Question about Canon PIXMA iP6700D InkJet Photo Printer
Error message A600 on iP6700D pinter --- removed all cartridges as suggested - no change - turned off and attempted a hard reset - no success - will not print at all -
    President:
  • 2,306 Answers
6A00 says the purge unit is jammed on the right side where the printhead parks.Sometimes you can just push back the squeegee assembly to free it and clean with a wet Q-tip. Other times you can only have the purge unit replaced.
Posted on Nov 26, 2009
Error 0xc18a0101 persists. Have tried solution given earlier for 0xc18a0001 without success. Ink system failure not resetting; all cartridges are full.
Its tricky mechanism, once printer detects ink system failed it cannot be resetted. Do this take out cartridges from printer., open right cover., find out logic card., remove cmos battery., wait for 5 minutes., refix batyery., power on the printer., follow the screen messges ... I hope it will solve the issue..
Sep 15, 2014 | HP Office Equipment & Supplies
PIXMA IP6700D Ser No.AAHG05912: Just replaced two ink cartriges(which I have done many times)and when attempting to print printer made a screechy ratcheting sound. "on" light blinked and so...
MARELT:
If you are still there seeking a solution, and didn't have success with the above, I will be happy to work with you on it. I have significant experience with these type printers, and will work with you until resolved. Please do not rate or close out the issue until we have agreed that we are fixed, or have tried everything, as troubleshooting is one step at a time and I will stick with you throughout.
Can you tell if any of the miscellaneous pieces, such as springs, belts, nuts & bolts, etc., are out of place or otherwise loose or malfunctioning? Often, this type of noise, accompanied by the failure of the carrier to return to center, is generated by two things: some part is out of place or otherwise damaged (could be as simple as a loose screw or cartridge not exactly placed properly) or there may be an issue with the print head itself. However, my experience has most often been that there may be a relatively easy solution, it just takes time to find it. Please let me know by posting back if you care to pursue, and I am further researching your specific model now.
smartsolve
May 31, 2008 | Office Equipment & Supplies
Getting a Cartridge Error message: "remove and
Hey well the cartridge could be faulty,,is it a genuine hp,,Those generic ones u can sometimes find arent that good,,but check the hp website for solutions,,there very helpful,,thats why hp is my favorite computer manufacturer,,goodluck
Nov 18, 2010 | HP OfficeJet 4315 All-In-One InkJet...
Epson D88 will not print, both red lights flash, message remove obstruction switch off and on. No change still 2 redlights flashing
The Lights can flash on an error and also iff the INK levels are down. You must check the ink levels and try to do a reset with printer software reinstalled.
Remvoe pinter from the PC, unistall and then reinstall to see if the printer shows the INK level exactly. If not replace INK cartridges to confirm.
Nov 16, 2010 | Epson Stylus D88 InkJet Photo Printer
What is error #2200
The 2200 error message indicates a scanner stall or jam. The steps below will help you to resolve the issue and clear the error message.
Printer Reset
1 Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
Did the error message return?
Yes: Continue to step 2.
No: Attempt a test scan. If the error message does not reappear, the error is resolved.
2 Power off the AIO and remove the power supply from the back of the unit. Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
Yes: contact Dell.
No: Continue to step 3.
3 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Insert the color cartridge, close the top cover, reinsert the power supply, and power on the AIO.
Yes: Repeat step 3 with another color cartridge. If the printer fails again, continue to step 4.
No: Repeat step 3 and install the black/photo cartridge. If both cartridges are installed, attempt a test scan. If the error message does not reappear, the error is resolved.
4 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove the color cartridge and insert the black/photo cartridge. Then close the top cover, reinsert the power supply, and power the AIO on.
Yes: Repeat step 4 with another black/photo cartridge. If the printer fails again, contact Dell.
No: Install the color cartridge. If the printer fails, contact Dell. If the error message does not appear with both cartridges installed, attempt a test scan. If the error message does not reappear, the error is resolved.
Mar 23, 2010 | Dell 962 Photo All-In-One InkJet Printer
I get the error 2200 message everytime I try to send a fax
Hello there:
this is a scanner stall or jam. The steps below will help you to resolve the issue and clear the error message2.gif.
Printer Reset
NOTE: The embedded links in the table lead to specific troubleshooting documents.
StepAction1
No: Attempt a test scan. If the error message does not reappear, the error is resolved.2
Power off the AIO and remove the power supply from the back of theunit. Open the scanner cover. Check the scanner glass for cracks andthe scanner casing for cracks. Close the scanner lid. Open the topcover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
Yes: Continue to Contacting Lexmark.
No: Continue to step 3.3
Power off the AIO and remove the power supply from the back of theunit. Open the top cover of the AIO. Using the carrier belt, move thecartridge carrier to the middle of the unit. Insert the colorcartridge, close the top cover, reinsert the power supply, and power onthe AIO.
Yes: Repeat step 3 with another color cartridge. If the printer2.gif fails again, continue to step 4.
No: Repeat step 3and install the black/photo cartridge. If both cartridges areinstalled, attempt a test scan. If the error message does not reappear,the error is resolved.4
Power off the AIO and remove the power supply from the back of theunit. Open the top cover of the AIO. Using the carrier belt, move thecartridge carrier to the middle of the unit. Remove the color cartridgeand insert the black/photo cartridge. Then close the top cover,reinsert the power supply, and power the AIO on.
Yes: Repeat step 4 with another black/photo cartridge. If the printer fails again, continue to Contacting Lexmark.
No: Install the color cartridge. If the printer fails, continue to Contacting Lexmark.If the error message does not appear with both cartridges installed,attempt a test scan. If the error message does not reappear, the erroris resolved.
Nov 10, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
I have a 13 month old HP Photosmart C5180 which is now displaying the following error message, "Ink System has failed. Unable to print.." Error: Oxc18a0506. The help message suggests "turn power off then...
your second set of catridges mush help you,, and also,, it seems that your operating system is corrupted,, its better you reinstall the printdrivers first,, if problem persists,, then try reinstall of windows..
Sep 28, 2009 | HP Photosmart C5180 All-In-One InkJet...
Error u071 I have a pixma ip6700D when I changed the ink cartridge I got the error message UO71 that says I have more than one cartridge of the same color, which I don't.  I have reseated the cartridge,...
Call Canon Tech Support @ 1 800 828 4040
This error is caused by a malfunction of the cartridge chip.
Canon will replace the cartridge(s) at no cost under warranty.
Jan 12, 2009 | Canon Pixma iP6600D InkJet Photo Printer
Canon Pixma IP6700D
Hi there
Error A600
Your A600 is a paper path error, usually related to the purge unit. Try checking the purge unit for paper stuck in it.
The 6A00 is a Canon generic code for paper path jam.
Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.
Almost 90% of the time is related to the purge unit being jammed with something and not being able to move.
Look for paper, paper clips, push pins, screws flower bud pods or the like.
The offending item needs to be removed or the purge unit needs replacement.
The purge unit, called a spittoon assembly in an HP, Lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has an electrical pump to milk the print heads and test for ink flow.
The purge unit is a white plastic assembly (on the right side of the printer where the print head homes) that is spring loaded on rides on a rail.
You can try moving it back and forth about 5 times or so and clean the rail with a cleanex and putting a little bit of some light oil on it and then close everything up and try it.
If you found this useful all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Jul 07, 2008 | Canon PIXMA iP6700D InkJet Photo Printer
Ink Tank not recognized
Here's info on the reset:
When your printer detects a problem with the cartridge you are attempting to use, a flag is set inside the device. This flag may not reset until you perform a hard reset on the device.
1. Verify that the printer is turned on.
2. Open printer's lid/top cover and remove all of the cartridges from their carriers. Close the lid/top cover.
3. Unplug the power cord from the printer.
4. Wait for 10 minutes.
5. Plug the power cord back into the printer.
6. Open the lid/top cover and reinsert both cartridges back in to their carriers.
7. Turn the printer on.
8. Print a test page.
Oct 01, 2007 | Canon PIXMA iP6700D InkJet Photo Printer
Canon PIXMA  iP6700D InkJet Photo Printer Logo
189 people viewed this question
old marine
old marine
