Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
My glass top with sealed burners Jenn-Air range is having trouble with the burners...the large burner does not come on at sall and the three smaller burners come on but do not maintsin the temperture settings..once they get hot they cool down before they will heat up again...can I fix this?
  • 725 Answers
Yes, you can fix this yourself! It is a simple repair thatyou canmake yourself, too.
The large burner needs to be replaced and the other burners need thr infinite swithces replaced on them.
I love the Jenn-Air brand ranges. Contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service from 7 AM until 9 PM CST and we will ship these parts to you overnight along with part removal/installation instructions for you to get cooking ASAP!
Thanks, Ella
Posted on Nov 17, 2009
NEED TO REMOVE RANGE TOP. THE LARGEST BURNER NUT HOLDING THE VENTURI IS STUCK. OTHER THREE BURNERS REMOVED OK. DO I HAVE TO SPLIT THE VENTURI NUT TO REMOVE RANGE TOP? I NEED TO GET INSIDE RANGE UNIT.
Yes keep playing with it and BOOOOM! Call in a professional. This is the law with gas appliances.
And turn off the CAPS lock. We heard you the first time :-)
Jan 24, 2016 | DCS "CTD-304-L 30"" Drop - in Cooktop, 4...
Burner light stays on
This is caused by a faulty sensor that is located between the burner element and the top. To replace the faulty part you will need to uninstall the cooktop and remove the glass top. The sensor is a rod a little smaller than a pencil that you will see right on top of that burner.
If you choose not to replace the sensor it will not cause any issues other than you will have to live with that light constantly on and you will know when the top is hot for that element.
Jun 19, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
I have a Jenn Air Electric stovetop with a glass top (Black) model # FCE 30600A One of the burners is nor working. Can I remove that glass top and repl;ace the burner?
Yes you can, at least I removed mine on a Kenmore. Be very careful as the burners are very delicate and even more so after they have aged.Look under the edge at the front for 3 screws. The top should pull out slightly and lift.
Apr 11, 2010 | Kitchen Ranges
How do you open the top of a gas range if it's sealed
remove the burner caps and drip trays if your have them / some brands will have 3 screws in each burner ( remove them . ) maytag style ( the burner turn's out ( you may need a strap wrench / be carefull not to break the ignitors on the edge of burners . ths will release top.. mm
Nov 22, 2009 | Jenn-Air Kitchen Ranges
Kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
Jan 29, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
My electric stove top burner only works on high
This is for the glass top units. well i'm not sure if your problem is with your large or small single burner or the large expandable burner. If it's the large or small single burner replace the burner and if it the expandable also replace the burner. If you have a coil burner replace the infinite switch. Good luck hope this helps you.
Jan 09, 2009 | Jenn-Air JED8430 Electric Cooktop
Glass Top Replacement
There are 3 or 4 screws under the front lip; then the unit hinges upward. Turn off the power first! Once opened you can safaly remove the burners and replace toe top. hope this helps!
Dec 26, 2008 | Jenn-Air JED8430 Electric Cooktop
Jenn air pro range 36" prg3610np
hi after the burner ignites turn knob until it stops trying to ignite thanks
Jan 07, 2008 | Jenn-Air PRG3010 (NP) Gas Kitchen Range
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
288 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
