Question about Microwave Ovens
Microwave faulty hi there just needs advise from you guys.I have an LG mocrowave,every times using it ,it keep blow out the fuser and spark every where in side compartment of mocrowave . cheers henry
  • 579 Answers
High voltage parts are suspect. You are looking at replacing either the magnatron or the high-voltage capacitor and diode. Its affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Hope ya fix it!
Posted on Jan 09, 2008
MY LG turntable keeps SPINING, I woke up this a.m. and the light was on and the turntable is go ing around and wont stop unless i unplug the unit. its it not using the mocrowave power just the talbe...
Hi Chloe,
Depending on where you bought this unit, typically, the first 30 days is in store exchange. This is a door switch problem. If you bought it online, contact the seller. I don't know what the warranty on this unit is..
Oct 22, 2013 | LG Microwave Ovens
R-408HS some buttons dont work
If the unit does this the keypad area may be bad---cheaper in most cases to buy a new unit.
Jun 17, 2012 | Sharp R-408HS Microwave Oven
How to get a burnt smell out of mocrowave
Mix some vinegar in a cup of water, put in microwave and set for 60 seconds, {may need more time} and wait till it starts to steam {may need to repeat} this will bind itself to the interior eliminating the burnt smell.
May 16, 2012 | Rival Microwave Ovens
My mocrowave does not heat items. It can be truned on and runds for the alotted time but it does not heat or thaw. Kenmore #88343
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 24, 2011 | Kenmore 69642 Microwave Oven
My microwave produce less heat
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off.
Now keeping clear of the microwave, switch on, use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues, you can use the microwave safely
May 11, 2011 | LG Microwave Ovens
Unit turns on, turntable turns, but nothing heats
Classic symptoms for failed door interlock safety switches, though it could be other trouble.
Remove the cover and check the operation of the little micro switches that operate when you close the door.
DONT TOUCH THE SILVER CAN - LETHAL.
If you regularly open the door while cooking, the contacts in these little switches become burned. When burned badly enough, they cannot make contact. When they cannot make contact, the mocrowave doesnt know the door is closed and will not turn on the magnatron resulting in no heat.
If you need more help, let me know.
a
Sep 27, 2009 | LG LRM1250 Microwave Oven
Microwave won't shut off
the timer is more than likely broken. There are no replacement parts and the mocrowave will need to be replaced...or keep the door open when not in use, and use a watch to keep track of cook times
May 05, 2009 | Sanyo EM-U1000W Microwave Oven
Mocrowave clod
heatman101
9t
Jan 23, 2009 | Samsung MW1030WA Microwave Oven
Ge XL spacesaver Microwave blowing fuses
I had the same problem.
Took it in to the local repair guy and he found the transformer was blown.
Cost $120 including tax
Jan 15, 2009 | GE JVM1630 Microwave Oven
Microwave Ovens Logo
57 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
