Question about LG Vu CU920 Cellular Phone
I cannot use my touch screen at all. I cannot check texts or voicemail. Hard buttons do still work & I can receive calls. I have not dropped my phone nor have I dropped it into water.
Goes to voice main on first try on second try rings
According to iPhone faq.org: " How can set the number of rings on my iPhone before voicemail picks up?
You can set the iPhone to wait longer or shorter than the default 20 seconds before it goes to voicemail when receiving an incoming call. This will result in a different number of rings before the voice messaging system picks up the line and plays your outgoing message. To change the amount of time the iPhone will ring follow these steps:
1. Open the phone app and dial *#61# on the Keypad. Press the Call button.
2. Locate this text on the screen: "Setting Interrogation Succeeded, Voice Call Forwarding, When Unanswered, Forwards to +" and record the 11-digit number after the + symbol.
3. Touch the Dismiss button. Now enter this code on the Keypad: *61*+ followed by the 11-digit Forwards to number recorded in step 2, followed by *11 and *ringtime#. Ringtime is the number of seconds you want your iPhone to ring before voicemail picks up. Your finished code should look something like this:
*61*+18555513466*11*30#
In the example above the ring time is set to 30 seconds. Press the Call button.
4. You should receive the message: Setting Activation Succeeded. Press Dismiss and next time you receive a call it will ring for the new amount of time before going to voicemail."
According to Apple Tool Box.com: "having this problem, please try the followings:
  • Make sure that iPhone's Ring/Silent switch is OFF meaning ringer is ON. A bell will flash briefly on the screen when you turn on the ringer.
  • Make sure that the Do Not Disturb setting is not silencing calls (Settings > Do Not Disturb).
  • Make sure that Airplane Mode is OFF (Settings > Airplane Mode).
  • Make sure that your carrier software is up to date (Settings > General > About)."
    AccorA
Apr 15, 2015 | Apple iPhone 4S
Save voicemail and text msgs
not sure about voicemails since the've kept on your provider's server but you can copy all your texts to SD card then re-insert to computer and copy them.
Nov 29, 2014 | LG 800g TripMinutes Touch Screen tracfone...
How do i delete my masseges
Are you asking about voicemail messages or text messages? Most phones allow you to erase voicemail by pressing the number 7 during or after the message. If you have a touch screen phone and want to erase text messages, try touching and holding your finger on the message for a few seconds...a delete button may pop up. 25254526-ipxh3zptubm5u5d1ogqxpt0r-2-0.png
Oct 24, 2014 | Cell Phones
My Motorola Photon Q will not receive or send texts or calls, what can I do?
I would check with sprint to see if your account is up to date. Otherwise, I would suggest going to your settings and see if you can update your phones's prl and profile. go to settings, tap "About phone", Tap "System updates", then tap each option. Good Luck!
Dec 05, 2012 | Motorola Mobility Sprint Photon Q 4g Lte...
Can't receive texts with certain numbers
go to contacts in the phone, go to your entry, press sub menu button, uncheck incoming calls (send calls directly to voicemail)
Jul 08, 2012 | Lg800g With 1200 Minutes And TripMinutes...
I have a LG Chocolate Touch... It had been working fine, I recently put a lock code on it... I still remember the password but now my touch screen isnt working... It hasnt been dropped nor fell in water so...
Hard reset SHOULD work:
Settings (and tools on some phones)--->Phone Settings--->Security Setting--->Master Reset (it may be called something else, but it will be clear).
Jul 05, 2011 | LG Cell Phones
The touch feature is not working. When I touch the screen nothing is happening. I cannot make any calls or text. What do I need to replace to fix it? I can receive calls.
my phone feel in beer.... i dried it by the fan over night and was working fine for about four days. On the fourth day the touch screen didn't work, but all my buttons work. I can pick up phone calls, call the last person I talked to, and it also charges. Is there any way to fix my touch screen???
Mar 22, 2010 | LG Dare VX9700 Cell Phone
I dropped my Blackberry Curve and the phone clicks...
the volume button may be stuck in a weird position on the inside. you may want to take it apart and clean the inside and reassemble. if you cant then a local repair shop may be able to do it for you
Apr 27, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
LG Vu CU920 Cellular Phone Logo
82 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
