We are unsure what holes on the back of LG32LX2R to attach wall brackets to, can you help
  • 49 Answers
DEPENDS ON WHAT BRACKET YOU HAVE IF YOU HAVE A BRACKET IN MIND, SOME OF THE HOLES SHOULD LINE UP EXACTLY. IF NOT THE BRACKET MAY NOT BE SOUTABLE FOR YOUR TV. DO NOT USE TO LONG OF SCREWS.
Posted on Nov 16, 2009
Towel rack fix came out from wall
Go to a hardware store and wall anchor screws to reinstall the brackets that hold to towel bar to the wall. There should be two brackets and two holes on each bracket. If the existing holes are to big, drill two new holes on each side. Screw the brackets to the wall. As you turn the screw, the will expand in the screw hole and hold the brackets that you attach the towel bar to.
Feb 02, 2018 | Towel Rack Home
Wall mount Sanyo LCD-32xr8DA
look at the middle of the tv the 4 screw mount thats wre the tv wall mount gos. good luck
Jun 15, 2013 | Televison & Video
Remove stand from monitor
there will be screws on the back which will allow you to remove the stand, then on the back of the monitor their should be 4 screw holes, use these to attach a a flat plate wall bracket to it.
but if you can't remove the stand, then put a clap speaker bracket on the wall & just clap the base of the monitor, as this type of bracket can be adjusted both in & out & up & down.
Jul 21, 2012 | Acer AL1711 17" LCD Monitor
Instalation Instructions for Frigidaire Over the Range Microwave 850 Watt Model #FMT118EPB
HI,
Frigidaire makes several over-the-range microwave models that are all installed in the same manner. To install correctly, you must have at least 45 1/2 inches from the bottom of the top cabinet to the cooking surface of the stove to provide enough clearance for the microwave. The top cabinet must also be at least 30 inches wide and 12 inches deep. Find someone to help you, then follow the steps below to install your Frigidaire microwave.
Things You'll Need:
  • Stud finder or hammer
  • Screwdriver
  • Drill
Instructions
Pull your range away from the wall so you can work comfortably. If this is not possible, cover it with a drop cloth. Find and mark the locations of the studs in the wall behind the range. They will be either 16 or 24 inches apart.
Follow the instructions on the wall template to mark the location of the mounting bracket and the four anchor holes on the wall and the bottom of the cabinet. Drill the anchor holes. Follow the instructions on the top cabinet template to mark and drill the two holes in the bottom of the cabinet.
Attach the mounting bracket to the wall studs using the six wood screws included with your microwave. Screw the toggle nuts onto the toggle bolts and push one through each of the four drilled holes. Screw each toggle bolt until the nut is snug against the inside of the wall.
Pick up the oven with your helper. Plug the oven into the outlet and slide the oven onto the mounting bracket arms. Push the oven back against the wall. Tighten the two screws on the microwave faceplate to fasten the microwave to the mounting bracket arms.
Attach the louver to the top of the microwave with the three provided screws. Insert the two top cabinet screws and washers from the top cabinet into the microwave and fasten tightly.
Take care.
Jun 16, 2010 | Frigidaire Microwave Ovens
How do i attach a wall mount to the back of my 20" samsung?
Samsung wall mount bracket WMB 1900T adapts for four hole wall mounts. Fits 19" to 22" monitors. Price is $27-$42 at online stores.
Apr 09, 2009 | Samsung T200HD LCD Monitor
No screws are included for wall mount
we can not , as we can not measure the diameter of the holes thru the computer .
Oct 10, 2017 | Coby DVD-988 Theater System
Attaching Wall Mount Support to AKAI Flat Panel
You use the four outer holes as suggested in the manual on page 12, see below:
Apr 23, 2008 | Akai LCT2721AD 27 in. LCD Television
Hannspree Television/Wall Bracket
If there are six threaded holes in the rear of your TV and the bracket supplied has only four holes I would bet that the weight requires a heavier bracket.
Apr 03, 2017 | Hannspree Televison & Video
Wall mount doesn't fit holes on tv
As your learning a universal wall mount won't work on this set because of the hole configuration, below is a link to one that should work but its not cheap.
AW51 NEW AKAI PDP TELEVISION WALL MOUNT BRACKET PMT4290 NIB AW51 eBay
Feb 23, 2018 | Televison & Video
How do i attach a Wall Mount to the TV?
Hi, Ok, great.Look at the back panel and you can see four holes spaced 4" between the top and bottom, and 16" from side to side. these are for universal mount. http://www.bestbuyplasma.com/Plasma/tvmounts_land.asp I think this clears your problem regards sreejith "Please use caution if wall mounting this product. Follow all directions from the manufacturer of the wall mount and be sure to securely fasten the product to the mount. While the TV can be wall mounted, improper wall installation may void the warranty."
Jul 16, 2007 | Akai LCT3285TA 32 in. LCD Television
Televison & Video Logo
Top Televison & Video Experts
