Question about Dell Latitude D600 Notebook
This is a dell d600 laptop will not bootup will come on for about three second and lights goes out have tried new power cord also tried without battery samething happen could inverter board be the problem or mainboard Also Dell c600 will install windowXP to 34% and freeze change CD drive and disk and same problem also change cpu fan did not help Thanks tyrone18
    Problem Solver:
  • 18 Answers
There is a short circut on mother board ,you need to go to a pro to fix it
Posted on Nov 16, 2009
My dell D600 laptop fails to boot, when i press the power button the three indicator light on it will on for 3 seconds and will off.
Try flexing the whole bottom assembly. that is with the laptop open put your knee in the middle and grab the unit with one hand on the corner closest to you and the other near the screen and put enough pressure to "flex " the mobo right after you push the start button if it doesn't start try it the other way... this has been working for my grandsons d600 for 6 months. i tried a new switch board because the guy that sold me the mobo said the plug for that is know to crack. good luck ps you will know it has worked when the 3 lock lights go out and the power light stays on.
May 12, 2011 | Dell Latitude D600 Notebook
Latitude D600 PC Notebook: dell d600 three light on and of problam...
This is do to the jack were the power button board plugs into the motherboard, i see this alot on d600 and d610, the lights come on for about 3 sec then computer turns off..
this can be fixed by resoldering the plug to the motherboard but most will say you need a new mother board the leads are small and tight together..
Used motherboard on ebay $60-150
May 17, 2010 | Dell Latitude D600 Notebook
Pushing on power button three green lights come on for one secone
click here you would find the details for led codes. you may select any laptop. codes remain the same.
Sep 24, 2009 | Dell Latitude D600 Notebook
Dell D600 Power Up Issue
there is a short circuit onnthe laptop motherboard usually it's power ic's that are next to the power socket that block the power from going to other parts so you should change those ic's
Sep 08, 2009 | Dell Latitude D600 Notebook
Battery not charging
1. plug the power cord into the laptop
2. remove the battery
3. try to power on the laptop
if the laptop led lights up and/or powers up without the battery it can be determined that you need a new battery
if the laptop led doesn't light up and/or power on. then you may have a charging port or power cord problem
Apr 18, 2009 | Dell Latitude D600 Notebook
Laptop will not turn on
Unplug the ac adapter from the back of the computer. Make sure it's plugged to an electric outlet. check if the ac adapter light is solid green. if not. then you have to replace it.
If it is solid green, reconnect it to the computer, if the light on the adapter goes out as soon as you plug it in to the system, you need to replace the motherboard. call dell to seek your options for replacement.
Mar 02, 2009 | Dell Latitude D600 Notebook
I have a dell d600 and the power light comes on for about 3 secs. then goes out and nothing happens... help...
This is common issue and that typically means your Processor is dead. If you dont hear any beeping and it powers off after three seconds without any activity on the screen means BIOS hasnt even found the Processor and without the processor you will get no POST. Post is a bunch of tests for hardware components and give beep codes if it finds an error. Only issue it cant post an error if the processor isnt working. Solution, order a new processor for your laptop and replace it or buy a new computer. If you order a new processor be sure to order some thermal paste too.
Thanks,
ArmyMason
Feb 25, 2009 | Dell Latitude D600 Notebook
Dell Latitude D600 Bootup then screen goes black
bad display drivers, boot into safe mode (F8 on boot) it should let you use the computer, unistall the graphics drivers and reboot again in normal mode, when your in re-install the graphics again
regards
Nov 22, 2008 | Dell Latitude D600 Notebook
Dell latitude d600 doesn't turn on
The test Dell advises to narrow down this issue is to remove the battery, hard drive, ram, and optical drive.  Next plug in the a/c power cord and you should get some LED's coming on. If not it points to the motherboard.
Aug 15, 2008 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
287 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
