Question about Kenmore 23822 Top Load Washer
Leaking from back near drain tube - Kenmore 23822 Top Load Washer
  • 49 Answers
TAKE THE BACK OFF OF IT. YOU MAY FIND A LOOSE HOSE. UNPLUG FIRST. NOT MANY POSSIBILITIES FOR LEAK ON TOP.
Posted on Nov 16, 2009
Leaking water from inside.water on bottom of inside.not evaperating out of drain pan in back.
David: According to PopularMechanics.com: "Usually, it's because the icemaker line has sprung a leak. People don't realize that there's a shutoff valve. Typically, it's under the sink; if not, look in the basement, beneath the fridge." However, David, for me personally, I found this to be true: "The drain tube is blocked. Unplug the refrigerator and locate the drain plug near the back or bottom of the main compartment. Use a turkey baster to force a 50/50 solution of bleach and warm water into the tube. Repeat a couple of times, then remove and clean the drain pan located underneath the refrigerator."
May 18, 2015 | Refrigerators
My GE Profile refrigerator leaks water from the freezer. I find a puddle under it 2x/week.
Defrost drain tube clogged, drain pan cracked, water tubing near compressor gets brittle and leaks, critters chew on water tubing also.
Oct 29, 2013 | GE Profile 26.6 cu. ft. Side-by-Side...
I hae air conditioning condensation leak into passenger floorboard on a 1994 Jeep Grand Cherokee
It is most likely due to the condesation drain tube being clogged. This tube should drain into the engine compartment. It should be located near the A/C evap. coil area where the refrigerant lines go through the bulkhead. If this tube gets clogged, the condensate will back up and find its way into the passenger compartment
Aug 30, 2013 | 2003 Mitsubishi Galant
Large evap leak for 2001 dodge durango
IF YOU HAVE EVAP LEAK INSIDE VECHICLE.YOUR EVAP HOUSING DRAIN TUBE STOPPED UP LOOK UNDER VECHICLE NEAR PASSENGER SIDE LOOK FOR THE EVAP DRAIN HOLE USE A SHOP VAC AND SMALL VACUUM TUBE AS A HOSE TO REMOVE DEBRIS FROM EVAP DRAIN HOLE.SO EVAP TUBE CAN DRAIN FROM OUTSIDE OF VECHICLE WHEN YOU TURN ON THE AC.
Oct 11, 2011 | 2001 Dodge Durango
The air conditioner leaks water on the floor passenger side.
the drain in the evaporator box is blocked, you need to find the dran tube and clear it. I usually take my air hose and gently blow air up into the tube. It should be near the center or the right side of the car by the firewall
Feb 24, 2011 | 2003 Volkswagen Passat
My sun roof leaks and no o0ne seems able to fix it 2004 ion3
Check your water drain holes. There should be one in each corner. The older Saturns would get blocked and the water would back up. On those you can access the drain tube on either front side at the kick panel. I've not tried to fix an ION so I'm not sure how the drains work. Open the sun roof and pour a little water in each corner. The water should drain out behind the front wheels and somewhere near the rear. If it doesn't you have blockage. Find the drain tube and run a wire through it. Make sure your are careful because you can pierce the rubber tube. Good luck.
Jun 11, 2010 | 2004 Saturn ION
Floors in the front are wet and the car is starting to smell
Three possibilities--the windshield is leaking water, the heater core is leaking antifreeze (should smell like antifreeze), or the air conditioner evaporator (near the heater core) has a plugged drain tube and the water condensed out of the warm air is running back into the cab. Hope this helps!
Feb 27, 2010 | 2000 Jeep Cherokee
Water leaking inside fridge.
If you remove the back panel of your freezer you will notice what looks like a drain - melted water will go through a drain hole that extends to your refrigerator inside a cup that slowly drains the water through a tube through the back of your refrigerator and down the drip pan. Your cup may appear fine, but maybe there is some obstruction somewhere causing the water not to drain fast enough - so what happens is that the cup will eventually overflow - try to see if you can remove this and pass a long wire down the drain tube at the back to dislodge anything blocking or partially blocking it - see if you can also clean your drain cup, eventually small derbris accumulate. At the back of your freezer panel look for any partial or complete obstruction of the drain hole and its surroundings, which might be iced up.
I myself have had this problem for months, my refrigerator would have water at the bottom accumulate and eventually under the crispers a river of water :)
Cleaning the cup and the drain tube at the back of the fridge and the drain and surroundings at the back of the freezer panel should fix this problem. Sounds like your drain at the freezer level is plugged up and water is backing up and leaking from elsewhere !
Sep 25, 2009 | Frigidaire PLHT219TC Top Freezer...
Water Leak
need to check to see if the drain line is still in drain pan. if so make sure the condensor fan is blowing. this is the fan beside compressor. its purpose is to transfer heat of the compressor over the drain pan to evaporate the water
Jun 22, 2009 | GE Profile PSW26P Stainless Steel Side by...
Oil leak from tube
you need to replace the o ring on the oil drain dolt that should stop the leak
May 24, 2009 | 2003 Harley Davidson FLSTF Fat boy
Kenmore 23822 Top Load Washer Logo
Sal De
fordexpert
Whirlpool
Whirlpool
