Hdd/dvd recorder RH265
Chinese menu etc - how do i get back to english - start setup again ? how ?
  • micheal1043 Jan 11, 2008
    thanks that did it
  • 102 Answers
Press:
Home
Left (navigation pad keys)
ENTER
Down
Right
Right
Second choice from top
OK
Hope this helps :)
Posted on Jan 11, 2008
LG RH265 does not read DVDs
Purchase a DVD cleaning kit and follow the instructions, this will remove any dirt from the laser pickup lens, and hopefully get it up and running. If this fails, the only other option is have the whole laser assembly replaced, "expensive" or replace the entire unit.
Mar 06, 2012 | LG RH1999H DVD Recorder/HDD Recorder
I NEED AN ENGLISH MANUEL FOR DVD RECORDER-RH265
There you go:
http://www.lg.com/lgecs.downloadFile.ldwf?DOC_ID=KROWM000152870&ORIGINAL_NAME_b1_a1=RH265-WM_NA2ALLB_MFL36926587.pdf&FILE_NAME=KROWM000152870.pdf&TC=DwnCmd
Aug 12, 2011 | LG Computers & Internet
My LG RH265 keeps opening the tray. When I close it with the remote, it opens itself again. This problem repeats itself on and on. What can I do about this, is there a way to reset the recorder?
My RH265 has had this fault three times and on each occasion LG have replaced the 815V DVD Deck (Part No. EAZ34934813) - This fault seems to be common to all their recorders and in my view gives LG an otherwise undeserved very bad name for product reliability. I am very surprised that they do not appear to have solved the problem with a reliable component.
Dec 06, 2009 | LG RH177 DVD Recorder/HDD Recorder
HDD/DVD Model RH265 : worked perfectly for 14 months. Now will not allow deletion of data from HD and also will not allow recording to HD. Symbol circle with diagonal bar appears on screen . Still allows...
Sounds like the hard disk might be full. How many recordings have you got on the machine? You say it won't allow you to delete "data". Have you protected the recordings?
Jun 30, 2009 | LG RH1999H DVD Recorder/HDD Recorder
Dm-20 displays Chinese
To reset the settings back to English:
1. Set the DM-20 to Voice mode using the blue switch on the back voice recorder.
2. Remove the DM-20 from Hold using the gray switch on the back of the voice recorder.
3. Press and hold the DISPLAY/MENU button on the front of the DM-20 for at least 3 seconds. The menu list is displayed.
4. Click the REWIND button six times to highlight the Format menu item.
5. Click the PLAY button to select the Format menu item. A message will be displayed with Cancel and Start options.
6. Click the REWIND button once to highlight Start.
7. Click the PLAY to select Start. A message stating that the data will be cleared will display briefly. Then a message asking if you are sure will be displayed.
8. Click the REWIND button once to highlight the Start menu item to continue with the format.
9. Click the PLAY select the Start menu item and begin the format. The format progress bar will appear. When it is complete the menu items will be in the English language.
Jan 08, 2009 | Olympus DM-20 Digital Voice Recorder
LG HDD/DVD Recorder Model: RH265
What you need to do is to put in your dvd that you wish to copy onto and then press the DVD button on your remote control. (this is next to the HDD button which is under the POWER button) Then follow the on screen prompts and instructions in the owners manual. I had the same problem but found the solution by mistake!
Hope this helps,
Nicky
Mar 02, 2008 | Televison & Video
Unlock regions on LJ RH265
Go into setup, select lock and press 0 seven times. should unlock it
Feb 16, 2008 | Televison & Video
LG RH265 - Problem when trying to register blank disk/dubbing
The DVD needs to initialise the disk first. Come out of the HDD dubbing menu and press DVD on the remote. The blank recordable disk should be recognised and you should see Initialise disk? on the screen. Press Start and hey presto, you can now dub from the HDD Movie dubbing menu (as per the manual instructions).
Feb 15, 2008 | LG RH177 DVD Recorder/HDD Recorder
Connection problems.
Must be connected by now I guess :)
Dec 14, 2007 | LG RH177 DVD Recorder/HDD Recorder
Dubbing rom hdd to dvd
All you have to do is select dvd on the remote (at the top). Then it should do it automatically. If it doesn't, go to menu, then setup, disk, format. That does the job.
Nov 17, 2007 | LG RH1999H DVD Recorder/HDD Recorder
Televison & Video Logo
80 people viewed this question
Top Televison & Video Experts
