Question about HP Pavilion dv9000z Notebook
When I start the laptop the light comes on but the screen stays blank.
  • 458 Answers
HOW TO FIX YOUR DV6000/DV9000/DV2000
All the Problems described in the previous posts are Graphics Related..
Faulty Nvidia Chip..Both Intel And AMD Based Motherboards..Though More Common on the AMD..
The symptoms of the Laptop Powering on and Shutting Off Repeatedly..Or.. Powering On and Having No Video...Or... Power Strip Lights Up, Beeps,Shuts Down...Or..No Power At All...Or.. Intermittant Loss Of Wireless/Video Goes In And Out/Touchpad Slows and Freezes..
To Fix this issue, You will need to Reflow The Graphics Chip.
I will Explain In Full Detail As To The Correct Method Below....
HP DV6000/DV2000/DV9000 Compaq v2000 Video Chip Reflow Instructions
First Step Is Complete Disassembly Of All Parts And Components..
Remove RAM, Remove CPU, Of Course Remove Heatsink and Fan assembly.
Next Step is Insulating the Motherboard... You need to Protect The CPU area, The RAM area, Cover any plastic Plug ports.
Try to leave 1/4 inch area around the edge of the chip free of insulation.
To Insulate the Board.. I use thick pieces of Tin/Aluminum, you can fold up some aluminum foil (tin foil) About 4 folds thickness....
Now that you have your Motherboard Insulated... Make Sure There's Nothing Flamable Or Burnable Below the Motherboard... it will get quite hot underneath.
You will need a Heat Gun.. You can get one of these at your Local Home Improvement Store, they cost about $15 - $30.. You Will Use ONLY the LOW Heat Setting... I REPEAT..... USE ONLY THE LOW HEAT SETTING ....
Next You Will Need Some Coins.. Yes Coins..
8 Quarters and 2 Nickels... Put the 2 Nickels On the Bottom and Stack Quarters On Top...
Place The Stack Of 2 Nickels And 8 Quarters On Top Of The Graphics Chip...
The Reason for using the Coins: Using the coins serves a few purposes...
1) It Helps Transfers the heat Into The Chip More Evenly/Slowly
2) It Helps Hold The Heat Longer/Then Helps To Cool Slower
3) It Gives The Correct Amount Of Weight That Is Needed To Press The Chip
A Thing To Look Out For...
Hewlett Packard is nutorious for using the RED epoxy around the edge of the Graphics chip.. this epoxy is used to help secure the chip to the motherboard...
This is a process that is Hand Done at the Factory.. And Some Boards Will Have Only A Little Amount of this, Some Will Have Alot of it...And Some are Only Done On The Corner Edges....
If There Is Alot of This On Your Chip, You Might End Up Needing To Carefully (REAL CAREFULLY) Remove as much of this epoxy as able to....You can use a Razor Blade To Lightly Scrape This Off... DO NOT MISS AND SCRATCH THE MOTHERBOARD!!! Go SLOW...
Now Comes The Heating Of The Chip...
Start With The Heat Gun About 6 Inches Away From The Top Of The Quarter Stack..You want to be holding the gun at a 45% angle.. Aim the heat at the Edge of the chip, You Will Start Rotating Around the Chip- around the outer edge of the chip...then use tighter circles concentrating on the quarter stack, then after about 30-40 seconds, slowly move closer to the chip...
Never Move the Heat Gun Closer than the Top Of Your Coin Stack...Then Pull It Back And Slowly Repeat.. The Chip Needs To Get Hot Enough To Re-Melt The Solder Balls On The Underside Of The Graphics Chip Back Down To The Contact Pads On the Motherboard.. and this takes Quite Alot of heating to Do.... You Must Not OVERHEAT the CHip... It Is Best To Underheat it and have to Redo.. than to overheat.. It will cause the solder to break down and even crack/split.. causing failure forever...
This process will take about 3 minutes total.. Once you shut off the Heat Gun.. Leave The Stack of Coins On The Chip And Let Sit For Another 5 minutes..
Now Remove The Coins(carefull they might still be hot)
Remove All Insulation.. Reinstall RAM, CPU, Heatsink and FAN Assembly (and Of Course Thermal Pads or Paste.. Note:. If Paste Is Used.. It Must Be Silver Paste...
Now You Can Connect The Power Button Strip/ Video Cable And The DC Jack Cable.... And Plug In AC adapter .. You're Now Ready To Test For Solid Power and Video....
Posted on Nov 22, 2009
  • 458 Answers
I turn it on, but the screen stays blank and the fan starts blowing really hard, caps lock and other lights light up but my laptop doesn't start at all.
hi,
if this continues consistently you might be looking at a screen problem, take the system to a qualified laptop screen repairer to get it fixed.
hope this helps
Jul 06, 2011 | HP Pavilion dv7-1130us laptop
MuWhen i turn the computer on the screen stays blank, the light on the far left hand side come on, but the screen stays blank - any solution? Thanks the computer is a Dell Inspiron 1525
clean the ram and check .. if same then u need to update the bios with programer.. u need to open laptop and remove the bios ... its all diffcult ... if any one has bios programmer ... i can send u bios updating file... u can contact me... thanks
Sep 13, 2010 | Dell Inspiron 1525 Notebook
Screen stays blank after start up. Grafic card?
take battery out then get rid of dust then restart it if still doesn't start make sure adaptor works correctly, if problem is still there its a computer error/bug
May 30, 2010 | Fujitsu Siemens AMILO D-7830 Notebook
My laptop comes on but the screen stays blank??
Unplug the power, remove the battery and then hold the power button for 30 to 60 seconds. Then reattach the power and attempt a boot. It worked for me! Just shutdown, put the battery back in you're good to go. Worked for me so definitely worth a try.
Good luck
~Phil
Jan 09, 2009 | Computers & Internet
R52 laptop screen stays blank
Try removing the battery and starting up just on power supply. May be a bad battery. If that doesn't work let me know.
Jun 06, 2008 | IBM ThinkPad R52 Notebook
Stupid blank screen on my Craptop
Could be a simple video driver problem, try starting up your laptop in safe mode (Pressing F8 on boot up). If and when screen comes up highlight 'Start Windows in Safe Mode' Next a list of startup drivers etc will stream down the screen and tell you you are starting in safe mode, allow this. If your lcd screen stays on then it's a driver problem, go to add/remove programmes and uninstall driver the driver and restart your laptop. This should then start in VGA mode all icons will be bigger than normal. Either re-install video drivers from setup/restore disk or go to laptops manufacturer website to download drivers. If no screen even in safe mode LCD probably dead. Please rate solution.
Nov 15, 2006 | Syntax ValueBook VT5000 PC Notebook
HP Pavilion dv9000z Notebook Logo
335 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
