Question about Homedics Sound Spa Premier SS-5000 Clock Radio
SS-5000 Is the remote sensor installed in a protected outside area to read temperature or is it placed inside next to an outside wall?
The manual seems to indicate that it should be OUTSIDE but under a protected eave if possible.
Posted on Mar 08, 2008
SS 5010 not sensing outside temperature. I replaced the batteries in the transmitter and pressed the TX. However, the display inside just keeps blinking. I can see the inside temperature.
Inside temp is separate from outside...no connection whatsoever. If the outside transmitter has new power and fails, it may have gotten wet inside and may be rendered useless. Replace with a new outdoor transmitter.
Jan 31, 2018 | Measuring Tools & Sensors
The temp will not read outdoors I replaced the batteries in both the wall stn and the outside remote and still no reading what can I do to get the thing working again
Remove all batteries. Install known-good batteries in outside unit. Allow time for outside unit to initialize and begin sending temperature data. Install known-good batteries in wall station. You should see outside temperature displayed. If not, either or both units may be defective.
Dec 14, 2017 | Stn Home
Is the "remote sensor" the unit that is mounted outside? If so, then the thermometer is the unit that is inside the residence?
  • The Station that reveals all readings is placed in doors , the temperature sensor is placed outdoors if possible in a northern position of your building out of sun light
Mar 13, 2015 | Measuring Tools & Sensors
The thermometer that reads the outside temperature
its not in the engine area, its nearer toward the bumber area, and replace the sensor
Mar 07, 2010 | Suzuki XL7 Cars & Trucks
Outdoor device won't register inside.
All these wireless weather station devices have to be paired to the base unit whenever the batteries are changed in any of the remotes. It's a poor design issue, but there is no way around it, due to the nature of wireless operation.
Place both units near each other and look on the back of your base and remote sensor units, you should find a reset button (or a small hole). Either press the button or use the end of a paper clip to depress and hold the reset on each unit; Base 1st, then the remote 2nd.
After a brief moment, the remote should register with the base and you'll be back getting wireless readings.
Hope you find this Very Helpful and best regards!
Aug 22, 2009 | Kitchen Appliances - Others
Out side temperature reading
Without having parts to try, this would be difficult to know what the fault is. Inside this unit there is a circuit board, and on the outside there is the exernal temperature sensor.
There are only a few things that can go wrong. There is not much that is servicable unless you can find a spare board, or a spare temperture probe. There is very little posiblity that in any practicality this unit can be serviced at the component level.
I would just go out and buy a new unit.
Jerry G.
Apr 21, 2008 | SkyScan 86742 Digital Atomic Wall Clock
Homedics SS- 5000
Hey, OK so you know how when you plug the clock in it takes like 5 minutes to upload? Well wait till you have the time set the atomic thing stops flashing. Now when you get there press the button on the inside of the outside temperature thing. Not the c/f one. The red dot should flash on the front of the thing your holding. It should work after that. If not then make sure you don't have any computers or cell phones by it that messes with it. Hope this helps.
Jan 15, 2008 | Homedics Sound Spa Premier SS-5000 Clock...
Remote Sensor
make sure your time is set and the atomic clock time is recieved, then leaving the rear cover off of the transmitter, push the "tx" button not the "c/f" that is just for centegrade or ferenhight. you will see the red light on the front of reciever flash in a few seconds. The temp should display on your clock screen. If not, did the red l.e.d. light on transmitter flash. If not, its not sending data to clock. I have to reset and hit transmit every time I replace batteries on transmitter. Had no problems for over 2 years of using outside. If your not getting a reading with transmitter sitting next to clock after hitting "tx" button you may have defective transmitter.
Jan 13, 2008 | Homedics Sound Spa Premier SS-5000 Clock...
Cant get outside time to work???
I have the same problem with mine. The outside temp displays OK for a while, then it displays two dashs. I unplug the main unit from the wall until the outside temp comes back. I then plug it back in and it works OK. I found that if the remote sensor is located more than 40 ft from the main unit and there are a couple of walls between the two, the outside temp fails more often. I have noticed that putting my wireless phone in it's charging craddle can cause the radio or nature sounds to turn on. I moved the main unit further away from the phone and that cured the problem. Sometimes it will do this if the humidity is low and I build up a static charge and then touch the unit.
Jan 04, 2008 | Homedics Sound Spa Premier SS-5000 Clock...
Remote Weather Station shows "HHH"
This means that the read is over the HIGH limit of the sensor, perhaps is too hot there. Change it to another location. josemaX
Jul 30, 2007 | GE 75295 Clock Radio
Homedics Sound Spa  Premier SS-5000 Clock Radio Logo
431 people viewed this question
Top Homedics Audio Players & Recorders Experts
Gyula Lacz
ray gallant
Tom Chichester
Are you a Homedics Audio Player and Recorder Expert? Answer questions, earn points and help others
