Question about Echo Garden
Pull rope is stuck
The pull start won't pull. feels locked up.
  • 49 Answers
USE CAUTION THERE IS A POWERFUL SPRING INSIDE.
Posted on Nov 16, 2009
Chainsaw troubleshooting
Sounds like the engine decompressor is stuck shut remove it clean up with carb cleaner and try again.
Jul 04, 2014 | Stihl 009l
I have a Stihl 025 that has become very hard to start because in the past couple of years, it has become difficult to pull the starting rope against what feels like excessive engine compression. Does this...
no
problem could be failing ring/s or excessive fuel in the crankcase causing excessive combustion pressure or hydraulic lock
check by pulling the plug and if that eases the problem and the engine free spins from the rope , overhaul the carby with new needle and seat and diaphragms
Nov 13, 2017 | Garden
TB4BP won't pull
crankcase could be full of fuel causing it to hydro lock take plug out and see if it will pull over be carefull though if it's hydro locked with fuel it will pump out of the sparkplug hole. the rope may be off of the starting pully as well
Aug 26, 2012 | Troy-Bilt 32cc 4-Cycle Gas Backpack Blower...
Pull start rope is hung up and won't release on my ryobi s430
a broken spring a tangled rope a stuck ingaugement tab
Aug 10, 2012 | Ryobi Garden
Starter rope hard to pull on mantis tiller
Sounds like your engine may be seized up. Mine did the same thing and I had to replace the block. If any dirt gets past the air cleaner or if your fuel mixture isn't right it won't take long to lock it up. If you need info on where to find parts, let me know. Good luck.
Jun 20, 2012 | Mantis 2-Cycle Tiller
Tecumseh pull start engine on Craftsman Lawn Vac will not pull. Feels like engine is locked up.
the engine is probably not locked ! remove the plug wire, tip up and see if the blade turns. if so, try the rope again. if it wont pull, take top off mower off to investigate the pull rope problem. good-day !
Nov 07, 2011 | Garden
Pull rope stuck
It sounds as if the motor may be locked up. WIth spark plug wire disconnected, turn mower on side and see if you can turn blade. It should turn rather easily, but you will feel the compression stroke. If you can' turn it try removing the spark plug. If you still can't turn it, check the oil level, if it's low the motor may be siezed. You also could have a stuck valve. If it is a valve you can try removing the cover, and soak it with oil. It is imperative to watch the oil level in small motors, as well as being sure to change it.
Jul 23, 2010 | Poulan "" Push Mower
The rope on my generator gets stuck as i pull to turn it on
Assuming the rope stays on the internal pulley, it is NORMAL for the rope to require great force at points in the cranking cycle (once per revolution of the crankshaft). These are the compression strokes and the force is MANY times the initial pulling force. If the rope returns easily, then the starter assembly is probably normal. It takes a strong arm and fast movement to start the enginess via pull rope. Some units have a compression release to ease this a bit.
Mar 22, 2010 | Electrical Supplies
ROPE ON MOWER WON'T PULL OUT
look under neath and see if anything is stuck in the blade. You probly have a cover for the top part; see if you can pop off a plastic top if you have one.
May 11, 2009 | Garden
When try to pull on the rope to start the mower is will not move. It feels like it is stuck. But I can move the blade around. Thank you
I thing the recoil spring is stuck it may be rusty. Its time for a complete maintenance on this mower. But you could try tapping the top of the recoil where the rope coils up into. Bang it a few times as you pull on the rope. this may free it up. Good luck DFD
Apr 20, 2009 | Garden
Garden Logo
313 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
