Question about Nextel i95cl
How can I load ringtones for the i9? - Nextel i95cl
Change the ring tone
The MINI is NOT the same as the normal I9 or 168+ in the way ringtones are setup.
From Second Main Menu page, select 'Profile' on the I9 MINI and then select 'General' then 'Customize' then 'Tone Setup' then SIM1 or SIM2 depending on which you are using/setting up. Now you can scroll through the ringtones to select a new one. All other ringtone related setup can be set through these menus...
Jul 05, 2010 | Uniden Cordless Phone
How do i use any mp3 songs a a ringtone. my phone is I68 I9 P168 UNLOCKED PDA CELL PHONE Sciphone Mp4 . i cannot find a way to set a ringtone.
It's quite hidden. Select the following, starting form the main screen:
Settings
>> User Profiles
>> General
>> Profile Options
>> Customize
>> Tone Setup
>> SIM1/2 incoming call
Options 26 to 30 are marked <empty> and if you select them you can assign an MP3 from there
Nov 10, 2009 | Lands Phones
I can't open mms messages on my i9 phone and how do yu down load music and ringtones to phone?
If you have a USB cable then you might be able to transfer music and things like that. Or else go to vringo.com for free video ringtones.Please give me a rating!
May 10, 2009 | Dual Electronics CECT P168 Cellular Phone
Change ringtone on cect i9
1. At the main menu, select “Settings”
2. Now select “User profiles”
3. In the next menu, select “General”
4. Now “Customize”
5. Select “Tone setup”
6. Choose which SIM (on dual SIM card phones) you want to assign a ringtone to.
7. You will now see a list of available ringtone.
8. Select it.
You should see at the very bottom of this list 5 empty locations this is where you can add your own mp3's as ringtones.
Now I Know your second question once you get this figured out will be how to assign ringtones to individual contacts in your phone book so here is part 2. 1. From the Main menu choose Phone
2. Choose Quick search
3. Find the contact in the list you want to add the ringtone by scrolling down the list and tap on their name
4. Choose Edit
5. Scroll down the list of options to the Musical note called Associate sound and select the ringtone from the list.
Your new ringtone will now function for that contact whenever they call!
Apr 15, 2009 | Dual Electronics CECT P168 Cellular Phone
Can not connect using usb cable from computer to i9
I think i may have had a similar problem getting error around the lines of "Unable to access application data". What worked for me was, restarting my computer and opening the IDEN loader program on my computer first, then i plugged the cable into my phone this seemed to stop the error. i also had to make sure the USB connection was set to Application Access
Mar 23, 2009 | Motorola Cell Phones
How do you set a MP3 as a ringtone on the CECT I9?
HI,I HAVE JUST GOT ONE OF THESE PHONES,I'VE FOUND THAT ONCE YOU HAVE DOWNLOADED THE TRACK VIA PC TO MEMORY CARD,GO TO DOCUMENTS AND COPY TO PHONE...WHEN YOU LOOK AT YOR RINGTONES(BY PRESSING THE PHONE BUTTON) ITS SET BY DEFAULT TO 4,SCROLL DOWN AND LOOK FOR YOUR TRACK,IF YOU CANT FIND IT,TRY THE OPTIONS. THEN IT WILL ASK TO BE SET FOR FREINDS/FAMILY ECT,SO SET IT TO WHAT YOU PREFERE,THE GO TO YOUR CONTACTS AND ADD THEM TO THE LIST WITH THAT RINGTONE....SORRY IF THESE INSTRUCTIONS ARE A BIT PANTS,IF YOU STILL DONT GET IT,I WILL DO IT STEP BY STEP,GOOD LUCK :)
Mar 06, 2009 | Dual Electronics CECT P168 Cellular Phone
Can not change ring tones or other settings on I9 phone
on the seconds screen go to user profiles, choose your profile and select customise then Tone Setup
Choose either sim one or sim two, you will see all the ringtones. now scroll to the very bottom and you will see 5 that say empty.
Select one and then select replace from there you can navigate to a mp3 or other music file
Jan 23, 2009 | Dual Electronics CECT P168 Cellular Phone
How to download to i9 phone
connect your phone to a laptop or pc using the usb cable...the phone will then show threee options....choose mass storage. this will then setup the phone so that you can see the memory avaiable on the phone under mycomputer. there will be two drives associated with the phone...the internal memory and the memory card. when you browse the drives you will see various folders...copy the media to the related folders.....hope this helps
Jan 07, 2009 | Dual Electronics CECT P168 Cellular Phone
I want to load Games on to my cect i9 touch screen phone, can you
I'm sorry to say that that guy is wrong because the CECT i9 does have java depending on who you purchase it from. If you want proof go on youtube and look at some videos of people actually downloading java games to their phone.
Dec 22, 2008 | Dual Electronics CECT P168 Cellular Phone
Cell Phones Logo
61 people viewed this question
Top Nextel Cell Phones Experts
Rommel Balcita
Trisha
Trisha
Shehu Pro
Shehu Pro
Are you a Nextel Cell Phone Expert? Answer questions, earn points and help others
