Question about Sharp AR-M277 Digital Copier Copier
Banging in lower tray
Green release lever holding the cover over the roller on the right side above the lower tray is dislodged. how do you put it back on
    Problem Solver:
  • 17 Answers
This is a common problem on your model you need a flange and a fuser drive gear. Call a sharp dealership and tell them the problem and solution so they can bring parts. Then you will not need to pay for a second service call. If in New York city or Long Island we can help.
Posted on Nov 21, 2009
Fix paper jam
Sir there showed be two green release levers on each side of the Fusing unit the part that get very hot. THEY mite have been broken off. Get a new fusing unit? or have tech come out and look at.
Feb 08, 2014 | Minolta Di152 Laser Printer
Tip
Layman?s Instructions to replace the transfer belt for a Samsung CLX-6200FX...
Intro: This is a fairly difficult task, so really make sure you want to do this first. Factor in the cost of the transfer belt(maybe $25 dollars off of Ebay??) and it's not such a good deal. Anyway, for the DIYer diehards, keep reading.Necessary equipment:1. Number 2 philips screwdriver and a really small flathead screwdriver2. Disposable gloves3. 12 inch strip of cardboard or plastic4. Vacuum cleaner5. Spring hook removal tool (can made a simple one with a pair of pliers and a paper clip)
Disassembly: 1. Place the transfer belt assembly down on a table, so that the paper belt drive is on your right side. Remove the paper drive belt assembly by removing the three bright screws that hold it in place.
2. Turn the whole thing over and remove the rubber roller at the bottom. This is done by first carefully remove the spring that hold one of the plastic end in place. Choose the end that has the metal grounding tab on it. Be really careful to not damage the plastic tabs that hold the spring ends. The grounding tab must be pulled up slightly in order to go over a plastic nub before you can slide the plastic end off. Don't pull the metal too hard, or it will be permanently deformed. Place these parts to one side. The metal ends of the rubber roller have a little bit of grease on it, so just leave it there.
3. Flip the transfer belt assembly back over and on the right side, there is a protruding piece of plastic that has an electrical connector attached to the end of it. It's held in place by two black screws. Remove those two screws and the assembly will now hang there by the wires.
4. Remove the top plastic piece (covers the green release lever). There are four black screws that hold this in, two screws on each side. The part will dangle because it is connected by the same wires that connect to the piece in step 3.
5. With the removal of the part in step 4, the green release lever assembly is completely exposed. There are two springs (one on each side) that pull the plastic ends of the release assembly to its normal position. These springs need to be carefully removed. The spring hook removal tool is handy here. Finally, there is a holding tab on each of these end pieces, which needs to be carefully pulled up about 2 mm or so and then the end will slide off the metal bar. Don't lift up on the tabs too much or they will break off.
6. There are 4 bright screws that hold the excess toner tank. (This is the big piece of plastic with ribs, that the paper belt drive assembly was attached to. This tank will now come off, since the part in step 4 has been removed. The tank will be full of excess toner, so have the vacuum cleaner handle to clean up the mess. Shake the toner out into a garbage can.
7.
Underneath the excess toner tank is a scraper/cleaner bar. Two bright screws hold the bar in place. Take care to not deform the metal grounding tab that grounds the bar during operation.
8.
Take the left side plastic panel off now. There are 4 black screws that hold it in place. It should come free. If something is holding it in place, then you probably skipped step 5 and didn't remove the green release level assembly yet.
9.
There is a round rod which will come loose as soon as the left side panel is removed. This round bar works with the scraper to clean the excess toner from the transfer belt. Note that one end of the round bar has been machined to have a smaller diameter. That end goes toward the left side plastic panel. Put the round rod aside for now.
10. There are two round rollers on the top and bottom of the transfer belt assembly that are used to stretch the belt. The bigger round roller is spring loaded to provide the tension needed to keep the belt flat during operation. Using a small flathead screwdriver, carefully remove the compression spring (hidden under the left side plastic panel earlier) so as to release the tension from the belt.
11. Put your gloves on now, because in the following steps, foam rollers will be exposed and it's best not to get body oils on them.
12. There is still tension on the belt because there's a compression spring on the other end of the big round roller, but that's okay. Now, press on the plastic end piece that holds onto the roller to completely release all tension on the belt. The belt will now slide off. It won't come off easily since it's a tight fit. Just work at it and it will come out. Note, one side of the belt has a rubber track inside of it. That's the orientation that the new belt must go back in on.
13.
With the old belt removed, the inside of the transfer belt assembly is now completely exposed. Vacuum the excess toner dust.
Reassembly:
14.
Note where the round bar that pressed against the scraper should be. There are pieces of plastic protruding here which will damage the new transfer belt as it is being put into place. Cover these protruding points with a strip of cardboard, 12 inches long and about 1-2inches in width.
15. Now, holding everything in your lap and with the right side down, press on the end piece of the big roller as before, so that it is possible to slide the new belt down into place. Take your time, and it will finally get into place. Try your best to not fold the transfer belt material in any way. You will know the belt is in place when the rubber inside track goes into the groove of the black plastic roller at the near end of the big roller.
16. Put the compression spring that pushed the end of the big roller back into place.
17.
Slide the round bar approximately now where it should go. Remove the protective strip and position and push the bar end into the brass bushing. Remember, the machined end of this round bar should be aligned so that it clears the inner rubber track of the belt. I put a drop of light machine oil on the brass bushing, but I don't know if was really necessary.
18. Carefully put the left side panel back into place, noting that the smaller roller end and the round bar have to aligned properly before the panel will slide into place. Again, I put one drop of light machine oil on each brass bushing just before putting it all together. Four black screws are used to hold the panel in place.
19.
Put the scraper bar back into place using two of the bright screws. Note, the metal tab on one end should be pressing against the bar, making electrical contact when it is in properly.
20. Put the excess toner tank back into place, using4 black screws.
21. Return the green release lever assembly pieces back into place, basically performing the earlier steps in reverse. First position the lever bar in place, then slide the ends back on. The retaining tabs should click and the ends will be locked into place again. Putting the springs back into place is easiest with the help of the hook removal tool.
22.
Thread the top plastic piece back over the green lever. You may need to press on the green lever just a bit to get the piece back in and again to align the screw holes. 4 black screws to hold this top plastic piece.
23. Put the electrical connector piece back into place. Note that it hooks over the side panel piece. Route the wires into the proper place, so as to not smash them as the two black screws are used to reattach this piece.
24. Put the rubber roller back into place. Steps are the exact reverse of what it took to take it off.
25. Finally, fasten the paper belt drive assembly back down with the 3 bright screws. Note,this piece hooks into the top plastic piece before it is screwed down. Use a small flathead screwdriver, as needed,to make sure the grounding tabs are not messed up as the assembly is put back into place.
on Feb 24, 2011 | Samsung CLX-6200FX Printer
The roller in the feeder has come out, I don't know how to put it back in
I am not sure as to which roller you are talking about but please find below the solution. !!!!DO RATE MY SOLUTION!!!Pickup roller replacement
  1. Tip the device over on its rear side, with the top of the device facing you.
  2. Rotate the bushings (callout 1) on each side of the roller upward. c02755446.gif
  3. Remove the left-side bushing by sliding the bushing to the left.
  4. Slide the roller and shaft toward the left until they clear the hole in the right-side bushing, and then lift the right end of the shaft.
  5. Slide the roller and shaft toward the right, and then lift the roller and shaft together out of the device. c02755447.gif -------------------------------------------------------------------------------------------------------------- This is for ADF (Automatic Document Feeder) on top of the printer.
    3. Press the round blue button while lifting the green lever. Rotate the green lever until it stops in the open position. The pickup roller assembly should remain on the surface.c00802892.gif
    4. Remove the assembly, and then wipe the assembly with a soft, dry, lint-free cloth.c00802893.gif
    5. Replace the assembly, with the largest roller down, in the upright holder, and then press until the assembly snaps into place.c00802894.gif
    6. Make sure that both sides of the assembly are secured by the blue hooks.c00802895.gif
    7. Lower the roller assembly, and then close the ADF cover.c00802896.gif NOTE: If jams continue in the ADF, contact a local HP-authorized service provider.
Jun 27, 2011 | HP LaserJet M3027x MFP Printer
I have a paper jam on my very old canon fax machine...Canon Super G3. The paper is held up in the rollers and has torn...how can I release the rollers so that I can get the torn piece of paper...
To remove the paper jam, follow the procedure---
1. Open the front cover.
2. Remove the cartridge.
3. Open the face up cover and push down the green paper release levers on both sides of the face up paper output.
4. Hold sides of the jammed paper and carefully move it inward then gently pull out.
5. Remove if any paper bits present near the rollers.
6. Don?t pull the paper upwards but straight between the rollers.
Please check page#62 for details in the manual---
Canon Super G3 Fax
Apr 01, 2011 | Canon Office Equipment & Supplies
CONSTANTLY HAVE A CARRIAGE JAM.
Hello
Unplug the power cord of the printer and open the cover to reveal the carriage assembly.
Squeeze the two levers beneath the paper tray together to remove the tray.
Slide the carriage assembly from the left side of the printer to the middle where you have easy access to it. If the carriage assembly will not slide.
Push down the large black bar located directly above the rollers and then release it so that it springs back up. Now attempt to slide the carriage assembly to the right again. If it still does not slide.
Locate the flat black component found directly below the rollers in the tray compartment. It should be lying flat, parallel with the base of the printer. If it is pointing upward, push it down.
Slide the carriage assembly over to the right once all of the above parts are in their correct positions.
Lift the actuator arm, which is directly above the white and/or gray gear assembly at the left side of the printer. The actuator arm is thin strip of black plastic that is approximately 1 3/4 inches long and 1/3 inch wide. Lifting it and releasing it should restore it to its proper position.
Put the paper tray back in the printer. With the cover of the printer still open, plug in the power cord and turn on the printer.
Press and hold "Resume," then close the cover of the printer.
THANK YOU FOR VISITING FIXYA
Mar 03, 2011 | HP Photosmart 2575 All-In-One Printer,...
Carriage jam
Hi there
Follow these steps to fix the problem
Slide the carriage assembly from the left side of the printer to the middle where you have easy access to it. If the carriage assembly will not slide, Push down the large black bar located directly above the rollers and then release it so that it springs back up. Now attempt to slide the carriage assembly to the right again. If it still does not slide, Locate the flat black component found directly below the rollers in the tray compartment. It should be lying flat, parallel with the base of the printer. If it is pointing upward, push it down.
Oct 03, 2010 | Office Equipment & Supplies
HP Officejet Pro LP 7880 feeder does not work, how to fix it?
Step one: Check the paper in the ADF The condition of the paper or the amount of paper loaded in the ADF might prevent the ADF from picking it up and feeding it through the product.
  1. Make sure that no more than 50 sheets of paper are in the ADF input tray.
  2. Make sure the original is not photo paper or carbon paper. These types of originals must be loaded on the scanner glass.
  3. Make sure the original document that is loaded in the ADF meets the following criteria:
    • Free from curls, folds, creases, and tears
    • Does not have staples or clips attached
Step two: Make sure the ADF pick assembly is in good working condition
  1. Remove the document feeder and open the ADF cover.
  2. While lifting the blue-green lever, carefully rotate the pick assembly toward the open ADF cover until it stops.
  3. Examine the pick assembly.
    • Make sure the bottom roller is held firmly in place by the two-catch, which is located to the left and the right of the roller.
    • Make sure the stack stopper, which is located between the top and bottom rollers, fits within the double slots just above the bottom roller. The stack stopper should move freely within the double slots to flow up and down when the whole pick assembly is lifted and lowered into position.
  4. Return the pick assembly to its original position.
  5. When the product is turned on, the top roller will reset to its original position above the separator pad. There will be a gap between the separator pad and the top roller.
  6. If there is no gap between the ADF top roller and the separator pad, press the Power button to turn off the product.
  7. Wait three to five seconds and then press the Power button to turn the product on. The ADF rollers should reset to the correct positions.
  8. Close the ADF cover and replace the document feeder.
Step three: Clean the rollers and separator pad
  3. Lightly dampen a clean, lint-free cloth with distilled water, and then squeeze any excess liquid from it.
  4. Use the damp cloth to wipe any residue off the rollers and the separator pad. If the residue does not come off using distilled water, use isopropyl (rubbing) alcohol on the cloth instead.
  5. Return the pick assembly to its original position.
  6. Close the ADF cover and replace the document feeder.
Step four: Detaching and re-attaching the ADF pick roller assembly If the ADF pick assembly is detached or not connected properly, follow the steps below to resolve the issue. If the ADF pick assembly works well, do not perform these steps.
  1. Press the Power button to turn off the All-in-One.
  2. Remove the document feeder and open the ADF cover.
  3. Press the blue-green ADF-release button to release the ADF rollers from the pick assembly as shown in the figure below (the red arrow is pointing to the ADF release button).
  4. Re-attach the ADF pick rollers by placing the rollers into the roller slot of the ADF pick assembly as shown in the figure below. The red arrows show the gears on the ADF pick assembly aligned on one side. The yellow arrows point to the two-catch notch.
  5. Once the rollers are placed on the two-catch notch, push them in, so that the two-catch clicks into place. The photo below shows a correctly installed ADF pick assembly.
  6. Close the ADF assembly and cover.
  7. Turn the product on and make a copy with the ADF to check that the pick assembly works.
Jul 16, 2010 | HP Officejet Pro L7680 All-In-One Printer
Savin Copier 3515
Hmmm.. try this
  1. Open the Front Cover
  2. Lift the large green handle up to its full extent
  3. Press and hold down the green lever to the left of the green handle
  4. Use the green handle to pull out the Toner Tray slightly then release the green lever
  5. Pull out the Toner Tray to its full extent
  6. Push the toner bottle towards the front of the black housing where the green lever is located
  7. Push the green lever down while continuing to hold the toner bottle towards it.
  8. Slide the whole assembly back into the device until it clicks into place
  9. Close the Front Cover
  10. The device should now attempt to Add Toner
  11. If the Add Toner indicator light does not go out repeat
Oct 31, 2008 | Microsoft Office 2003 Basic Edition...
Brother 9420cn message on display transfer roller not installed, appeared during printing session, cannot rectify
Replacing the transfer roller
1 Turn off the machine’s power switch.
2 Open the back cover of the machine.
3 Release the transfer roller lock levers on
the right and left-hand sides, and then lift
the levers to release the transfer roller.
4 Take out the transfer roller by gently
pulling the right-hand side up and sliding
the transfer roller to the right.
5 Put in the new transfer roller by holding
the lock levers of the transfer roller and
adjusting the angle of the transfer roller
lever shafts (both sides) to match the
transfer unit grooves. Put the transfer
roller onto the shafts and place the roller
onto the springs as shown below:
6 Push the lock levers down to lock the
transfer roller into place.
7 Close the back cover.
8 Turn the machine’s power switch back
on.
Apr 30, 2008 | Office Equipment & Supplies
Sharp AR-M277 Digital Copier Copier Logo
48 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
