Question about Hayward 48 Sq Ft Pro Grid Vertical Grid De Pool Filter
Why is my harward pro grid de filter shooting out all the debris it collects? It will collect and hold it all day until it restarts the following morning and then it will shoot the de and all other debris out. It is a 24ft roung above ground pool in southern california.
  • drnow May 11, 2010
    did it ever work correctly?
  • 366 Answers
Chances are you have a torn grid inside, sometimes debris will cover the tear while it's running, then when the pump shuts off the debris settles to the bottom of the tank. Then when the pump turns back on, it shoots DE and debris through the tear until something else plugs it. Tear the filter down and inspect the grids, replace as necessary.
Posted on Nov 19, 2009
Will a tyni tear in one of the grids let the de powder back in the piool
yes, you can replace the single grid or all of them if it's more than a couple of years old.
Aug 12, 2010 | Hayward 48 Sq Ft Pro Grid Vertical Grid De...
I'm getting DE back in my pool from the 4820 filter
One of two things can cause this. Either the spider gasket is bad or there is a rip or tear in one or more of the filter grids.
P.S.
(the spider gasket is inside the valve you turn to backwash filter)
Mar 25, 2010 | Hayward 48 Sq Ft Pro Grid Vertical Grid De...
De powder coming back into pool water from filter
make sure your grids are properly seated and if you have a multiport valve, take it apart and make certain your spider gasket is in place and not distorted. That is the only other reason DE would return into the pool. If you have a slide valve, make sure your o-rings inside are in good condition and properly lubed.
Nov 01, 2009 | Hayward 48 Sq Ft Pro Grid Vertical Grid De...
Collection grid
You can purchase a new collection grid on ebay.
Jun 25, 2009 | Sharper Image Professional Plus Ionic...
Need to reassemble the D.E. filter
All D.E. filters are basically the same. There are two plastic manifolds. One attaches to the bottom of tank by threads or bolts. The other plastic manifold goes on top, and ussually has small holes in this manifold for stainless rods to run through.All fabic looking materials(grids) run between bottom manifold, and top manifold.All grids must be washed free ofD.E.(diatomacus earth). Place bottom manifold on solid ground and begin plugging grids into large holes in manifold so they form a circle, this sometimes takes two people. Place top manifold on other end of grids in a simular fashion.Gently turn assembled filter to its side while holding together, and run ss rods through small
holes in bottom manifold, i n between grids , and through small holes in top manifold. Secure rods with ss washer and nuts, until snug but not overtightened.
Feb 15, 2009 | Jacuzzi Pool & Spa
Hoover Windtunnel
Either the hose has a clog, or the inlet down by the belt is clogged. Is there suction at the end of the hose, if not then it is clogged. If there is suction, then it has to be clogged down below by the brush roll, check that inlet. There also is a filter at the bottom where the dirt cup (and bag) is, check it also.
Dec 28, 2007 | Vacuums
Hayward 48 Sq Ft Pro Grid Vertical Grid De Pool Filter  Logo
287 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
