Question about Logitech Audio Players & Recorders
I have bought a logitech z-5500 and was wondering how i can connect it to my xbox 360 to get 5.1? I only get 2 speakers when i connect using optical... why is that? i read i will need this connector: http://www.amazon.com/Console-Adapter-Convert-Plugs-Single/dp/B0006U3ACY is that true?
  • 6 more comments
  • ole_k_tynset Nov 16, 2009
    well im not sure if i can connect those RCA connectors on the component cable becose i only have coax,optical, and 3x 3.55mm outputs on my logitech z-5500.. + headset and mp3 or w/e
    ty, and it seems like ppl are just guessing i mean why cant i use optical, or coax.. why is there only support for 2 speakers with optical..
  • ole_k_tynset Nov 17, 2009
    so component cable into the stereo 1-3 on the z5500, and from the tv/tuner a hdmi cabel? wat:P
    how can i connect hdmi on z5500 hm im starting to think z5500 is ONLY FOR COMPUTER ^^
    or maybe you mean using hdmi on my xbox and then into the tuner/TV
    ok so if i also connect my TV like you say with hdmi out to the tv/tuner? but what will be the input on the z5500
    ok i have a few questions then...
    i dont even know what digital and analog means i know its how information is sent but perfomance wise i dont know whats diffrent.. i assume digital is better but exactly how do oyu get digital.. only through optical cable or something? or does it depend on youre amp/receiver what signal you can get.
    ok thanx. could you also clearify a bit about (copyed from logitech specs.. something about decoders) Dolby Pro Logic II, DTS 96/24, Dolby Digital. what is that..
    good
  • 19,396 Answers
Hi.
That connector is used to convert the RCA cables out to an 1/8 apple Ipod connector.
I think it is only used to connect an Ipod to your console.
To get 5.1 you need to connect to a surround system, to connect you can useone of the following cables:
• Xbox 360 Component HD AV Cable • VGA HD AV cable • S-video AV cable
The best choice is probably using component cables.
After connecting configure following instructions here: How to configure analog or digital audio settings on your Xbox 360
Posted on Nov 16, 2009
  • 3 more comments
  • Ginko
    Ginko Nov 16, 2009
    Hi.
    I will have a look into the logitech z-5500 backpanel, but first I have to go offline for some time.
    I will post back in about a couple of hours.
    Thanks.
  • Ginko
    Ginko Nov 16, 2009
    Hi.
    Try this:
    Connect XBox to z-5500 using component cable (blue, gr, red).
    Connect z-5500 to TV using HDMI out (or Scart on older TV).
    That should allow to have 5.1 surround and HD video at same time.
  • Ginko
    Ginko Nov 17, 2009
    Hi.
    The problem on Xbox is that surround audio and video are carried on the same cable.
    You need to use component cable into the stereo 1-3 on the z5500, and from the z5500 HDMI out to TV/receiver input a hdmi cable , that will carry video.
    The only problem would be if z5500 does not carry video out. In that case you connect XB0x to the receiver, and audio out from receiver to z5500. Or XBox to TV, and optical or analog audio out from TV to z5500.
    Regards.
  • Ginko
    Ginko Nov 17, 2009
    Hi, sorry , I was confusing with a different unit. We answer many questions.
    Your unit has only 6 channel (the three jacks), and coax digital audio or opt. digital audio.
    Using the adapter you bought you will get sound, but it will not be surround, it will just be like connecting a regular analog stereo out to 5.1 speakers.
    You can try it and see if you like the result.
    It won't be better than using optical out.
    You will have to connect the Xbox to a receiver, then get output to receiver .
    Other solution is using audio out from TV to surround, and connecting XBox output to TV.
    The only spare audio out from XBox, not carrying video along, is the optical digital audio (stereo) and the analog red white (RCA cables)
    Use either optical out or the adapter you bought on the surround system and check the result.
  • Ginko
    Ginko Nov 17, 2009
    Digital is not "better" than analog, it is a different thing.
    An analog signal is continuous, while a digital signal is sampled and coded in bits and bytes.
    To make an example, the sound you read using a deck on a vynil disk is analog, it is given by tip running on the disk surface and generating an continuous electiric inpulse.
    Sound from a cd is digital. This is given by an analog sound sampled in bits that represent 0/1 codes. The digital sound is then put together by a computer that will sand again an analog signal to speakers (passive speakers are always analog).
    The 5.1 will manage better a digital audio, but you do not have much connector options on this unit.
    The choices are connecting through optical stereo in, or using the adapter to connect a regular 2xaudio channels from Xbox to a 5.1 connector. That will be distributed onto the 5.1 speakers, but won't be true native surround from XBox, you can get that only using component or HDMI, and with this surround system this is not possible because of panel limitations.
    Try using your adapter and compare with sound from optical out. Keep the best configuration. The only other option is passing the signal through a receiver, or buying a bigger surround system.
    Sound will still be good in both connections (digital optical, or analog with adapter).
I don't have a sound card.but how can i connect logitech Z-5500 speakers to my pc
Since Logitec Z-5500 is a 5.1 Speaker System you need to purchase a Sound Card to be able to connect it with your pc. You can get a Sound card starting with a price tag of 20 Pounds.
Hope this will help you solve your problem Best Regards NextDoorNerd
Jul 28, 2010 | Logitech Z-5500 Computer Speakers
Logitech Z-5500, no sound out of speakers
Hi there bud , There could be a number of problems as it is a refurbished Speaker Set ,It could be The Subwoofer yes , Have you tried it on other PC's? if it does the same then it is The SPeakers that are faulty :(
Hope this helps
Happy new year :)
Jan 06, 2010 | Logitech Z-5500 Computer Speakers
Logitech harmony xbox 360 remote not communicating with 360.
There is a setting that may need to be changed within the Xbox 360, to allow it to be controlled by a Harmony Advanced Universal Remote.
To configure your Xbox 360 to respond to a Harmony Remote
  1. Using your original Xbox 360 controller, go into the Xbox Dashboard on the Xbox menu
  2. Select "Console Settings"
  3. Select "Remote Control"
  4. If "All channels" is selected, select "Xbox 360 Media Remote”. If "Xbox 360 Media Remote" is selected, then select "All channels"
Your Harmony remote should now control your Xbox 360
Oct 20, 2009 | Logitech Harmony 360 LCD Remote Control
How can I connect my logitech Z 5500 to a sony bravia KDL-32U3000
You can buy a Digital Coax audio cable from any electronic store, this will be a single cable that will connect from your z-5500 to your TV.
Oct 11, 2009 | Logitech Z-5500 Computer Speakers
Not getting true surround sound
The only way to get Dolby 5.1 audio out of the Xbox will be via fiber optic cable from the Xbox to a Dolby Digital amplifier - which will output a decoded 5.1 signal to a 6 channel amplifier and 5 speakers and one sub-woofer. I doubt the Logitech speaker system has a Dolby 5.1 decoder built in with the amplifier for under $100, but I can't say for sure. If the Logitech has a an optical (or TOSLink) input, connect it to the Xbox and follow the instructions below.
To configure your audio settings, follow these steps:
  1. Start the Xbox 360 console without a disc in the disc tray.
  2. In the System section of the Xbox Dashboard, select Console Settings.
  3. In the Console Settings area, select Audio.
  4. In the Audio Settings area, configure settings for analog output or digital output:
    • Analog output settings:
      • Dolby Pro Logic II: Select this setting for stereo systems or Dolby Pro Logic II-compatible systems.
      • Mono: Select this setting for systems that do not support stereo output. Note If you have connected to Xbox LIVE and downloaded any AutoUpdates, the Mono option will not be available.
    • Digital output settings:
      • Digital Stereo: Select this setting to use digital stereo output.
      • Dolby Digital 5.1: Select this setting to use Dolby Digital output.
      • Enable WMA Pro: Select this setting to enable WMA Pro pass-through if your receiver supports the WMA Pro format.
Note You must use one of the following cables to support digital output:
  • VGA HD AV cable
  • S-video AV cable
  • Advanced SCART AV cable
  • Japanese HDAV D-connector AV cable
Additional info:
http://www.dummies.com/how-to/content/hooking-up-xbox-360-sound.html
Sep 28, 2009 | Audio Players & Recorders
Hook up z-5500 suround to a tv
The Sony has (http://b2b.sony.com/Solutions/product/KDL-46S4100)
Digital Audio Output(s): 1 (Rear) Optical Digital Output
The Logitech speakers have (http://www.logitech.com/index.cfm/speakers_audio/home_pc_speakers/devices/224&cl=GB,EN)
Source Inputs:
Digital optical for DVD or CD players, PlayStation®2, Xbox®**
To do this, you need a Digital optical cable--Search Googe for this: Cables Unlimited Pro A/V Series - Digital Audio Cable (optical) - 6 ft
Should work.
Oct 22, 2008 | Audio Players & Recorders
Lip Sync issues with Logitech Z-5500 and PS3
hello there
First things First:
1) change the digital opt, cable, for another with cooper conduction. **
2) check connection again on low volume.
good luck
Mar 21, 2008 | Logitech Z-5500 Computer Speakers
Not Compatible with Xbox 360 controller
how could you have hooked it up to a 360 controller? this headset is USB.
Dec 21, 2007 | Logitech 250 Headset
Logitech momo with xbox 360
if the wheel has a USB cable it should work just the same
Dec 20, 2007 | Logitech MOMO Force Wheel And Pedals Set
49 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
