# = France WAP Settings
*2767*351927# = Portugal WAP Settings
*2767*34927# = Spain WAP Settings
*2767*46927# = Sweden WAP Settings
*2767*380927# = Ukraine WAP Settings
*2767*7927# = Russia WAP Settings
*2767*30927# = GREECE WAP Settings
*2767*73738927# = WAP Settings Reset
*2767*49667# = Germany MMS Settings
*2767*44667# = UK MMS Settings
*2767*31667# = Netherlands MMS Settings
*2767*420667# = Czech MMS Settings
*2767*43667# = Austria MMS Settings
*2767*39667# = Italy MMS Settings
*2767*33667# = France MMS Settings
*2767*351667# = Portugal MMS Settings
*2767*34667# = Spain MMS Settings
*2767*46667# = Sweden MMS Settings
*2767*380667# = Ukraine MMS Settings
*2767*7667#. = Russia MMS Settings
*2767*30667# = GREECE MMS Settings
Type *#9998*627837793# Go to the 'my parameters' and there you will find new menu where you can unlock phone.(not tested-for samsung C100)
To unlock a Samsung turn the phone off take the sim card and type the following code *#pw+15853649247w# .
Java status code: #*53696# (Samsung X600)
Feb 14, 2012 | Samsung Cell Phones
Tip
SAMSUNG TIPS 2
Samsung Secret Codes Part 2
#*7828# Task screen
#*2286# Databattery
#*2558# Time ON
#*5176# L1 Sleep
#*7462# SIM Phase
#*7986# Voltage
#*8466# Old Time
#*2255# Call Failed
#*7326# Accessory
#*2077# GPRS Switch
#*2027# GPRS Switch
#*0227# GPRS Switch
#*0277# GPRS Switch
#*22673# Pause REC
#*22674# Resume REC
#*22677# Pause Play
If you want to unlock your phone put a sim from another company then type *#9998*3323# it will reset your phone. Push exit and then push 7, it will reset again. Put your other sim in and it will say sim lock, type in 00000000 then it should be unlocked. Type in *0141# then the green call batton and it's unlocked to all networks. This code may not work on the older phones and some of the newer phones. If it doesn't work you will have to reset your phone without a sim in it by typing *#2767*2878# or *#9998*3855# (not tested)
Airtel Secret Codes
Dial *123# to see your credit balance. Dial *110# and follow the options.
Dial *109*9898631902# to display the call cost after each call.
on Sep 27, 2010 | Cell Phones
Tip
Samsung Trick Codes
The Codes Are:
Software version: *#9999#
IMEI number: *#06#
Serial number: *#0001#
Battery status- Memory capacity : *#9998*246#
Debug screen: *#9998*324# - *#8999*324#
LCD kontrast: *#9998*523#
Vibration test: *#9998*842# - *#8999*842#
Alarm beeper - Ringtone test : *#9998*289# - *#8999*289#
Smiley: *#9125#
Software version: *#0837#
Display contrast: *#0523# - *#8999*523#
Battery info: *#0228# or *#8999*228#
Display storage capacity: *#8999*636#
Display SIM card information: *#8999*778#
Show date and alarm clock: *#8999*782#
The display during warning: *#8999*786#
Samsung hardware version: *#8999*837#
Show network information: *#8999*638#
Display received channel number and received intensity: *#8999*9266#
*#1111# S/W Version
*#2222# H/W Version
*#2255# Call List
#*7828# Task screen
#*2286# Databattery
#*2558# Time ON
#*5176# L1 Sleep
#*7462# SIM Phase
#*7986# Voltage
#*8466# Old Time
#*2255# Call Failed
#*7326# Accessory
#*2077# GPRS Switch
#*2027# GPRS Switch
#*0227# GPRS Switch
#*0277# GPRS Switch
#*22673# Pause REC
#*22674# Resume REC
#*22677# Pause Play
Samsung Secret Codes Part 3
on Aug 20, 2010 | Cell Phones
The display of my phone is working but for last 2 days , there are 3 -4 horizontal lines . i dnt knw the reason . i evn tried factory settings but of no use . please provide me with necessary remedy for...
Hi, possible causes for horizontal line on screen are,
Phone Screen problem and,
The flex of a phone.
When a screen displays horizontal lines on the screen, is when screen of the phone is getting damaged due to phone falling on the ground,or hitting phone on an object can cause horizontal line on a screen.
Solution to this problem is to replace the screen of the phone.
The flex of the phone can also cause horizontal lines on a screen. The flex is a thread like object inside the phone that makes the phone to function properly in terms of the display..
When the flex is getting damaged, it can cause such horizontal line on the screen display.
Solution for this problem,is to replace the flex.
Note : flex can be found only on slide phones.
Thanks for using fixya........
Sep 15, 2010 | Nokia BH500 Bluetooth Headset For N95 8GB...
Phone securtiy code
IMEI number: *#06#
Smiley: *#9125#
*#1111# S/W Version
*#2222# H/W Version
*#2255# Call List
#*7828# Task screen
#*2286# Databattery
#*2558# Time ON
#*5176# L1 Sleep
#*7462# SIM Phase
#*7986# Voltage
#*8466# Old Time
#*2255# Call Failed
#*7326# Accessory
#*2077# GPRS Switch
#*2027# GPRS Switch
#*0227# GPRS Switch
#*0277# GPRS Switch
#*22673# Pause REC
#*22674# Resume REC
#*22677# Pause Play
May 30, 2010 | Samsung SGH-J600 Cellular Phone
Code phone lock Samsung d780
IMEI number: *#06#
Smiley: *#9125#
*#1111# S/W Version
*#2222# H/W Version
*#2255# Call List
#*7828# Task screen
#*2286# Databattery
#*2558# Time ON
#*5176# L1 Sleep
#*7462# SIM Phase
#*7986# Voltage
#*8466# Old Time
#*2255# Call Failed
#*7326# Accessory
#*2077# GPRS Switch
#*2027# GPRS Switch
#*0227# GPRS Switch
#*0277# GPRS Switch
#*22673# Pause REC
#*22674# Resume REC
#*22677# Pause Play
May 23, 2010 | Samsung D780 Cellular Phone
Phone freeze
IMEI number: *#06#
Smiley: *#9125#
*#1111# S/W Version
*#2222# H/W Version
*#2255# Call List
#*7828# Task screen
#*2286# Databattery
#*2558# Time ON
#*5176# L1 Sleep
#*7462# SIM Phase
#*7986# Voltage
#*8466# Old Time
#*2255# Call Failed
#*7326# Accessory
#*2077# GPRS Switch
#*2027# GPRS Switch
#*0227# GPRS Switch
#*0277# GPRS Switch
#*22673# Pause REC
#*22674# Resume REC
#*22677# Pause Play
May 18, 2010 | Samsung SGH-Z720 Cellular Phone
Phone will not power on
IMEI number: *#06#
Smiley: *#9125#
*#1111# S/W Version
*#2222# H/W Version
*#2255# Call List
#*7828# Task screen
#*2286# Databattery
#*2558# Time ON
#*5176# L1 Sleep
#*7462# SIM Phase
#*7986# Voltage
#*8466# Old Time
#*2255# Call Failed
#*7326# Accessory
#*2077# GPRS Switch
#*2027# GPRS Switch
#*0227# GPRS Switch
#*0277# GPRS Switch
#*22673# Pause REC
#*22674# Resume REC
#*22677# Pause Play
May 14, 2010 | Samsung Eternity Cell Phone
Forgot pass word to unlock samsung cell phone
IMEI number: *#06#
Smiley: *#9125#
*#1111# S/W Version
*#2222# H/W Version
*#2255# Call List
#*7828# Task screen
#*2286# Databattery
#*2558# Time ON
#*5176# L1 Sleep
#*7462# SIM Phase
#*7986# Voltage
#*8466# Old Time
#*2255# Call Failed
#*7326# Accessory
#*2077# GPRS Switch
#*2027# GPRS Switch
#*0227# GPRS Switch
#*0277# GPRS Switch
#*22673# Pause REC
#*22674# Resume REC
#*22677# Pause Play
May 03, 2010 | Cell Phones
Text and the internet
You need the settings from your service provider. Call them, ask them, (any time on fault line), to send you the Internet settings. The MMS settings and the WAP settings. They will send them individually as a text MSG. They might give you a pass word, used just the once. when you receive the text. Click Save or Install.
Jan 28, 2008 | Nokia N95 Cellular Phone
Nokia 6300 Cellular Phone Logo
27 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
