Question about Jandy 131K BTU LAARS AIR ENERGY HEAT PUMP W/TITAN. HX & CHILLER
I have a Jandy Ae3000. I came home and found swollen pipe from the heat exchange flex pipe all the way atleast two feet past the valve going back to the pool. At one junction the pressure I guess was so great it pushed the pipe out of the fitting. Yes the valve was open. The heater is giving me a code that says low refrigerant pressure I'm not sure if this came before or after the fact. Can you tell me why this happend ? It looks like I will have to replumb the whole inside of the heater and replace the heat exchange. Heat exchange says lifetime warranty?
  • Dale Cobb May 11, 2010
    do you have a check valve on the system? I have seen this with a check valve that has failed. If there is no check valve, the heat pump may have been running when the pump was off. What type of timer/control system do you have?
    Top Expert:
  • Jandy Master
  • 3,543 Answers
Check manual bypass inside unit if spring broke water boiled in unit and overheated the pipe heater might be trash sorry
Posted on Apr 30, 2016
4 Suggested Answers
SOURCE: Pool heater leakage
Chances are that the header or manifold is cracked. usually the heat exchanger themselves are not damaged from freeze, but either the rear manifold (header) or the front header (the one that pipes go in and out of). Sometimes both. Replacing the entire heater is not necessary, about $200 in parts usually. We have a schematic diagram of the LJ heater here: http://www.poolcenter.com/parts_heaters_lite2_lj_2003-present_pg1.htm
Rob Cox
POOLCENTER.com
Posted on Jan 28, 2009
  • 139 Answers
SOURCE: Looking to buy pvc pipes to fit Jandy pool heater
jandy in and out pipes are 2" schedule 80 cpcv and should beavailable at any plumbing supply house. buy on 16" nipple and cut in half.Thread into headers then pvc cement the unthreaded end to tie into pump/filter system
Posted on Aug 23, 2009
  • 246 Answers
SOURCE: How to fox flo 6 problem on Jandy lite2 175n pool heater
possible was the wron one I assume was the same one clean the filter clean the basket check for clog impeller
Posted on Sep 02, 2009
Why won't my heater heat past 100degF?
Probably a bad thermostat. We have replacement thermostats at poolsupply1.com
Nov 03, 2014 | Pool & Spa
How many fluid ounces in a pipe measuring 5mm X 1m How many fluid ounces in a pipe measuring 15mm X 1m
English? Would that be approximately 3 feet of 1/4 inch pipe? 3 feet of 3/4 inch pipe?
Sep 10, 2013 | Easy Heat Water Pipe Heating Cable
My high efficiency furnace has water (possibly condensation) running down the air intake pvc pipe into the furnace and all over the burner, gas valve, and wiring.
First, check the drainline from the furnace. You have a 90% gas fired furnace. Where 80% furnace has 1 heat exchanger, yours has 2 heat exchangers. And the second heat exchanger will cool the exhaust enough, that it ends up below the dew point, and your furnace outlet/exhaust will condensate. This drain is probably stopped up. Now, I've installed and service many of these systems and I've only seen the piping at the roof you described once. And that was when the roofers replaced the roof, damaged the furnace flue pipe, and tried to repair it themselves. Normally, and this may not apply to yours, we tie in the exhaust/supply lines about 2-3 ft. above the furnace. Then 1 pipe goes through the roof. Thus 1 pipe is a kit that has an inner liner & outer pipe(2 pipes in 1). Now I'm not sure if this is a problem or normal for your system, but it may be worth looking into. You should be able to find it in the installation manual, or call a local parts house that sells your brand, or as your tech. And if it's just your drain, forget all about the piping I mentioned. Hope this helps!
Mar 08, 2017 | Goodman Heating & Cooling
014 code
A 14 code means the thermal fuse (white wire which wraps around the heat exchanger) has snapped. This occurs if the heat exchanger reaches a dangerously high temperature. To correct this error code you need to replace the thermal fuse and keep the heat exchanger from over heating. Typical reasons the heat exchanger over heats are:
1) scaling in the heat exchanger
2) combustion chamber dirty and burning hot
Oct 07, 2010 | Noritz N-069M-DV, N-084M, and N-084M-DV...
Jandy Lite 2 LJ Water Leaking
I have the same problem, removed the heat exchanger and found a small rubber gastket that was ripped. The gaskets can be found at parts store. Set of 18 about $20.00.can.
May 27, 2010 | Jandy Lite2 LJ125 Ceramic Gas Heater
Water will not heat past 57 the jandy control says it is set for 102-looks everything is working-is there a heater control somewhere?
Their is a heat sensor on your pipeing somewhere. It will be in a pipe and held in place by a stanles steel clamp and have a wire running back to you control. When you open your box and remove the inner cover you will follow the wire to where it pluggs in. Then simpley remove this and replace. Good luck.
Dec 15, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Help! I just recently purchased a '93 Honda Prelude and as I was driving it home from work today a pipe fell down on my feet! It's a plastic moulded black pipe that has the code 77421-SSO-0000 on it, I...
hi there i am willing to bet that the pipe is for the defroster or the air vent on the drivers side. you have to look up under the dash and try and see if you can locate the air vents this can be a pain in the you know were. all you got to do to locate were it came from is turn on your heat or ac and feel under the dash and you will feel the air flow and then you know atleast were the end goes now the hard part might be getting this back up there and on
hope this helps
Please leave me a rating
Thank you
Apr 21, 2009 | 1993 Honda Prelude
Pool heater leakage
Rob Cox
POOLCENTER.com
Jan 23, 2009 | Jandy Digital Lite2 Lj325 Btu Heater,...
I have central air and heat(the unit is about 8 yrs old)..when my heat kicks off there is still extremly cold air continually coming through the vents as if there is still a fan going,but it's not from the...
Does it look like a box with four flex ducts or pipes coming off of it? if so its a fresh air/ heat recovery ventilator, supposed to bring in fresh air, keep in mind, the outdoor unit does not bring in air, it is just a pump to the indoor unit. that unit may be running independently, or wired incorrectly
Jan 17, 2009 | Fantech AEV1000 Air Exchanger 120 cfm
Jandy 131K BTU LAARS AIR ENERGY HEAT PUMP W/TITAN. HX & CHILLER Logo
105 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
