Question about LG Shine KE970 Cellular Phone
Phone will not dial, can't use any keys. the only one that is working is the off key. Did not get wet, or was not dropped.
My LG Neon got wet is now really messed up
I had the same problem and fixed it rather easily, the problem is that the componants are wet and need to be dried, if you send it away your warrenty will be flaud as it is wet and all they will do to fix it is pull it apart and put it in a drying machine so i advise you to wrap it in a towel and place it somewhere warm like a hot water cubboard or directly in the sun, it needs to completly dry. you could try wrapping it in a towel and use a hairdryer on a low setting to dry out the componants, remeber to stop and let it air evey now and then or you will get condensation on your screen, hope this helps
Dec 22, 2009 | LG Neon GT365 Cell Phone
No dial tone with 3730
No dial tone means the terminal is not getting a signal from the phone line.
Troubleshooting:
1) Make sure it is not on a splitter most of time the splitter goes bad.
2) Make sure the phone cord used is a 2 pin cord.
3) Make sure if you have DSL from your phone company plug it in a DSL filter but make sure
you drop the baud rate the terminal uses.
Hit the more key (2nd purple key from left usually the tip key) until you see other setup.
Enter Password Default 1 Alpha Alpha 66831 Alpha key is the little black button above
the number 2.
Then hit the more key again until you see COMMS choose that and hit next until you see
Baud rate. Hit Edit and then NEXT until you get 300 baud when that shows under new hit
select or enter. Choose F4 exit save changes and then the red X key until you are back at
main sales screen Run a test sale.
If still same problem Repeat steps and change baud rate until one works. Usually 300 will
work for DSL lines.
Call me if you need assistance.
www.greenlightpayments.com EXT 105
Jul 02, 2009 | VeriFone Omni 3700
I dropped phone in toliet. Will it ever work
If you immediately put it in a bowl of white rice, it drys it.
But other than that, nope. It probably won't work.
I had the same issue only I actually flushed mine on accident, haha.
Jun 22, 2009 | Motorola Mobility RAZR V3
Wet phone - can turn on - other keys dont work
only god can answer that question...try using a blow dryer on low and if it doesn't come back to life...replace it...phone companies always have sales on cell phones.
Mar 27, 2009 | Motorola Mobility RAZR V3
When i pressing green Dialing key for making a call it fails to dial (Hangs), i hv to restart each time (6630)
HI HAROON
YOU SHOULD FORMAT YOUR MEMORY CARD AND CELL PHONE MEMORY AND TRY AGAIN.IF THE PROBLEM PERSIST THAN GET FLASH YOUR CELL PHONE.
DO LET ME KNOW WHICH GSM NETWORK YOU ARE USING AND YOUR CITY/AREA LOCATION.
Oct 22, 2008 | Nokia 6630 Cellular Phone
Dial out problem
you just have to change the key pad and dry the inside of the phone.
Feb 09, 2008 | Motorola Mobility RAZR V3
Wet motorola l6
okay...you should purchase a new keyboard that should help.
Dec 18, 2007 | Motorola Mobility L6 Cellular Phone
Nokia 6255i keypad problems...PLEASE HELP!
if you manage to open the phone you go to the face plate were the key pad is possitioned and clean it with isoprophyl alcohol that can curethe problem . advice by dogy
Jul 03, 2007 | Nokia 6255i
LG Shine KE970 Cellular Phone Logo
53 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
