Question about Maytag Neptune MDE5500AY Electric Dryer
Neptune Dryer Blades
The blades in our neptune dryer have become very loose suddenly, can this be fixed?
    Scholar:
  • 86 Answers
Yes - right where the front panel meets the top panel of the dryer on both sides there are two clips. Insert a screwdriver into the clips and push up on top panel. You'll see the screws that hold the fins on the dryer. Tighten these screws or replace. Good luck...
Posted on Nov 17, 2009
My Maytag neptune dryer was tripping the circuit breaker. Then it just lost power and quit. What could cause this and how do I fix it.
This could be a bad breaker or a loose connection in the dryer plug/outlet. If the dryer just will not work at all and there is voltage at the dryer's outlet, then the dryer is defective. I would then suspect the motor as the culprit.
Mar 03, 2011 | Maytag Neptune MDE5500AY Electric Dryer
One of the tumbler blades is loose. How can I tighten the screws? I can see there are two screws holding the blade to the drum. What is the best way to get to the screws so I can tighten them? thanks
There are two clips that hold the lid down. they are located about one inch in from either side of the machine you can use a flat tip screwdriver and push them in and the lid will come up giving you access to the drum vein screws.
Dec 02, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Our Neptune gas dryer seems to work fine but suddenly produces no heat. The vent is clear and the gas line attached and open.
Look at the glow ignitor. If it is broken then it needs to be replaced. About 20 dollars, and a 5/16 wrench will fix this issue, just make sure that you unplug the dryer before you start touching the electrical. This piece is located in the bottom of the dryer behind the back panel.
May 08, 2010 | Maytag Neptune MDG5500AW Gas Dryer
The dryer is not heating all the sudden. I just
check and see if the iginter is loose or not making good contact
Oct 20, 2009 | Maytag Neptune MDG5500AW Gas Dryer
One of the dryer "blades" on the inside fell off
you just need to remove the front panel and then take out the drum. While the drum is out check the rollers and replace the skid pads.
Aug 01, 2009 | Maytag Neptune MDE5500AY Electric Dryer
I dropped a sock into the dryer filter how can I retrieve this
Fish it out with something. It may get in the impeller blades or catch fire.
May 19, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune Dryer making vibrating noise while working
a bearing in the back for your drum sounds like what you describe. It needs to be taken apart and the bearing lubricated with high temp grease
Feb 23, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune sensor and time drying settings
Fixed the problem, not the machine, needed a new dryer vent. Just unhooked the vent and
the dryer worked perfectly. V
Feb 08, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Neptune Dryer PF Error Code
PF is a 'Power Failure' code meaning the dryer power may be interrupted. The plug receptacle may be bad. Check the plug for proper tension. If feels loose, have the receptacle replaced. Inspect the plug for discoloration. (a sign of a bad receptacle). If all looks OK, Check the power connections at the dryer. If looks OK the electronic control may be defective.
May 31, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
174 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
