Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
Red is coming out pink - Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
  • 262 Answers
Try to clean the printhead 2x you can do this using the computer and launching the home center software Just click the help icon(?) then lokk for maintenance and under maintenance click the clean printhead.
Or if you using the ESP3 you can press and hold at the same time copy and cancel button, if you hear mechanical sounds release the buttons and the clean printhead begins.,
If cleaning the printhead will not resolve the issue it means the printhead is already clogged please call kodak tech support toll free for printhead replacement 1 800 421 6699 ext 02,. I think printhead is free of charged
Posted on Nov 19, 2009
Wiring coming out of motor doesnt match wiring harnesses that I have purchased
It is not the replacement you need! Go back and get the correct replacement item.
Sep 02, 2017 | Cars & Trucks
1990 Chevy GMC Suburban alternator wiring
Well, according to my diagrams for 88-94 models, the alternator only uses the red and brown. There are pink-black wires that power some of the sensors and solenoids but should go to a fuse marked ECM in the fuse box.
Have you tried hooking up the harness without using the pink-black wire ?
Aug 28, 2012 | 1990 GMC Suburban
I removed an old wall oven, and the wires coming out of the wall are black, red, pink, and ground. the new oven has black, red, WHITE , and ground. Does pink go to white?
It should go to white. but to double check you should use meter to check if you have 110 Volts between the pink and the Black and 110 Volts between the pink and the red. and 220 between Black and Red
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Leave a comment if you need more help.
Thanks for using Fixya.
Dec 27, 2011 | Ovens
Where can i get a wiring diagram for my 2002 chrysler neon auto
12V CONSTANT WIRE RED and PINK/BLACK Ignition harness
12V IGNITION WIRE DARK BLUE Ignition harness
12V ACCESSORY WIRE BLACK/ORANGE Ignition harness
STARTER WIRE YELLOW Ignition harness
PARKING LIGHTS (+) BLACK/YELLOW At Headlight switch
POWER DOOR LOCK (5-wire reverse polarity) ORANGE/PURPLE Harness Coming Into Vehicle From Driver's
Door
POWER DOOR UNLOCK (5-wire reverse
polarity)
PINK/PURPLE Harness Coming Into Vehicle From Driver's
Door
DOOR TRIGGER (-) YELLOW/BLACK At Headlight Switch
DOMELIGHT SUPERVISION (-) Use door trigger
TRUNK TRIGGER (-) GRAY/BLACK At Light In Trunk
TACHOMETER WIRE TAN/BLUE or BLACK/GRAY At Ignition Coil
BRAKE WIRE (+) WHITE/BROWN At Brake Pedal Switch
HORN TRIGGER (-) BLACK/RED Harness Coming From Steering Wheel At
Column
CAUTION! SRS airbag wires are not enclosed in protective loom at the steering column. They are a twisted pair of wires that run with rest of
ignition harness. Be careful not to cut or probe these wires.
Radio:
(Black plug)
Rear Right speaker -: Blue w/White stripe
Rear Left speaker -: Brown w/Yellow stripe
Front Right +: Purple
Front Left +: Dark Green
Rear Right speaker +: Blue w/Orange Stripe
Rear Left speaker +: Brown w/Blue Stripe
Power Antenna/Amp: White
(Gray Plug)
+12v battery wire: Pink or Pink w/White Stripe
+12v Ignition wire: Red w/ White Stripe
Front Right speaker -: Blue w/ Red Stripe
Front Left speaker -: Brown w/ Red Stripe
May 03, 2011 | 2002 Dodge Neon
I have a Gestetner DSc38u and when I print colour I get a 'red'/'pink' line about an inch from the top of each page. Any suggestions?
If the line is only red or pink, it is most likely caused by the magenta PCU. Replace this PCU and your problem will go away.
Occasionally the magenta developer unit can cause a red or pink line, but the problem is more than likely from your magenta PCU. The PCU is easy to replace, and instructions will come in the box if you order an OEM replacement unit.
Jan 22, 2011 | Ricoh Aficio 3800CMF Laser Printer
5100 HP Desktop printer--magenta ink comes out pink not red (right out of sealed package!)
magenta is just a fancy name for pink.... its usually a darker shade of pink not overly dark but not a bright pink that most associate with the color.
most hp printers use the ckmy color format as opposed to the rgb that most are used to. check your other ink levels to ensure that they are at least half full and when you print out a doc or pic requiring red, the other inks will assist in creating the proper shade
Mar 27, 2010 | HP Office Equipment & Supplies
Jensen vm9510
Attach the pink wire to the red power wire to see if unit comes on. If does then no attached correctly to emergencing brake wiring.
Apr 18, 2007 | Jensen VM9510 Car DVD Player
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
179 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
