Half the screen on my Normende LCD is bad quality, green streaks on it, how can i fix it
    Scholar:
  • 108 Answers
Green streaks, and or lines across parts the screen usually is a either video controller failure. Or a compononet failure on the screen, a higher end shop may be able to repair. If your out of warranty the repair MAY end up more than cost of a new unit. look in your manual and see if there is a factory reset. try that first. but usually its a controller failure of either each line on screen or general video processor.
Posted on Nov 16, 2009
How to fix Toshiba Regza LCD TV when half the screen with vertical streaks?
hi this fault sounds like a bad tab/ribbon fault, at top of the tv are ribbons connector to the screen, when one is faulty the heat makes them flex causing this fault, you can bond the ribbon down with a bit of rubber to stop it flexing, but this not a permanent repair as it is a screen fault. hope it helps
regards
shaun
Apr 24, 2014 | Toshiba 42HP66 42 in. LCD Television
MY MONITER LGW1643C TROBULESHOOTING PROBLEM AND HALF DISPLAY IS GOOD HALF DISPLAY IS BAD
kakred6, If unit "date of manufacture) on rear cover is 2004 then trade unit for new wide screen unit! What is the problem with the "BAD" half of screen??? Is it the right, left, or upper, or lower half?? Most lcd display problems stem from a faulty internal, or external (lay on floor) "switch-mode-power-supply" going bad from poor quality CAPACITORS having been installed on the "switch-mode-power-supply board. Read fixya profiles of "budmrtn" "buddymc" "12fixlouie" to see if you want to explore a DIY fix. Also visit YOUTUBE for DIY video clips. If you deem this response useful, please rate it on FIXYA after you do your research! Bye for now. 12fixlouie
Aug 10, 2010 | LG Computers & Internet
My daughter's LCD TV has color vertical streaks
I believe she had damage the screen TFT (Thin Film Transistors that drive each LCD Red, Blue, Green pixels, there are about a million of them on the screen). The sreen is very delicate. You can ask local repair shop for second opinion.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Jul 01, 2010 | Olevia MN-20LCDTV-SN 20 in. EDTV-Ready...
Dark shadow-like vertical streaks thru LCD screen (Sharp)
Hi, I have a Sony Grand Wega LCD Projection TV that has a blotted gray streak across the front of the screen. I only use a damp cloth to clean the window and that doesn't seem to help. It really shows up on light pictures and is unnoticed when the picture is a little darker. What can I do to fix this problem???
Aug 19, 2009 | Philips 32PF5531D 32 in. LCD Television
Westinghouse LCD TV - broad vertical green and blue lines
try to go to the factory reset and see if that helps. If not, you can then check your connection. if you use component (red, green and blue for video and red and white for audio), make sure all the color matches when you plug it in. if everything have been checked then you need to replace the main board and it should correct the problem.
Jun 22, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Colorful streaks/spots on my camera screen.
probably a bad connection to the lcd display. warranty fix.
Jun 19, 2009 | Canon PowerShot SD1100 IS Digital Camera
Screen
Sounds like you LCD has gone bad... Its like a calculator LCD when you press down on the screen of it it get like a blob. My projector also has done this... Half of the screen is all blue
Sep 06, 2007 | Hitachi Performa CP-RS55 Multimedia...
Televison & Video Logo
85 people viewed this question
Top Televison & Video Experts
Electro Med Services...
