Question about LG Studioworks 563N 15" CRT Monitor
150 watt bulb in a crt monitor power circuit is blinking, on and off what could be the problem
  • 49 Answers
IF THE BULB BLINKS, IT COULD BE THE BULB OR THE BALLAST CONTROLLING IT. CONTACT SHOPJIMMY.COM IF YOU WANT TO TRY FIXING IT YOURSELF. OR GET A NEW ONE PRICES ARE DOWN.
Posted on Nov 16, 2009
My bike pulsar 150 natural light not working what I do
Hi, Ashok if your headlight is not working, keeps burning out, blinking, or is dim the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
1. Faulty ground or power supply wire to headlight bulb socket.
2. Worn down solder contacts or loose fit of the bulb base in the socket due to vibration.
3. Worn, chaffed, or broken wires in the light circuit.
4. Corroded, broken, or loose pins/sockets in wire connectors.
5. Faulty hi/lo beam switch.
6. Faulty ignition switch.
7. Fuse is good but no continuity on both sides.
8. Faulty wiring between battery positive and headlight bulb socket.
9. Weak charging alternator/generator.
10. Faulty voltage regulator/rectifier ground or overcharging.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Pulsar 150 cc headlight horn Problem
http://www.xbhp.com/talkies/motorcycle-ownership-experiences/4984-bajaj-pulsar-150-all-versions-158.html
How to change pulsar 150 head light bulb part 2
Bajaj Pulsar 150 Maintenance Manual
Aug 03, 2016 | Motorcycles
Tip
Power Consumption by CRT monitors
<span>Frequent PC users especially desktop PC's with CRT monitors has to be very careful in using the CRT monitors as that consumes more power than other types of monitors in market.</SPAN><br> <span>Recent research has found the CRT monitors to be consuming 60-80 watts of power for a normal 15 inch monitor compared to 25-35 watts for LCD. The power consumption is almost double in CRT's. If you consider 17-19 inch monitor the power consumption in CRT's might go up to 100-150 watts roughly.</SPAN><br> <span>It is advisable for more than 1 CRT monitor users to keep the monitors switched off when not in use so the power consumption is reduced.</SPAN><br>
on Dec 12, 2010 | Computers & Internet
How many 5 watt outside lights can you power with a 20 amp breaker?
Volts x amps= watts.
20 amp breaker x 125 volts = 2500 watts.
However, electrician use the 80% rule, so multiply 2500 x 80% = 2000 watts.
So if you have 20 amp breaker, and 12 gauge wire, and 20 amp switch, and distance is less than 150 feet, then watt load is 2000 watts or 400 5-watt bulbs.
Keep in mind that most switches are 15 amp, and not 20 amp.
Recalculate for 15 amp switch = 1875 watts x 80% = 1500 watts or 300 5-watt bulbs.
Jun 22, 2012 | Home
Want to know power consumption of a hpsr5410f
The HP Pavilion w1907, 19 inch Widescreen monitor, RK283AA,
uses 49 Watts in operating mode, 2 watts in sleep mode.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00916924&tmp_task=prodinfoCategory&cc=us&dlc=en&lc=en&product=3351967
The Compaq Presario SR5410F Desktop PC, has a 250 Watt power supply. (Maximum wattage rating )
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01374067&tmp_task=prodinfoCategory&cc=us&dlc=en&lc=en&product=3686678
Theoretically.
Back in the day when this computer was made, Power Supply manufacturers were 'fudging' a bit on the truth.
(HP has their Power Supply's made by another company.
Bestec, HiPro, and Delta, are three of them )
Actual wattage is more like 60 to 70 percent, of what is stated.
250 divided by 10 = 25.
25 times 6 = 150 (60 percent)
25 times 7 = 175 (70 percent)
Your Power Supply's actual maximum rated wattage, may be as low as 150 Watts!
Going with the Power Supply produces a maximum of 250 Watts;
If you are playing an intense game, or have several programs running at once, you MAY reach using 250 Watts.
Just surfing the internet? About 100 Watts.
Desktop PC plus Monitor:
1) Surfing Internet: 149 Watts, or let's just say - 150 Watts
2) Computer is maxed out running hard?
249 Watts, or let's just say 300 Watts.
Voltage times Amperage = Wattage
Wattage divided by Voltage = Amperage
Number 1 above? About the power it takes to use a 100 Watt light bulb, and a 50 Watt light bulb. (Incandescent)
Number 2? About the power it takes to run three 100 Watt light bulbs.
(Incandescent)
Regards,
joecoolvette
Apr 16, 2012 | HP SR5410F 18GHz Presario Pentium Desktop...
How much power does a computer use while in sleep mode?
If your computer is a desktop and using CRT monitor it will consume 60 to 250 watts when being use. But if in standby mode or sleep mode it only uses 1 to 6 watts. A typical CRT 17" monitor is consuming 80 watts and the 17" LCD monitor is consuming 35 watts it defends on the type of unit is being used. hope this may help good day and best regards.
Sep 17, 2011 | Computers & Internet
My acer AC713 monitor's brightness value gets reduced to zero.
Dear sir,
This is common problem arises mainly due to moisture,especially in rainy season,Monitor front panel control buttons remain pressed,due to deposition of ferric oxide and moisture in between monitor botton panel and circuit board.So you can dry this moisture by hanging a bulb of 60 watt nearer a monitor about 4-5 hrs,(too near may damage the internal heat sensitive parts.).It solves your problem.....and also you may clean the inner monitor button contacting circuit by means of PCB cleaner to wipe out ferric oxide deposition.
if you had any query regarding this issue leave a feedback we glad to assist you.
good luck.
Sep 10, 2009 | Acer AC713 17" CRT Monitor
Protection light blinks and beeping
it has been through an overload (hence the protection light) and needs its breaker to be reset (look for a poped out button and push it back in) or it needs a new fuse (replace ONLY WITH THE EXACT SAME MODEL OF FUSE or it will either blow too early or too late (or not at all) when there is a surge.
Aug 17, 2009 | Monster Cable Monster Mobile PowerStation...
No display
test all HV mylar capacitor around the horizontal circuits.. usually .22 1600volts with color orange or blue..replace caps that value has changed..
Jan 23, 2009 | Compaq V700 17" CRT Monitor
LG Flatron ez t713sh 17" CRT Problem:
I already have the solution to that problem. It is a faulty capacitor that needs replacement. If you want you can copy and paste this link http://loversdelight-ididitmyself.blogspot.com.
Jun 30, 2008 | LG Flatron Ez T710BH 17" CRT Monitor
LG Flatron L1550S power light blinks green.
shorted components on the circuit. send it to a repair shop if you don't have experience on electronic troubleshooting!!!
Nov 27, 2007 | LG Flatron 995FT 19" CRT Monitor
LG Studioworks 563N 15" CRT Monitor Logo
93 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
