Question about Nokia N72 Cellular Phone
Connection error [ packet data ]
M using nokia n-72 with vodafone_my problem is_ while m connecting to server they are showing error message that :''Packet data:packet data not available.Check network services''so_ plz help .. :)thanks
How do I fix server error 8004849
This is from Microsoft:-
If you receive Server Error: 0x80048849 and/ or 0x80048820 in Windows Live Mail at home or while you're in your regular network, it may be due to the setting of the MTU (Maximum Transmission Unit) on the mail client.
If you get this synchronization error at a coffee shop, airport or a place from where you don't usually connect to the internet, we suggest synchronizing mail on your regular internet connection.
When the MTU setting on the mail client is larger than the MTU settings configured on network devices between your mail client and the mail client servers, some data packets may be lost, causing mail synchronization to fail.
Follow the steps given below to fix synchronization errors due to mismatched MTU settings:
Determine the MTU setting on your network device
Apply the MTU setting to your mail client
This is a trial and error process, and will be different for each user. You may have to repeat the procedure below a few times, before you can find out the MTU setting of your network device. Follow the steps below:
Open command prompt
Click Start ? Run ? Type cmd
In the Command Prompt Window, type in the following:
Ping <Mail server address> -f -l 1500
Notes:
The <Mail server address> is the IP address of the mail server that you are unable to synchronize with.
For Hotmail, 65.55.33.106 is the IP address for DeltaSync (mail.services.live.com).In this document we will be using this IP address as an example.
In the -l 1500, 1500 is the max MTU for Ethernet connections.
You may get an error like this (100% packet loss):
C:\Users\username>ping 65.55.33.106 -f -l 1500
Pinging 65.55.33.106 with 1500 bytes of data:
Packet needs to be fragmented but DF set.
Ping statistics for 65.55.33.106:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss)
If you received the error above, subtract 28 from the 1500 bytes of data. In the Command Prompt Window, type in the following:
Ping <Mail server address> -f -l 1472
If you get a 0% Packet Loss with 1472, it means the MTU setting of your configured network is 1472
Note: If you continue to receive the error described in (b) above, repeat the above steps by subtracting 28 from 1472 bytes of data. Repeat these steps until you get a message for 0% packet loss. If you were able to communicate with the mail server at an MTU size of 1424, you will receive the following:
C:\Users\username>ping 65.55.33.106 -f -l 1424
Pinging 65.55.33.106 with 1424 bytes of data:
Reply from 65.55.33.106: bytes=1424 time=230ms TTL=241
Reply from 65.55.33.106: bytes=1424 time=196ms TTL=241
Reply from 65.55.33.106: bytes=1424 time=162ms TTL=241
Reply from 65.55.33.106: bytes=1424 time=163ms TTL=241
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss)
Approximate round trip times in milli-seconds:
Minimum = 162ms, Maximum = 230ms, Average = 187ms
Open command prompt as administrator (you must be an admin on the computer)
netsh int ip show int
You will receive a message similar to the following. Find the connection name that you use to connect to the internet and note the Idx value
C:\Users\Username>netsh int ip show int
Idx Met MTU State Name
1 50 1472 connected Loopback Pseudo-Interface 1
11 20 1472 connected Local Area Connection
To apply the correct MTU setting on your mail client, type the following in command prompt:
netsh int ip set interface <Idx value> mtu= <MTU setting of your router> store=persistent
Press Enter
For example, if the correct MTU setting was 1424 and Idx value of your connection was 11, you will type:
netsh int ip set interface 11 mtu=1424 store=persistent
If (c ) was successful, you will receive the confirmation message "Ok"
Exit command prompt
Restart your computer
Open WL Mail and see if the issue persists.
have Windows Vista Home Premium Recently unable to send or recieve Window...
Feb 12, 2015 | Toshiba Computers & Internet
Tip
Gprs & MMs settings for india mobile networks 2
&gt;IDEA GPRS SETTING <span> </span> <span> </span>#Account Name - Idea GPRS <br /> <span> </span>#Username - <br /> <span> </span>#Password - <br /> <span> </span>#Homepage - http://wap.ideafresh.com <br /> <span> </span>#Proxy and Server Port - 8080 <br /> <span> </span>#Proxy and Server adress - 10.4.42.45 <br /> <span> </span>#Databearer - GPRS / Packetdata <br /> <span> </span>#Acces Point Name - imis <br /> <span> </span>#Proxy - Enabled/yes <br /> <span> </span>#Authentication Type - Normal<span> </span> <br /> <span> </span>&gt;IDEA MMS SETTING <br /> <br /> <span> </span>#Connection name - IDEA_MMS <br /> <span> </span>#Databearer - GPRS <br /> <span> </span>#APN - mmsc <br /> <span> </span>#User name - <br /> <span> </span>#Prompt password - No <br /> <span> </span>#Password - <br /> <span> </span>#Authentication - http://10.4.42.21:8002 <br /> <span> </span>#Proxy serv. address - 10.4.42.15:8080 <br /> <span> </span>#Proxy and server Port - 8080 <br /> <span> </span>&gt;VODAFONE GPRS SETTING <br /> <span> </span>#Account Name: Vodafone_gprs <br /> <span> </span>#Homepage: http://live.vodafone.in <br /> <span> </span>#User Name: <br /> <span> </span>#Pass: <br /> <span> </span>#Access Point Settings: <br /> <span> </span>#Proxy: Enabled <br /> <span> </span>#Proxy Address: 10.10.1.100 <br /> <span> </span>#Proxy Port: 9401 <br /> <span> </span>#Data Bearer: Packet Data <br /> <span> </span>#Bearer Settings: <br /> <span> </span>#Packet Data Access Point: portalnmms <br /> <span> </span>#Network type: IPV4 <br /> <span> </span>#Authentication: normal <br /> <span> </span>#User Name: <br /> <span> </span>#Password: <br /> <span> </span>&gt;VODAFONE MMS SETTING <br /> <span> </span>#AccountName:- vodafone <br /> <span> </span>#Server:- http://live.vodafone.com <br /> <span> </span>#Proxy:- 196.006.128.012 <br /> <span> </span>#Proxy Port:- 8080 <br /> &gt;BSNL GPRS SETTING <br /> <span> </span>BSNL PORTAL <br /> <span> </span>#Account Name - Bsnl Portal <br /> <span> </span>#Username - <br /> <span> </span>#Password - <br /> <span> </span>#Proxy - Enabled/yes <br /> <span> </span>#Acces Point Name - celloneportal <br /> <span> </span>#Homepage - wap.cellone.in <br /> <span> </span>#Proxy and Server Adress - 192.168.081.163 <br /> <span> </span>#Proxy and Server Port - 8080 <br /> <span> </span>#Data Bearer - GPRS / Packetdata <br /> <span> </span>#Authentication Type - Normal <br /> <span> </span>BSNL NORTH <br /> <br /> <span> </span>#Account Name - BSNL GPRS <br /> <span> </span>#User Name - <br /> <span> </span>#Password - <br /> <span> </span>#Proxy - Enabled/yes <br /> <span> </span>#Homepage - http://petercrys.com <br /> <span> </span>#Proxy and Server address - 192.168.051.163 <br /> <span> </span>#Proxy and Server Port - 8080 <br /> <span> </span>#Acces Point Name (postpaid) - www.n.po <br /> <span> </span>#Acces Point Name (prepaid) - www.n.pr <br /> <span> </span>#Data bearer - GPRS/ Packetdata <br /> <span> </span>#Authentication Type - Normal <br /> <br /> <span> </span>BSNL SOUTH <br /> <span> </span>#Account Name - BSNL GPRS <br /> <span> </span>#User Name - Your mobile no <br /> <span> </span>#Password - <br /> <span> </span>#Proxy - Enabled/yes <br /> <span> </span>#Homepage - http://localhost/home.wml <br /> <span> </span>#Proxy and Server address - **** <br /> <span> </span>#Proxy and Server Port - 8080 <br /> <span> </span>#Acces Point Name - bsnlsouth <br /> <span> </span>#Data bearer - GPRS/ Packetdata <br /> <span> </span>#Authentication Type - Normal <br /> <br />
on Jan 11, 2011 | Cell Phones
Nokia X6 Packet Data connection problem
i am trying to disactivate package data connection in nokia x6 so please tell me the solution for it....thanks
Feb 19, 2012 | Cell Phones
Hi i have a nokia 6300 which used to be an old vodafone. i am using it on o2 and have no problem connecting to wap or sending messages. however when i try to access skype i get error message "subribe...
hi there, In this case you need to contact your network provider so they could send you the settings so you could use the service. hope this one helps.
May 18, 2011 | Nokia 6300 Cell Phone
I have got Nokia 3500 with vodafone service.I can access internet from my phone but when i connect to y laptop thru a cable using nokia pc suite , i get subscribe to packet data message on the...
sir please reinstall the pcsuit to the laptop.and go the internet settings in the cellphone and check the internet access option to the vodafone nad then you try to connect the internet..............
Nov 22, 2010 | Cell Phones
How can i set up my mms setting for nokia n86 in
Setting up MMS
1. Select menu button
2. Scroll and select tools
3. Scroll and select settings
4. Scroll and select connection
5. Scroll and select destinations
6. Scroll and select multimedia msg
7. Select options
8. Select new access point
9. When asked “automatically check for available access point” select no
10. Scroll and select packet data
11. When asked for packet data access point enter Vodafone MMS, and enter ok
12. Select edit
13. Scroll and select access point name
14. Delete any text, please enter
For Pay monthly customers: wap.vodafone.co.uk,
For Pay as you talk customers: pp.vodafone.co.uk,
and select ok
15. Scroll and select user name
16. Enter wap, select ok
17. Scroll and select password
18. Enter wap, select ok
19. Scroll to authentication and change to normal
20. Scroll to use access point and change to automatically
21. Scroll and select homepage and enter http://mms.vodafone.co.uk/servlets/mms, select
ok
22. Select options
23. Scroll and select advanced settings
24. Scroll and select proxy server address and enter 212.183.137.012, select ok
25. Scroll and select proxy port number and enter 8799, select ok
26. Select back twice
27. Select options
28. Scroll and select organise
29. Select change priority
30. Scroll to priority one, select ok
31. Select back five times
32. Scroll and select messaging
33. Select options
34. Scroll and select settings
35. Scroll and select multimedia message
36. Scroll and select access point in use
37. Scroll to Vodafone MMS, select ok
38. Select back four times
Let me know how you get on.
Sep 25, 2009 | Nokia N86 Smartphone
I am unable to use opera mini on my nokia 7610 gprs activated phone(vodafone network) when i start opera mini it asks"Allow opera mini to use network connection" and then i click to yes and then GPRS conn...
there's a CONNECTION PROBLEM in your phone. Probably in the Packet Data or whatsoever. Anyway, if you try restarting the phone, it might turn out well, but don't expect that it will be alright immediately. If problem persists, go to the store where you bought your phone and have it a look.
Jun 20, 2009 | Nokia 7610
Cannot send mms. error "check multimedia settings. multimedia message sending failed" I have a postpaid vodafone connection. these are my settings:- Menu u Settings u Configuration Settings u...
ok your settings look 'pefect'
contact VODAFONE customer care on 191 on a pay monthly handset 2345 on a pay and go
they will be able to guide you through the mms set up procedure
Michael
Universal Mobiles Coventry LTD
Mobile Phone Engineer
May 27, 2009 | Nokia 6070 Cellular Phone
Nokia N72 Cellular Phone Logo
232 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
