Question about Plumbing
Ford TRactor 1710 hydraulic problem
I replaced a hydraulic line on the front end-loader on a Ford 1710 tractor ater it broke. AFterwards, I checked the hydraulic fluid in the resivour and it was still over full by about 1 to 1.5 inches so I didn't add any new fluid. When I start the tractor and run the front end loader up and down it works fine for about 2 to 4 minutes but then starts surging about 2 times a second. From what I've found online (very little) I may have air in the lines. I've been told that this system is self-bleeding and I should only have to move the bucket up and down and it should bleed itself. My problem is that it still surges and the bucket slows until it won't even move. Any ides? Can I add more fluid which is already about 2 inches above full but about 1 to 1.5 inches from the top of the case? Thanks, JR
  • Russell McCarthy May 11, 2010
    does anyone have a schematic or breakdown for a 1957 ford tractor hydraulic pump external
  • 317 Answers
Raise front loader....loosen hyd. line a little lower loader till all air is released and only fluid is coming out and retighten.....its like bleedig brakes on a car
Posted on Nov 17, 2009
Ford 7810 series 2 hydraulics have gone very slow have pressure tested tractor and it is OK until you rev it up the pressure goes oil sound like it is sergin in back end of tractor oil level OK ?
Best advice is for you to list this in Lawn and Garden or Construction equipment section for Tractors. There is a valve knob on a 4000 series that proportions hydraulic flow from more in back than front depending on the setting. If you have a front loader or if you have rear attachments you can get more action on the end you want. On a 4000 the knob is by the right heel of the driver. Could work like this for 7810.
Jul 20, 2017 | Ford Cars & Trucks
1640A Kubota tractor front end loader or bush hog will not lift
I would say you have air in the hydraulic system or you are low on Hydraulic fluid, I am not sure of the procedure on this make to bleed the air out but a dealer may help you if you ask nice.
Sep 22, 2016 | Cars & Trucks
Don't know how to read the hydraulic dipstick for a 1944 ford 2n tractor
Ford Tractor Hydraulic System - My Ford Tractors
www.myfordtractors.com/hydraulics.shtml
All N-Series Tractors - Ford-Ferguson 9N, 2N, and Ford 8N ... 6 - How long has it been since you changed the hydraulic fluid? ... If that didn't do it, read on. ... then remove the bottom bolt from the inspection plate that has the hydraulic dip-stick.
Yesterday's Tractors - Fifty Tips for Ford 9N, 2N and 8N ...
www.yesterdaystractors.com/articles/artint268.htm
I'd like to say that the reason I have an 8N Ford tractor is because that's the tractor ... The N tractors have a common sump for the rear end, hydraulic pump andtransmission. ... (Read the label.) .... Take the inspection plate with the dipstick off.
Ford 8N, 9N, 2N, NAA Tractors Information - SSB Tractor ...
www.ssbtractor.com/wwwboard/messages15/
Helpful information and resources on Ford 8N, 9N, 2N, NAA tractors from SSB Tractor, a leading provider of tractor parts, manuals, implements ... 1944 ford 2n: What type of oil to use? and whats the oil pressure should be? ...... N Series Trans/Hydro Fluid - Interesting To Read ... Ford NAA/Jubilee Hydraulic dipstick location?
Jan 01, 2016 | Ford Cars & Trucks
How to check the hydrolick fluid on a 1972 ford 5000 it has no dipstick I just got this tractor
Ford Tractors Information - SSB Tractor Forum
www.ssbtractor.com/wwwboard/messages4/
Helpful information and resources on Ford tractors from SSB Tractor, a leading provider of tractor ... tractor pumps oil but won't pump hydraulic fluid ..... 1972 Ford LGT165 lawn and garden tractor hydraulics ..... Ford 5000 transmission oil level
Aug 17, 2015 | Ford Cars & Trucks
2020 john deere diesel tractor with j-d 36# loader
Sounds like you need more hydraulic oil - Or like you said the transmission screen (dirty).
Where it is ??
Mar 27, 2009 | John Deere 420,1020,2010,2020,2510,2520...
I have a ford 1710 offset tractor. I have rebuilt the hydraulic pump and have trouble with the priority valve blowing seals. The factory offers two kits to remedy the problem,the first one didn't work,and...
I had this problem too. I made the upgrades like you did,
but I kept blowing seals. The solution is really simple, it
seems that if you take it to a shop they figure it out right
away. Where is all this information stored anyway?
One of the screws on the plate holding the power steering
hydraulic diverter (below the pump) needs to have a washer
between the plate and the engine. I don't remember which one
it is but I think it might be the top one. This will bring the shaft
on the priority valve (same as diverter) in line with the seat
on the pump. Without it they are not quite lined up leaving
a gap for the fluid to shoot through and blow the seal. Also,
makes it harder to get the thing together.
Aug 06, 2008 | Ford ZX2 Cars & Trucks
Plumbing Logo
1,627 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
