Question about Linksys Wireless-G WRT54G Router
Wireless g router
What do i use for a passkey when i hit reset? THere are several numbers on the bottom and i dont know which one it is.
    Sergeant:
    Champion:
  • 317 Answers
Which passkey? if it is to access the router utility, it is usually password or password1 if it is to access it from a wireless device, then it is whichever number is listed as WEP or WPA
Posted on Jan 09, 2008
  • Alexander Selby
    Alexander Selby Jan 09, 2008
    Sorry Dude the password for the utility is admin
6ya staff
SOURCE:
Setting up a new modem
After you press the reset. Your laptop has to be physically connected to the router to configure it
Open your web browser, type in "192.168.1.1" and login using username and password.
In "Basic setup" DHCP Server should be "Enabled"
Enter "Domain name" Name your private network
Set the starting IP address - Enter 10 ( any low number)
Set time zone
Save Settings ( button at bottom of page )
Under Advance Routing, set Operating mode as "Router"
Save Settings
WIRELESS TAB
Wireless - set to MIXED
Wireless network name - same as domain name
Select a wireless channel (default is 6)
Wireless SSID Broadcast - ENABLE
Save Settings
Wireless Security tab
Select WEP
Default transmit Key - select 1
Enter a pass phrase to generate a security code, click on Generate
WRITE DOWN THE PASSKEY ( aka, Security code)
KEY 1 should have this PASSKEY entered.
SAVE SETTINGS
On your laptop, right click on the icon for the wireless on the task bar, select "View available networks"
Select your network, it should prompt you for the passkey, you will need to enter it twice
Jan 08, 2013 | Zyxel (91-004-361002) Wireless Router
Password reset
Do you know the current password? if so go to start > run command type IPconfig look under Default Gateway know that number. put that number into your web browser. Then from there use admin for your user name and 1234 in the password field from there go to your wireless settings and change the password
If you dont know the password just hit the reset on the back of the router for about 5 seconds and then follow above
Apr 24, 2012 | Edimax BR-6228Ns 150Mbps 802.11n...
Forgot password for wireless network. When I had to reset my kindle and lost all my books I restarted my kindle per their instructions, but now I cannot access my wireless network on my kindle because my...
login to your router from your computer and change the wireless passkey. if you do not know how to do this then use the manual provided for the product and it will tell you how to connect to the router and change the passkey information under wireless.
If you forgot the password and username for the wireless router itself, there is a button either onthe back or bottom for resetting the router to default settings. This will clear everything stored and change all settings to factory after which the information is in your manual. If you don't have a manual, the manuals can be found easily by searching google.
Sep 28, 2011 | NetGear WGR614 Wireless Router
How do I find my Network Key..or Password
If you forgot or do not know teh network / passkey of your wireless router you have to follow the following procedure to know the password (i am assuming that you have windows)
1. Connect your router directly to your computer (disconnect your cable / DSL internet from the router)
2. Use the Switch ports (ports marked 1 to 4 to connect to your computer / Do not use the internet port or WAN port in your router to connect to the computer)
3. Open command prompt (Start - Run - Type CMD and hit enter
4. Type IPCONFIG and hit enter. (not down the numbers next to Default gateway (it should be in the format 192.168.1.1 etc).
5. Type exit and hit enter
6. Open the internet explorer and type the default gateway you noted and hit enter
7. You should get a small popup asking for username & password - type
admin (username)
password (password) if this does not work (type admin for password also)
if this username and password does not work then you need to reset the router. (Please refer to the manual for this process)
8. if the username & password works you should be able to access the router page, then you need to click on wireless settings on the router page and then know or change your wireless passkey.
Please reply to the post if you need further assistance.
Dec 24, 2010 | Computers & Internet
Please help, when i try to connect dir-615 on my network pc that is running vista, instead of asking for wireless passkey key{because i set on my router to WPA security)it's asking for certificate and user...
1st have clean all settings? a reset button is behind nerby the power connector.
2nd change wireless passkey(use WPA2 it´s safer) and very important the router password.
3rd reboot computer, then vista work well. (Its a Vista Defect, dont ask me why, but it´s true)
Nov 21, 2009 | D-Link DIR-615 Wireless Router
We dont know the sercuity code?
When you try to connect to a wireless network, it can be your router or can be any wireless network nearby your laptop. So if its your router's network you are unable to connect, you can call your router company, or can go to the router page and change the passkey for the wireless network. By going to the specific option or by running the setup wizard from there again. You can access the router page by ip of the router, i.e. default gateway of the PC.
If its not your router then you cant access it, until and unless you contact the owner of the network to give you the passkey.
If your network is showing multiple network, ensure which one is yours and if your network is working properly.
Regards,
Shrey
Oct 23, 2009 | NetGear WGR614 Wireless Router
Need to install Wireless-G Broadband Router 2.4
try this website...http://74.125.153.132/search?q=cache:N_ltt9u-l0AJ:mac.softpedia.com/get/Drivers/Linksys-Wireless-G-Broadband-Router-WRT54GS.shtml+software+for+linksys+wireless+router&cd=2&hl=en&ct=clnk.....thanks for using fix ya!please dont forget to rate my solution
May 30, 2009 | Linksys Wireless-G Broadband Router
I forgot my passkey
The resetting to factory settings commands are:-
Reset Procedure print.gif Step 1 Locate the reset pinhole on the back of the unit.
Step 2 With the unit powered on, press and hold the Reset button.
Step 3 Hold the Reset button for about 10 seconds.
Step 4 Release the Reset button.
Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting.
Step 6 The device is now at factory defaults.
...................sodeep
May 12, 2009 | Belkin (F5D7132) 802.11b/g Wireless Access...
Passkey
You have to reset the router and re-configure it with the new passkey.
Sep 11, 2008 | Belkin (F5D7231-4) Wireless Router
Vista and bluetooth
Passkeys need to match in both the router/access point and the wireless adapter attempting to communicate with it. Whoever configured the router should be able to supply the WEP/WPA passkey / passphrase / network key If your router does not have a passkey ... you are attempting to attach to the wrong wireless router. (if that is the case you should consider assigning WEP/WPA security to your wireless networl (router/accesspoint and adapters)
Dec 24, 2007 | IOGear (GBU211) Bluetooth Wireless Adapter
Linksys Wireless-G WRT54G Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
