Question about Logitech MX3000 USB PS/2 Wireless Keyboard/Mouse
Keys do not register
When I connected the keyboard and mouse, th emouse worked perfectly. But the keyboard not so much. While it is connecting the battery light blinks a few times and suts off. When you hold the battery test button, F1, it lights up green. The 'Sleep' and the 'F Mode' buttons work. And to wake it up every key on the keyboard will wake it up...but they won't work otherwise. Is there a way to troubleshoot around this problem?
  • 1 more comment
  • Anonymous Apr 02, 2008
    some upper case letters don't work
  • Anonymous Apr 05, 2008
    the mouse works, however the only the shutdown button works on the keyboard. i have replaced the batteries but there is no change.
  • bornssrvr Sep 04, 2008
    After connecting receiver, connected mouse ok but the keyboard wouldn't sleep button worked and any key will start pc back up but cant type after this. Please help
  • 1,067 Answers
Try new batteries new kb drivers from website duracell best to use
Posted on Jan 09, 2008
  • nick helpap
    nick helpap Jan 16, 2008
    1st off what model kb u have that dont work be more spefic thx nick then i can help u more
My hp wireless usb mouse won't connect. I have tried th connect button on bottom with no luck the keyboard works great but no mouse. please help
Make sure that the batteries are good and inserted correctly and that the LEDs (if any) light up.
Jun 18, 2011 | HP Wireless Optical Mouse
Logitech wireless mouse (m305) isn't working
Does this mouse need to sync with the reciever plugged into the computer?
Somewhere on the mouse and posssibly on the reciever plugged into the USB
port on the computer it should have a connect button. Usually to connect/sync
a mouse or keyboard press the button on the reciever first then press the connect
button on the mouse. Or if th mouse has a button just press the mouse button,
often the mouses lazer will blink until the mouse connects with the reciever then
just stay lit at this point it sould work. Another Question, how are the batteries in
the mouse?
May 19, 2011 | Logitech Cordless Mouse
Did some work on my pc now the keyboard is not working when i type letters or use keys they are not responding but my mouse is working
You should check the connection of you mouse and keyboard to see if they are properly connected.If the connections are okay you should go to the manufacturer website and download and install the drivers for the mouse and keyboard,i cannot give you the link because i am not sure what type of mouse and keyboard you are using. If you are using wireless mouse and keyboard you should replace the battery inside both of them and make sure the receiver is turn on.After you try these solution your mouse and keyboard should work fine.
Sep 03, 2010 | Logitech S520 Mouse
Logitech mouse n keyboard wont connect
whenever you chage the battery you have to syncnonize your keyboard and mouse to sensor of the reciver. you can see on the back side of the keyboard there is connect button just press it and on the recevre side also press the connect buton same setting do with mouse also.
Sep 08, 2009 | Logitech Cordless iTouch Keyboard/Cordless...
Keyboard failure at boot cannot use F2, F8 or F12 keys
watch it and bam solved
Aug 14, 2009 | Dell Dimension E521 PC Desktop
No boot no keyboard or mouse
First disconnect all external connections except video, see if system will boot normally (press the power button once on tower to shutdown)
If that works, then connect the keyboard only to the back USB port nearest the NIC. See if the keyboard works. If it does, shutdown and connect the mouse and try again. If it doesn't, try the mouse only. If you localize the problem to either the mouse or keyboard, replace that item.
If neither works, then reset the motherboard junper to reset BIOS defaults. the again, try them one at a time. If they still do not work, then you will need a mothebroard.
Apr 18, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
All Keys do not work on keyboard with KVM switch
GCS632U is designed to work with standard USB keyboard an mouse only. You have to make sure that you are not using any type of adapter such as PS/2 to USB adapter. To further isolate the problem, please follow the steps below:
1. Connect the USB keybord directly to th computer to make sure that the keyboard is working properly.
2. Make sure that the keyboard is connected to the keyboard port on your KVM switch. You may take a look under neath this GCS632U (near the USB ports) and you will see an icon where to connect the keyboar and mouse.
3. If you're still gettings the same problem, Try power cycling this kvm switch by disconnecting if from the computers and disconnect also the keyboard and mouse from the KVM switch and leave them disconnected for a minute or two.
4. Reconnect everything after two minutes and then reboot the two computers.
5. If same problem exist, try using different USB keyboard.
NOTE: This KVM swith does not work correctly with wireless, gaming and smart keyboards because it's designed to work with standrd USB keyboard only.
Mar 23, 2009 | IOGear GCS632U 2-port KVM Switch
Problem with the receiver on my wireless keyboard & mouse KB985W
If you still have the software that came with your keyboard and mouse then i suggest you reload it, it appears that some of your keys have functions to them and they are misbehaving.
If you do not have the software then remove the reciever from the computer and then replace it again. press the connect button on the reciever then the connect button on the keyboard, wait for it to register the keyboard then press the connect button on the reciever then the connect button on the mouse and wait for it to register.
Hopefully this will help.
Nov 16, 2008 | Micro Innovations PD7250LSR Wireless RF...
Logitech wireless mouse and keyboard
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Sep 23, 2008 | Logitech Cordless Mouse
Mouse/keyboard problems
Probably, the keyboard cable isn't quite connected, or crooked. Likewise, the mouse cable. It's hard to get them into the connector perfectly straight and tighten them at the same time. Shouldn't be a problem. If it still doesn't work, there's a chance that by disconnecting the keyboard/mouse after such a long time, the cable might have become damaged. Hope not tho.
Good luck
Oct 16, 2007 | Dell Inspiron 3500 Notebook
Logitech MX3000 USB PS/2 Wireless Keyboard/Mouse Logo
89 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
