Question about Fitness Quest Eclipse 1100 Hr/A Elliptical
The handles keeping on falling off, seems that the
The handles keep on falling off which make the machine unusable, seems that the cap is no longer secure which makes the hand move out of position
  • 10,865 Answers
Hello. If the cap is no longer secure, and you can see no screw or other mechanical way to fasten it you could consider using a clear one minute epoxy adhesive available at any hardware store or home depot. On the other hand, if this machine is fairly new and possibly under warranty you should contact the company using one of the following methods:
New Balance 9.5e Customer Service Department 1400 Raff Road SW, Canton OH 44750-0001 1-800-292-5009, Monday through Friday 9:00am to 5:00pm, Eastern Standard Time email: customersupport@newbalancefitness.com www.newbalancefitness.com
Posted on Nov 16, 2009
Cannot secure the handle on my left/right handle,falls out cannot see
all I know of screw in from either direction . and you might not be tightening it up when inserting it .
Jun 27, 2016 | Sport & Outdoor - Others
How to keep center wheel cap on 2004 f150 from falling off
Those are a tight fitting plastic snap in unit...
If they are falling out the CENTER CAPs need to be replaced. To be replaced properly on the vehicle... they need to be aligned... and snapped into place... The popular approach was to hit them on... if they didn't snap in...
HIT THEM HARDER... (wrong)
http://www.yourcaliforniaford.com/
Feb 10, 2016 | 2004 Ford F150
Handle dome keeps coming off
Sounds like the setscrew that holds it on has either worked lose and is missing or is striped and no longer tightens properly. Replace set screw if missing and or replace set screw if the set screw is striped. If the threads are stripped in the faucet body the faucet itself will need to be replaced. This usually does not fall under Moen's warranty guidlines.
Mar 29, 2014 | Moen 7594EC Arbor Single Handle/Hole...
Top tray wheels keep falling off
I feel for you! I have been tortured by the blasted wheels falling off every time I go to put something into the dishwasher, or want to empty it. To add to it all, this part is no longer available to replace, which I need to do as one of the clips finally snapped off. It is a highly frustrating design flaw in this machine.
Feb 25, 2014 | Baumatic 23 in. BDW5 Built-in Dishwasher
Sewing machine design
It sounds like the spool cap is broken or defective. It should fit snugly on the spool pin. If it is constantly falling off, then try finding a replacement. The horizontal spool pin design helps the machine pull the thread off the spool because the thread spool does not need to spin. The added pressure of spinning a thread spool contributes to tension issues (especially if you are using large thread spools that are so common now days).
On new machines, frequently the thread cutter is on the back of the presser foot lifter.
The thread guide above the needle is usually threaded from the left side because the thread tends to be pulled toward the right.
Unfortunately, what you are experiencing are pretty much common functions with most newer sewing machines, so even changing machines may not result in any greater degree of satisfaction.
Mar 31, 2017 | Singer Sewing Machines
Garmin Nuvi 360 says memory full cant reset
Connect the unit up to a PC and try deleting some of the unused text-to- speech (TTS) voices. Keep only the ones that you need. Delete any unused photos or MP3's...and also any unused vehicle icons on the unit. When the unit is booting, it loads in all of the vehicle icons allowing you to change the selected vehicle, so this too uses up valuable memory.
Apr 08, 2013 | Garmin NUVI 360 GPS Receiver
Handle keeps wont stay up, keeps turning off.
Yes you can repair this. Sounds like the valve springs and the rubber valve seats may be worn. There are repair kits available at Lowe's, Home Depot, Wal-Mart, ect. for these faucets. And they usually come with the "tool" you need to remove the faucet handle and the cap and seal nut. After that, it's pretty straightforward, and easy. Two springs, two seats, and an O ring or two, and your'e done. Just make sure to shut off the supply lines to the sink before you start and open the faucet handle to remove any pressure left after you cut the water off. Tighten the cap or seal nut securely after the new springs and seats are in, and you should be good to go.
Sep 26, 2009 | Price Pfister Genesis Luxury Kitchen...
Pinzon 5-9-Inch Pasta Maker handle problem
This is a common problem, it happens to every one that use the machine, I thinks this is a fair trade off for the great price this machine costs.
Jul 16, 2009 | Pinzon Pasta Maker
Agitator keeps falling off
Put a little blue loctite on it.
Oct 20, 2006 | Maytag PAV2300 Top Load Washer
Fitness Quest Eclipse 1100 Hr/A Elliptical Logo
314 people viewed this question
Top Fitness Quest Sport & Outdoor - Others Experts
Joseph Mueller
Joseph Mueller
Tom Chichester
micky koren
Level 1 Expert
Are you a Fitness Quest Sport and Outdoor - Other Expert? Answer questions, earn points and help others
