Question about HP LaserJet 9040mfp All-In-One Printer
HP LaserJet 9040mfp All-In-One... Problem
We can't get the printer to print out of tray 2, our executive sized paper. It keeps defaulting to tray 4, our letter sized paper.
  • SusanK5 Jan 09, 2008
    Hi, I realize we are actually trying to "copy" rather than print. We are trying to copy a number of pages of a book. We have been able to use the menu -> configure device -> originals -> paper size-> executive. We lay the book on the glass, then press the start button twice. We are able to force the printer to print from Tray 2 this way. However, the setting doesn't hold, so that to copy another set of pages, we have to go through the sequence above again. Is there a way to get the settings to hold? Thanks, Susan
If want to take 3 pages print in same doc but printer fire continue the 1st pages not 1 next 2, next 3 by serialy
Posted on Sep 04, 2008
    President:
  • 4,402 Answers
You first need to run a configuratin page from the infromation menu on the printer. It will tell you what size and type paper the printer thinks is in tray 2. If that does not match what is actually in the tray (size) then you may have a issue with the paper size switches on the right inside cavity of the paper tray. If the switches, there is a samll pca board behind the black cover with the 3 metal springs. That board is the same for both trays 2 and 3 so you could switch the boards to see if that is the issue. It could also be as simple as the paper tray bar not aligned correctly and the easy way is to switch trays 2 and 3 and see what happens. The type setting which is inputed at the printer if not matching the job will cause the paper to not be drawn unless that type is asked for. Example if someone changed the type to preprinted and you do not ask for preprinted it will never draw from that tray. Hope this helps.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=e
n&cc=us&objectID=bpl12037
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en
&cc=us&objectID=bpl10241&prodTypeId=18972&prodSeriesId=1845551
If tray 2 & 3 have same size/type, will pull paper from 3 until empty. Make sure that the tray selection (or paper type) in the printer driver or software application is set correctly. (The printer driver and software application settings override the printer control panel settings.)
Posted on Jan 09, 2008
  • Cary Farah
    Cary Farah Jan 10, 2008
    pull the other trays out and leave tray 2 in
How do I change the default on my HP P30005dn to Tray 2?
Normal default on HP is tray 2, however if you do not have that tray set for plain paper letter size the printer will default to whichever tray has letter plain paper installed. You should also check your print driver default settings to ensure that tray 2 is set as default tray.
Aug 14, 2014 | HP LaserJet P3005dn Printer
My HP 4100N printer often automatically selects to print from tray 1 (the manual feed), when I want to print from tray 2 (the automatic feed). How do I set the default tray?
HP Laser Jet 4100 HP Not pulling paper from Tray 2
Action: The 4100 will look at tray 1 first then tray 2 If tray 1 is empty it will pull from tray 2 if the papersize matches the job otherwise back to tray 1 and ask for the paper. Your machine likely thinks the paper in tray 2 is not the size you want. For instance you have LETTER in tray2 But the machine thinks it is legal. The LJ 4100 detects the paper size in tray 2 automatically. If you print a configuration page: MENU them INFORMATION then ITEM then CONFIGURATION PAGE then SELECT. The page will print and show what size paper the machine thinks is in Tray 2 if it says LEGAL and you have LETTER you need to Check The Paper Backstop in TRAY 2. The back stop sets the length of the paper if it is not at Letter (8 1/2 x 11) the machine will not detect LETTER. Even if it just a little bit off or between positions.
If it is set at LETTER then you may have bad switches in the machine that are operated by the tray. Or the arms on the tray that operate the switches are not moving properly. You will find the arms on the rt, side of the tray and feel them change position when you move the backstop.
Hope this helps helps. Please keep us updated and remember to rate this answer. TF
Oct 18, 2010 | HP LaserJet 4100n Printer
Colour laserjet HP cp2025 keeps going into cleaning mode - why ?
Re: CP2025 cleaning at every possible moment Talked to HP support and fixed mine by changing Settings/Paper Handling/Tray 2 Type to "Heavy 111-130g"
All paper handling settings as follows:
Default Paper Size: Letter
Default Paper Type: Plain
Manual Feed: Off Duplex: Off Bind: Long Edge
Tray 1 Size: Any size Tray 1 Type: Any Type Tray 2 Size: Letter Tray 2 Type: Heavy 111-130g
Paper Out Handling
Specify Time and Action Paper Out Time: 0 Seconds
Paper Out Action:
Override
Apr 17, 2010 | HP Color LaserJet 2600n Printer
THE PRINT FROM MY LEXMARK PRINTER IS SMALL AND I CANNOT ADJUST THIS. CAN YOU HELP PLEASE
Your printer supports a wide variety of paper sizes. See Media guidelines for illustrations of proper paper orientation. The printer determines the size paper loaded in the trays by the position of the paper guides. Make sure you adjust the guides each time you change paper sizesYour printer can automatically sense when A4, letter, legal, executive media or B5, DL, and #10 envelopes are loaded in tray1. To do this, the Auto Size Sense setting must be set to On. Your printer default was set at the factory to either the US or Non-US default with the Auto Size Sense setting On.To change the Auto Size Sense setting to Off: 1 Turn the printer off. 2 Press and hold the Go and Stop buttons and turn the printer on. 3 Release both buttons when Performing Self Test appears. 4 Press Menu> or <Menu, until the Tray 1 Auto Size message appears. 5 Press Select. 6 Press Menu> or <Menu, until Off appears on the display. 7 Press Select. To return the Auto Size Sense setting to On, repeat steps 1 through 7 but, select On during step 6.
Sep 03, 2009 | Lexmark P4350 All-In-One InkJet Printer
Pc load letter
Hi there this issue is caused by your driver defaulting to letter and a4 paper being used set your default paper size to a4 in the driver and also set tray to a4 this should cure the problem Regards AL "alstech"
May 28, 2009 | HP LaserJet 4 plus Printer
Want to print on legal size paper from Tray 1 (top) as default
print menu - config and verify paper is being sensed correctly. If paper size in tray is not set correctly printer will ask where to print from
Feb 12, 2009 | Lexmark T640 Laser Printer
Paper tray?
Two possible solutions;
1) Check the settings in the printer driver for the default tray. The other user could very well have changed them and set tray 1 as the default tray.
2) Check the paper size settings in the paper tray. Pull tray 2 out and check the paper guides. Make sure the paper guide in the front and left of the paper tray are set for the correct media type (letter, legal, etc.)
The printer reads the tabs in the back of the papertray to identify the paper size. If someone moved it while loading paper the printer identifies another paper size and defaults into the tray that has the size of paper required to print.
Hope this solves your problem.
Nov 19, 2008 | HP LaserJet 4100n Printer
Tray 1- load plain letter
Linda,
On printer check media/paper type tray 2 or 3 is plain and tray 2/3 is set for letter paper size too, via printer control panel. Also check under paper handling other options for tray 1, also on tray 2 and 3, I think there is a blue little round switch on left should be set as letter not custom.
Some paper types cannot be feed from anywhere else but tray1/bypass ie labels/laminate/card stock.
Check print driver on pc has tray 3 option installed and is not set as default to print to manual bypass/tray 1
light flashing cause printer wants paper type/size that it "thinks" it hasn't got in tray 2/3
If that dont cover it...post back
Soulvisitor :-)
Dec 18, 2007 | HP LaserJet 4100n Printer
Keep getting "11 load letter in tray 1" message
Are the print jobs being sent to printer all the same page size?
Are they all print jobs sent letter page size and your printers cassettes are set for A4 or something?
Your printer is asking for letter size paper, because any paper it has is not set to letter  and document that it is trying to print has been sent as that size.
Check what options you have on print driver on pc as far as Tray defaults, paper type and size settings
Check printer settings via its keypad as to tray defaults, paper size set for each tray and paper type, some printers have paper size switchs on their trays too.
Oct 26, 2007 | IBM Network Printer 12 Laser
HP LaserJet 9040mfp All-In-One Printer Logo
236 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
