Question about Canon FAXPHONE L80 Laser
Feeds two sheets on top of each other through feeder when transmitting.
When transmitting originals, two are fed on top of each other.
  • KevinWh Jan 12, 2008
    Mine does that too. I have discovered that inside the original feed opening, there is a sensor on the left that cycles in and out to let the first page feed and then blocks the others until the end of the first page. Mine is not cycling in and out like the other machines in my office. I need to check with Canon how to get it repaired.
Before I taped the sensor, it wouldn't retract to allow the paper through and the rollers would grab a sheet and try to pull it through jamming the sheet in the ADF since the sensor blocked the paper path. Took it in to the local Canon repair shop on Saturday for a technician to look at it.
Posted on Jan 14, 2008
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
The problem is not the sensor, itis the rollers that feed and seperate the paper.
the sensor only tells it there is paper, in the machine. then there is a tire that feeds the paper and another that stops the others from feeding at the same time. If the tire ( on some models it's a pad that looks like it has a rubber or a cork.) is old it looses it's grip and let's the paper slip by. Try cleaning with alcohol, must be replaced eventually.
Streaks on copies when original is fed through Imageclass MF 4694 top feeder; doesn't happen when on flatbed
There is dirt on the ADF glass. Normally to the left of the flat bed glass, there is a thin glass strip. Clean it with a damp cloth.
Aug 06, 2012 | Canon imageCLASS MF4690 Multifunction...
Miss feeds when print multilpe pages
The paper feed solenoid is sticking, it can be seen thru a hole in the back with the door opened. Not easy to get to, but I have been able to bend the stop tab slightly and run just fine.
Sep 02, 2009 | Konica Minolta magicolor 2300DL Laser...
Saying paper jam dcp-135c brother printer
 Hello there,If the paper is lodged too far into the printer and can't be removed: Press the power button to turn the printer off.
Pull firmly on the paper to remove it. If you can't reach the paper because it is too far in, raise the front cover and remove the paper from the front of the printer.
Close the front cover.
Press the power button to turn the printer back on.
Resend your document to print.
Ensure that:
The paper is a recommended paper for Laser printers.
You do not force the paper down into the printer when you load it. For example, if you are loading letter or A4 size paper, the top edge of the paper should extend above the top of the sheet feeder.
The printer is on a flat, level surface.
The left paper guide is against the side of the paper.
You do not load too much paper in the sheet feeder. Depending on the thickness of your paper, the sheet feeder can hold up to 100 sheets of paper.
The left paper guide does not cause the paper to bend in the sheet feeder.
Your printer feeds regular paper as expected. If regular paper feeds without causing problems, load the envelopes vertically against the right side of the sheet feeder. Make sure the paper guide is against the side of the envelopes.
Envelopes or the appropriate specialty papers are selected in the printer driver.
You are using a paper or envelope size supported by your printer.
do not forget to rate this solution....good luck
thanks for using FixYa
Jan 30, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Paper is feeding unevenly on black & white prints
  1. Press the power button to turn the printer off.
  2. Pull firmly on the paper to remove it. If you can't reach the paper because it is too far in, raise the front cover and remove the paper from the front of the printer.
  3. Close the front cover.
  4. Press the power button to turn the printer back on.
  5. Resend your document to print.
Ensure that:
  • The paper is a recommended paper for inkjet printers.
  • You do not force the paper down into the printer when you load it. For example, if you are loading letter or A4 size paper, the top edge of the paper should extend above the top of the sheet feeder.
  • The printer is on a flat, level surface.
  • The left paper guide is against the side of the paper.
  • You do not load too much paper in the sheet feeder. Depending on the thickness of your paper, the sheet feeder can hold up to 100 sheets of paper.
  • The left paper guide does not cause the paper to bend in the sheet feeder.
  • Your printer feeds regular paper as expected. If regular paper feeds without causing problems, load the envelopes vertically against the right side of the sheet feeder. Make sure the paper guide is against the side of the envelopes.
  • Envelopes or the appropriate specialty papers are selected in the printer driver.
  • You are using a paper or envelope size supported by your printer.
Important: Your application may not be designed to print envelopes. For help, consult the documentation that accompanied your application.
May 21, 2008 | Lexmark X4270 All-In-One InkJet Printer
Paper feed on Canon i 350n ink jet printer
Ensure that:
May 13, 2008 | Canon i350 InkJet Printer
Paper jam
I removed paper from jam, red light will not quit flashing, I turned
printer off and on again, but it will not print and red light will not
quit flashing, What can I do?
May 12, 2008 | Office Equipment & Supplies
Jammed paper
Ensure that:
Apr 28, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Paper jam
Ensure that:
Jan 04, 2008 | Lexmark X1240 All-In-One InkJet Printer
Canon FAXPHONE L80 Laser Logo
112 people viewed this question
old marine
old marine
