Question about Bosch 22 in. SKT5002GB Built-In Dishwasher
Bosch SKT5102 The machine wont stay on. When I push the on/off switch the machine comes on for a split second then goes off. If I hold the switch in then the machine works. I have taken the back off and located the micro switch and note that I can buy a replacement. Do you think that is the problem and will I just be wastin my money on a new switch if not. Thanks
  • 3 Answers
It sounds like the switch but you don't need the bosch one if it is only the micro-switch they are easily available
ger531
Posted on Jan 11, 2008
GE FRONT LOAD FILLS BUT WONT START
the first thing that comes to me is the door switch,if it is faulty the machine will not go any further,try pushing the door a couple of times and see if it will start,if not try holding any two button until you here a beep or for 20 seconds ,or hold and push the stop start button for same,this a reset for any white goods.if this fails please come back to me,adrian....
Jan 16, 2015 | GE GFWH1400DWW Front Load Tumble
5 ton split heat pump
Your low on charge. on your valve there are little tubes that help the 24v coil by pushing pressure against valve. if not enough presser the valve wont shift. put 2 pounds of gas in and see what it dose
Jun 11, 2013 | Heating & Cooling
I have a whirlpool duet gas dryer model ggw9200lw1. when i press the start button it clicks once but wont run.
First, check the door switch. Push and release it by hand and you should hear a click. If no sound, replace the door switch with this part.
If the switch is ok, press the cancel button on the machine. Then do this. press and hold the start button for 2 seconds then release wait 2 seconds and press and hold again for 2 seconds continue this pattern until the dryer goes into test mode. You will see all the lights on the control light up. press each button on the control one at a time 3 times each. (Do not press the cancel button) until the dryer begins to run. When the dryer starts to run then press the cancel button. Then your machine should function properly.
Oct 19, 2012 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Maytag Dryer won't start withouth me turning the drum.
Good day. Ugly problem.
My first choice would have been the motor, but.......
Here is the process, it might help you.
The power to the motor goes first to and thru the door switch. It then returns to the timer.
When the timer is turned to any running position, power leaves the timer where it is split into 2 leads.
One of the power leads goes directly to the centrifugal switch Which is the switch on the motor with all the wires. If you spin the drum, you also spin the motor, and if spun fast enough will close the contacts on the cetrifugal switch, thus sending power to the motor, allowing it to run. I guess you have done that.
The second lead out of the timer goes to the push to start switch, it then leaves and goes to the centrifugal switch but on the power side, so it is directly connected to the main winding in the motor.
That is why when you press the press to start switch, the motor runs, and if held in it will continue to run.
In fact, at this point, the motor had 2 sources of power, either of which can run the motor.
Thus releasing the push to start switch doesn't matter, since it runs off the other source.
Possibilities.
The centrifugal switch is not wired right. Please recheck. (or the motor was bad out of the box. Happens).
The push to start switch is bad, and needs replaced.
Or, the wiring going to or leaving the push to start switch has broken or making a bad connection.
Lastley, I said the power comes out of the timer and splits into 2 circuits. Not always true, in some models the timer sends 2 seperate wires out carrying the power, with the possibility the timer could be bad.
Hope this helps.
and thank for using FixYa
Jan 07, 2010 | Maytag MDE6000 Dryer
Pushing on power button three green lights come on for one secone
click here you would find the details for led codes. you may select any laptop. codes remain the same.
Sep 24, 2009 | Dell Latitude D600 Notebook
My alpine car cd player wont stay on....
There is a Title button (above the volume knob). Push it and hold it for 2 or 3 seconds. It was either that, or push and hold the 'Function" button on the glide bar... pretty sure it was the title button though. It will come back on.
Apr 07, 2009 | Alpine CDA-9855 CD, WMA, MP3 Player
Power wont stay on, switches automatically off.
replace the power suply unit the 5v stand by is not working
if youhave good hands buy a 5 volt power supply and connect it to the same output (but remember to remove the transformer for that power )
check it with a dvm
hope i helped
Mar 12, 2009 | Televison & Video
Wont power up
Sounds like someone has spelt water or something on the laptop. Don't keep trying to start it and remove the Battary and take it to you computer service agent to have a look.
Other easy things to look at first would be to remove any USB items connected, test your power pack and make sure it working.
Feb 20, 2009 | HP Compaq nc6320 Notebook
Control lock light stays on.
Carefully and slowly look for a button, I dont remember which, but there is a button that duels as a child lock if held for three seconds, find this and hold for three seconds to fix:)
Sep 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Bosch 22 in. SKT5002GB Built-In Dishwasher Logo
200 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
