Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
Broken cog on compressor motor 919.166440
I was replacing the motor on my craftsman compressor 919.166440 and the cog on the motor shaft broke. where can i get a replacement cog?
  • 530 Answers
Below is a link where they have a variety of parts for smaller craftsman compressors.
I didn't see an exact match for your model however I think if you contact them they will probably be able to help you out. I'm sure that motor/pump model was used on several different models.
Hope it helps.
http://www.mastertoolrepair.com/craftsman-sears-parts-portable-compressors-c-271_535_537.html
Posted on Nov 16, 2009
Electric clutch assemble fell off, broke shaft and cut wires.
Your shaft broke ?going to the engine? crankshaft? Thats strange never seen that before usually keyway is built into clutch.If this is what you describe you need a new crankshaft in your motor. Will probably be expensive.
Aug 01, 2012 | Craftsman 24 Hp 48" Deck Yard Tractor
Replacing a the belt on a portable air compressor - craftsman
hi mate if the pump is connected then it doesnt have a belt its direct drive and if the motor is seperate from the pump unit then it belt driven i dont understand as the picture is a direct drive (no belt)
Aug 23, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Broken pull cord
ur going to have to unmount the the motor from the shaft
step 1. Unbolt throttle housing
step 2. now with that out of the way u should see a clamp holding the motor to the shaft, loosen and pull the shaft out, there will be a cable, so make sure u have it lined up so it goes back into place
step 3, look at the back of the motor, u should see screws going into the plastic housing (coming in from back going into plastic)
step 4. once that is off pull the broken part of the cord out
step 5. wind up the starter coil, (it will only wind up one way) its spring loaded so be carful, once it stops back it off 1 full turn
step 6. u will see a hole for the cord in the housing and in the coil, make sure they are lined up
step 7. insert the cord through both holes, tie it as tighttttt as possible, then let the spring do the rest
step 8. put it back together
May 30, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman air compressor bearing flywheel
Your local hardware store should have one. The model number will probably not help; you will need to measure the keyway width and height to buy key stock of those dimensions then cut off the length you need.
Hope this helps.
May 21, 2009 | Craftsman Air Tools & Compressors
Broken connecting rod
i broke the rod in my air compressor and cant find a place to buy a new one it is a pro source
Nov 10, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Sears Craftsman 3-Gallon, 1.5 HP Air Compressor Hums
YES IT MAY BE THE CAPACITOR . IT COULD ALSO BE THE WIREING IN THE MTR, THE PUNP ITSELF.
Broken belt how to fix i have a belt
Take off belt cover on the left side of the top cover, turn cleaner over, take out screw from red lock and remove, pull cap and brush roll out, unhook the cogged belt, then you can replace the pump belt thru that opening. Put belt over the pump pulley and stretched to go over the motor shaft. Then check the cogged belt and the cogged end of the pully to make sure that there are cogs, replace belt if there are cogss missing or belt is broke, if no cogs on the pulley, then you will have to replace the pump. Pulley only comes witht he pump.
Jul 29, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell Proheat Shampooer
Jul 03, 2008 | Bissell 1699 ProHeat Clear View Upright...
How to check the location of the pump belt?
Jun 30, 2008 | Bissell 1699 ProHeat Clear View Upright...
How do you replace the belt? I took off the door and there seems to be no easy way to get it over the lower red wheel.
Mar 26, 2008 | Vacuums
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
244 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Joe Garcia
Joe Garcia
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
