Question about Optics
Redfeild scopes out of focus
    Scholar:
  • 190 Answers
Turn the back lens holder screw it in or out till it get in focus most people don't know that there supposed to focus there scope or how to do it and most scopes are good enough but they can be made better by adjusting them to your eye
Posted on Nov 21, 2009
I have a Simmons Model ATV 4515 rifle scope. other
Your scope has 5 adjustments:
1. Eye piece focus - used to focus on the reticle.
2. windage adjustment - should be on the R side of the scope, adjusts lateral impact point.
3. Vertical adjustment - the top turret. Adjusts vertical point of impact.
4. Power ring - adjusts the magnification of the scope.
5. AO ring - Parralax adjustment - used to focus the scope at specific distances. Most markings are not exact, you should set it at the range you are shooting and fine tune focus when you look through the scope.
Sep 06, 2013 | Optics
Scope is out of focus
You focus on the reticle with the eye focus ring. You need a parallax adjustment ring to "focus" a scope. Your scope does not have this feature. Are you trying to use it at a very short distance?
Mar 30, 2013 | Weaver K4 4X38 Riflescope
Here?s my problem : My scope model is LX200R 14?. I?ve pulled the focuser shaft out of the focuser arm pin. I?ve turned the locking lock knob several turns before putting back the focuser shaft. I...
Steward, this is Joe Lalumia-- I have seen your post on various forums. The 14 inch is different from the other smaller LX200 scopes.
Probably Dr. Clay, and or Andrew on the Yahoo Group LX200 forum will know the answer because they service these scopes.
Post a message there (register for free) and one of them will answer you about that very nice scope.
Clear Skies!
Joe
Dec 14, 2010 | Meade LX200R 14 in. Telescope
Why do i see a blury target when i look thu the scope with myglasses and it is clear without them
Because your glasses (prescription or reading) are configured to correct your "far" sighted vision deficiency. Even though the scope is located at a very close distance to your eye, the point your scope is focusing to/at is many? yards in the distance. If you're like many of us, you can see satisfactorily at a distance, but your arms aren't long enough to allow you to read a magazine?
Nov 03, 2010 | Nikon Optics
Very blury above 10 x no mater how i ajust it and hard to veiw target nikon 8426 6- 24x50 bdc brand new
If you are trying to focus at a relatively close distance, you may be overpowering the scopes ability to focus at that distance. Most rifle scopes are set to parralax free at 100 yards.You can see this effect by putting the scope on its lowest power, focusing at 25-50 yards, and then increasing the power setting. You will see the image go out of focus as the power increases. This simply means that you must shoot at longer distances in order to use the scope to its full potential.
The other problem may be your parallax adjustment, but you may have already tried that solution.If not, make sure that the adjustment dial is set at the distance you are trying to shoot (minor adjustment from the indicated setting may be required to fine tune the image).
Oct 22, 2010 | Nikon 8426 6-24x50 Monarch Side Focus...
Loss of focus when izoom in
This typically means that you are have exceeded the scopes ability to focus at the distance that you are shooting. This scope is optimized for 50 yards and will function well at all magnification settings. Closer than this optimal distance the higher magnifications may present problems with blurring. Many scopes have a "parallax" adjustment that changes the optical focus to correct this problem. Several of my 22 mag scopes have this adjustment on the objective bell. You simply set the indicator line on the appropriate yardage indicator (making minor adjustments to fine tune focus). Hope this helps
Sep 16, 2010 | Simmons 22 Mag 39X32 with Rings
I need to adjust the focus of my Redfield widefield scope, by focusing the ret field scope does it change the accuracy of the optics?
no it dont,,, it makes it even more accurate,, how can you see clearly if its out of focuse,,,,,
Nov 17, 2009 | Optics
How to use accutrac 2x7 redfeild scope , there are lines above the crosshairs and a yardage graph on the bottom of the crosshairs, how exactly do i use this scope
Looking for instructions on the use of an Acu-trac rifle scope by Redfield. There are lines above the crosshairs and a yardage graph on the bottom of the crosshairs.
Oct 07, 2009 | Redfield Optics
Inoperative focus control
I'm assuming this is the Maksukov-Cassegrain telescope. Turning the focus knob CW should get you focus at infinity by moving the primary mirror away from the eyepiece. As you turn the knob it should move in and out relative to the real of the scope. If that's not happening the focus screw may have been turned CW too far and no longer be catching the threads in the rear plate of the scope.
You may be able to get it to rethread by holding the front of the scope toward the ceiling and turning the knob CCW. Attached is a photo of what the scope looks like under the rear housing. To prevent the focuer shaft from turning in too far the knob should be firmly seated agains the rear of the shaft. I think on this model this is a friction fit.
HTH, George
Jan 23, 2008 | Optics
Tasco propoint PDP2 scope
Are you looking set the eye relief or the focus ring?
For eye relief you need to loosen the scope in the rings, mount the rifle to your shoulder with your standard hold and cheek weld. At this point, slide the scope back and forth in the rings until you obtain a full field of view. Tighten one of the rings slightly, dismount and remount the rifle several times to ensure correct adjustment. Level scope and tighten rings a final time.
For focus adjustment (remember that you are using the eyepiece to focus on the cross hair, not your target!) loosen the lock ring and turn the eyepiece until the cross hair is focused. It is best if you check it several times by closing and opening your eye several times. The crosshair should be instantly in focus. If your eye must adjust, then you need to refocus until the focus is instant.
The two dials on the scope are for adjusting the bullet point of impact. They will typically move POI 1/4 inch at 100 yards.
Nov 08, 2007 | Optics
Optics Logo
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Optic Expert? Answer questions, earn points and help others
