Question about Sony PlayStation Portable (PSP) Slim (PSP-2000) Console
My psp volume button will not work can you help but its only the one to turn it up not down
  • Sony Master
  • 441 Answers
When this happens, it's because the volume button on the inside is messed up. Usually it's because it's dirty or sticky and sticks down [or presses itself]. You can try opening it and cleaning under the volume button. If that doesn't work, you may need to replace the home/volume/start/select circuit ribbon cable. If you're not comfortable opening it, check the following company -- they would repair something like this for $29
http://store.richspsxparts.com/clforpsprese.html
Posted on Nov 17, 2009
5 Suggested Answers
SOURCE: PSP Not Working
Hey, try taking the faceplate and screen off. Get a blowdryer and dry. This sometimes fixes the problem.
Posted on Jul 20, 2008
  • 4 Answers
SOURCE: psp volume wont turn up
the button my be broken
Posted on Aug 27, 2008
Wiseman08
  • 13 Answers
SOURCE: The volume button of my psp does not work
I think your volume button is broken because I had a similar problem with my psp My WiFi switch wont work when I had it checked the switch was detached from the command it was assigned to
Posted on May 21, 2009
benwabnick
  • 2404 Answers
SOURCE: all my psp buttons except for the volume didnt
once you try to upgrade and fail, then there is no way to get it back, its called bricking, meaning the PSP is as good as a brick. Here is the site that explains it more in detail so that way you'll have the info for the future.
http://www.askdavetaylor.com/can_i_roll_back_my_sony_psp_firmware_upgrade.html
Posted on Jan 04, 2010
Testimonial: "then what should i do to fix this my psp?.."
I have a problem on my psp. while im playing Dissidia 012 the volume simply went off. so i push the + volume button to increase . but nothing happend. so i dont know whats the problem with that . so please...
Your Volume Down button is probably malfunctioned and is stuck down. The following website sells the exact part you would need, the home volume select etc, switch under the bar on the inside. They also install it if you're not comfortable doing it:
http://store.richspsxparts.com/psppspshovos.html
Apr 01, 2011 | Sony PSP-3000 Black Console
Tip
How to fix Volume issues in PSP Portable
How to Fix a PSP Volume Button through Software
Check to be sure that your PlayStation Portable's AVLS (Automatic Volume Limiter System) is turned off.
Start your PSP without a game in it. Choose "Settings," then select "Sound Settings." If the AVLS option is "ON," turn it "OFF."
Check to see that your memory stick is inserted properly if the sound still does not work. This often interferes with the volume control. Remove the memory stick and reinsert it.
Perform a hard reset of your PSP if the volume still does not work. To do this, first unplug your PSP and remove any games or memory sticks. Then remove the battery from its cavity on the back. Press and hold any button for five seconds, then reinstall your battery.
Move on to hardware solutions if none of the above options work
How to Fix a PSP Volume Button through Hardware
Remove your PlayStation Portable's battery pack, any games and memory sticks. Unplug it.
Unscrew all five screws that hold the faceplate onto your PSP. The fifth is hard to locate, so find it just below the screen on the bottom edge.
Clean the button heads underneath the volume buttons with a small cloth. You should also clean the Home button nearby as this often interferes with the volume button.
Return the faceplate and screws, and test your PSP.
on Feb 13, 2010 | Video Game Consoles & Games
My PSP 3000s sound system is alweys on full volume and I cant control the volume on it. it wont let me
Try going to sound settings and go to dynamic normalizer and if its off turn it on if you want to listen to your music you might also want to check by that i mean take the cover off the psp unscrew it Look at the place were the button for volume + - are and see if its jamed if you want to mute your psp hold the sound logo down untill you can't hear anything
Aug 24, 2010 | Sony PlayStation Portable (PSP) Console
How to incres volume of psp
Follow these steps to increase the volume for your PSP-
(1) Turn on your PSP and start playing your movie, song or game. Boost the volume of the PSP by pressing the volume control buttons located on the button bar, which is below the screen. The (+) button will turn the volume up, and the (-) button will turn the volume down.
(2) Plug your PSP into a larger speaker if the volume still is not high enough. You need an auxiliary cable with two male ends to plug the PSP into a speaker. You can use a three-foot cable. Plug one end of the cable into the PSP and the other into the speaker input.
(3) Plug any FM transmitter into the PSP headphone jack and tune your radio to the FM station on the FM transmitter. Your audio from the PSP will now be playing through the radio speakers in your car or home. This will allow you increase the volume greatly.
Thanks for using Fixya.
Good Luck and have a nice day.
Jun 06, 2010 | Sony PlayStation Portable (PSP) Console
My volume dont work is there anyway i can troubleshoot it or restart the whole thing?
Feb 13, 2010 | Sony PlayStation Portable (PSP) Console
My psp volume wont turn up
Your vol up and down buttons are broken probably. you either gotta open ur psp and clean it or u gotta go down to the local game shop and ask them abotu the problem and see if they can fix
Nov 02, 2009 | Sony PlayStation Portable (PSP) Slim...
May 20, 2009 | Sony PlayStation Portable (PSP) Console
PSP Not Working
Jul 19, 2008 | Sony PlayStation Portable (PSP) Console
Psp keys
It sounds like the pc board that the volume buttons are in is damaged or coming loose. Aany repair shop that services PSP's should be able to fix that.
Sep 12, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Slim (PSP-2000) Console Logo
1,290 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
