Question about Guardian Rv Generator 4800 Watt, Gasoline, Primepact 50G
Generator starts with and runs great, but theres no current on my toy hauler
  • 776 Answers
Johnny,
If generators are not used regularly, they need the their magnetic field to be charged (or flashed). This can be done by plugging an electric motor into the socket while the generator is running and spin the motor by hand. The hand-spun motor will push some electric current back into the generator and magnetize it enough to start it.
Look in the manual. There is likely something about field flashing the magnetic fieldgenerator starts with and runs great, but theres - 2.gif. The easiest way to do this is to.
1) start the generator
2) plug an electric drill into the generator (without drill bit)
3) make sure drill is set to forward direction (if a reversable drill.
4) pull the trigger on the drill.
5) If the drill does not start, spin the drill's chuck clockwise (When looking down at the chuck from the drill bit end). Spin counter-clockwise if holding it like a pistol and pointing away from yourself.
6) Do this several times (hard) until the the generator will kick in and suddenly make the drill spin at full speed.
Be careful not to drop the drill or poke someone with it as you celebrate success.
Posted on Nov 18, 2009
I have a toy hauler with a generac generator propane that wont start getting gas and spark but wont start model 04164-0
Check the comprssion, if you are sure you have a spark and gas. Is the fuel been delivered to the cylinders? Check the fuel solenoid for power, if power is present the demand gas regulator maybe gummed up. LP companies put a waxy lubricant in the gas and over time this can build up and harden in regulators. Also during crank observe the throttle is it going open as it should? if not suspect a control issue
Oct 17, 2013 | Generac 40 Kw Natural Gas/propane...
Hello all, I just bought a Little tiles haul and ride (612442). While assembling, the part F was latched on to part B (by mistake) before I could put in the parts D and E. So I now basically have part B...
What I know of Little Tikes is that they are snapped on to complete the a toy. They don't make any permanent attachments to easily assemble and disassemble them. If you're having a hart time removing that part, I suggest you bring it back to the toy store where you bought it and maybe they have a personnel there who can help you.
Oct 07, 2013 | Little Tikes Handle Haulers Haul and Ride
I have a toy hauler with a 5500 guardian gen. It runs but recently it won't supply any 110 power to any of the electrical items in the camper.
there could be a couple of things wroung the breaker tripped have to reset the breaker the plug in went bad a wire came off or broke or the doid blew out you will need a meter to get in and check these out to see if any of these are bad most of the time it is a bad breaker that could be esily fixed or wire to the plug in either way they are pretty easy to fix.good luck
Aug 03, 2011 | Generac Guardian Electrical Supplies
Honda ems 4000 generator starts and runs great, but no power
The plunger is stuck where the governor rod which is spring attached to the frame is. If you locate the governor metal rod on the lower level of the unit. zrock it to a higher rpm as you would a car carburator from under the hood.
This will free the plunger and the green light will go on and your current meter will register 120 volts.
When you lay up the generator for quite some time it often sticks closed. With monthly start up you will no have this problem reoccurr.
May 13, 2010 | Cars & Trucks
Onan generator not running
recheck, reclean,and rebuild carb possible had moisture in fuel and carb --white smoke--but sounds like float and carb still gummed up
Feb 15, 2010 | Watts Onan Portable Generator - 4000 ,...
Onan generator 2005 model hgjab-1038c rv generator will not keep batterys charged have to hook battery charger every time that generator is not running what should i check for this genator is in my 2005...
Go to the auto parts store and buy a "Battery Tender" solar powered, or get an electric trickle charger. Or install a battery disconnect for the period the unit is not in use; you can disconnect the battery.
HTH,
Mike...
Dec 02, 2009 | Watts Onan Portable Generator - 5000 ,...
What is the oil filter for onan4000 generator
yes--- where is the oil filter on a onan 4000 in toy hauler?
Jul 12, 2009 | Watts Onan Portable Generator - 4000 ,...
Trans slip when pulling toy hauler
Heat is killing your transmission. Change the transmission oil and filter and slow down. Pulling something that heavy is best with a manual transmission.
Jun 15, 2009 | RTO Automatic Transmission And Engine Oil...
Oil type for Onan 4000 generator
SAE 15W-40 is what i used to use
synthetic? not sure about that one there may be oil pres switch that could give you a problem.
Apr 04, 2009 | Watts Onan Portable Generator - 4000 ,...
Guardian Rv Generator 4800 Watt, Gasoline, Primepact 50G Logo
483 people viewed this question
Top Guardian Electrical Supplies Experts
 Kenneth
Kenneth
Roland W VanLue
Roland W VanLue
Are you a Guardian Electrical Supply Expert? Answer questions, earn points and help others
