Question about Sharp FO 4450 Laser Fax
I Have a Sharp FO-4450, there is an error reading as follow's "High Voltage Reading", can you help?
    Problem Solver:
  • 17 Answers
Most likely you will need a high voltage power board. Or a drum or toner contact was damaged. Call a sharp dealership.
Posted on Nov 21, 2009
Is the sharp FO04450 a thermal (roll paper type)
No it is a plain paper laser fax that uses a fine powder to print, called the "toner"
Jan 26, 2012 | Sharp FO 4450 Laser Fax
Our office uses a Sharp FO-4470 fax machine. this morning it is flashing an error on the display of High Voltage Error. Can anyone help with this?
It probably means that the high voltage driver board is blown. You'll have to take it to a service center for repair.
Feb 18, 2011 | Sharp FO-4400 Fax
F2 error
Well F2 error codeis on a variety of Sharp copiers, the F2 error code would normally be accompanied by a sub code that indicates the fault, You may please check out the following -
  • F2 with sub code 00 - Toner Sensor problem, ID pattern reading error;
  • F2 with sub code 02 - Toner Motor problem, check toner dispenser motor;
  • F2 with sub code 31 - Image Density error, Check the light level or the drum surface reflectivity;
  • F2 with sub code 32 - Drum Mark sensor, missing/dislocated mark or sensor faulty. Sensor cannot scan mark properly;
  • F2 with sub code 33 - grid voltage wrong, either too high or too low;
  • F2 with sub code 35 - grid voltage correction will not work during simulation;
  • F2 with sub code 37 - drum mark sensor adjustment required.
You may post further comments for more help or information......
Good Luck!!
Thanks for using FixYa!!
Sep 10, 2010 | Sharp AR-5316 Advanced Digital Imager...
Papers come out with black streeks on them from my sharp FO 4450
If everything is coming out with streaks, it's most likely your cleaning blade which is part of the drum cartridge. I've also seen this from 3rd party toner. Get Sharp toner for your Sharp fax if you don't have it already. If your black streaks are only on copies and sent faxes, this indicates that your scanner is dirty. It's located where you feed your paper in. Lift this part up and you'll see a strip of glass running front to back about 1/2 inch wide. Clean it and that will get rid of lines.
Oct 12, 2009 | Sharp FO-4400 Fax
Sharp FO-4650 fax machine
You have a bad printhead unit(laser unit) only if the problem persist. The polygon mirror is not rotating within a specific amount of time.
Feb 10, 2009 | Sharp FO 4450 Laser Fax
Sharp FO-4450 has ghost images
You probably have a bad fuser unit, but first try a new drum.
Jan 24, 2009 | Sharp FO-4400 Fax
How to reset drum counter
lift up the rapid key flap on the keyboard. press the life key and I think the display will give a choice of press 3 key and enter.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Oct 30, 2008 | Sharp FO 4450 Laser Fax
Drum cost
The price should be in the $50 range.
Here is a web site to compare
http://www.bizrate.com/faxmachines/products__keyword--sharp+fo+4450.html
Mar 13, 2008 | Sharp FO 4450 Laser Fax
Sharp FO-4450 errors when sending to Brother Intellifax 475-0E
Tell me more. What model Brother? Did you call them and make sure the Brother is set to auto receive?
Aug 09, 2007 | Sharp FO 4450 Laser Fax
Sharp FO 4450 Laser Fax Logo
162 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
