Question about Electrolux Dishwashers
My aeg electrolux favorit sensorlogic dishwasher stopped working. It starts the program. Fills itself with water and then quits. Then it starts to beep constantly. I dont know what to do.. anybody that can help me?
SOURCE: My AEG favorit sensorlogic turbo
hey
I just had the same issue done everything you say above with no joy. i then emptied the water that was in the dishwasher that the filter goes into and its now fine.
good luck
Posted on Jul 03, 2008
SOURCE: AEG Favorit 50730 Sensorlogic Dishwasher:
get a new dishwasher
Posted on Nov 06, 2008
SOURCE: AEG Favorit Sensorlogic turbodry
I need to know manufactures year of AEG favorit 80860
Posted on Oct 29, 2009
reddyanantha
  • 205 Answers
SOURCE: My mums AEG favorit sensorlogic dishwasher has
please check the timer
Posted on Nov 06, 2009
SOURCE: My AEG dishwasher - Favorit no. 60870 sensorlogic
I don't have the answer - but mine has been doing this too. There's now a metalic/electical smell that has me worried so I've resorted to a basin of water and fairy liquid! Did you solve your problem?
Posted on Jan 24, 2010
Why my AEG F55080vi stops after drain cycle (program beginning) and then it stops and I hear 2 beeps and 2 flash continuously?
Definitely, water drain time-out. Error code i20.
The pressure switch doesn't return to EMPTY (1-2) after two drain phases lasting 120 seconds.
Possible causes:
Drain circuit obstructed/blocked; drain pump
interrupted or jammed (foreign bodies); level
pressure switch blocked on FULL (1-3); hydraulic
circuit of pressure switch obstructed; wiring faulty;
circuit board faulty.
Thanks to your detailed description of failure I conclude that in drain phase (after starts drain pump) leaks water and causing a short circuit. I would thoroughly reviewed drain hydraulic circuit. If is alarm displayed and there is no water inside dishwasher then check heater and anti-interference suppressor.
Dado
Jul 12, 2014 | AEG Dishwashers
Aeg electrolux dishwasher wont wash just keeps beeping
well there are several possibility's. What was the washer doing? Rinse or cleaning? If there is standing water in the tub, then the pump went out or is clogged.
Dec 04, 2012 | Dishwashers
I have an AEG Favorit Sensorlogic Turbodry and it wony start. You switch it on and the onlycycle button that lets you press it is AUTO but it does nothing and then after a couple of minutes it just starts...
could be the drain pump thats blocked /jammed or faulty. the first 2mins the pump is energised if it does not run the electronics sense this and cancel the prog. Also similar if no water supply or if water valve faulty after 5mins. Dont think it will be aqua flood control as pump would run and alarm sound instantly. more mysterious problems can be heater down to earth. and lastly the electronics itself.check the others first though.
Aug 24, 2010 | Dishwashers
Our AEG Favorit Sensorlogic dishwasher has had no power to it
Open the lower front panel and locate where the water inlet hose is connected. Shut the water off under the sink, disconnect the hose at the water inlet solenoid, then put the loose end into a bowl or pan and turn the under-sink valve on slowly. Do you get water flowing from the hose? If so, then check the solenoid water inlet valve for damage. If the coil is ok, the valve part may be stuck closed. It should make a firm 'click' when the timer is set to start the machine (leave the hose loose). If it doesn't click, the coil may be bad, the valve may be stuck, or the timer is not sending 115 volts to the solenoid. Try a new valve first. If still no click, you may need the professional service. Good luck!
Mar 26, 2010 | AEG 23 in. Favorit 50750Vi Built-in...
My AEG Favorit Sensorlogic Turbodry dishwasher is making 3 short continuous beeps which I understand means the leak prevention system has kicked in. Is there something I can do to reset or must I call a...
Open the left metal panel, if the white plastic tank is black at the bottom or is not clean: remove it, open it, clean it (make sure the water flows through properly) and put it back in.
Mar 04, 2010 | AEG 24 in. Favorit 80860iW Built-in...
My AEG dishwasher - Favorit no. 60870 sensorlogic - is making a strange noise when on - what should I do?
Nov 09, 2009 | AEG 24 in. Favorit 60870M Free-standing...
Jul 31, 2009 | Dishwashers
My AEG favorit sensorlogic turbo dry dishwasher keeps bleeping and want start. Im not sure whats wrong with it. I have cleaned the filters and put in new salt and it still wont work. The programme...
hey
good luck
Jun 09, 2008 | Dishwashers
Dishwasher is on before I physically switch it on
Support AEG Australia
I don't know what "the timer? has gone" means. You can't clear the timer or reset it? I would call their support. There is also support in the UK. But you can take a look at the following page:
http://www.instructables.com/id/How-to-repair-your-AEG-or-Electrolux-dishwasher
No diagnostic codes?
Error codes for AEG Dishwasher
Oct 29, 2017 | AEG 18 in. Favorit F54850 Slim-Line...
Dishwashers Logo
384 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Garth Jackson
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
