Question about Blaupunkt IDC-A09 5-Disc CD Changer
Cd changer will not work
All the lights on my Blaupunkt IDC-A09, 5 cd changer in peugeot 307 (2002) are flashing and the cd player will not work, how can i fix this?
Any assistance would be greatly appreciated
  • 3 more comments
  • HELLPPP Feb 02, 2008
    Hi there i have the same problem wih my IDC-A09 CD Changer.. lights flash from orange to green an i can not eject any CD's.. i hav opened the CD changer an manualy ejected the CD's but still no LUCK!!!
    Any other Solutions???
  • albey Dec 06, 2008
    hi i have a 307 on an 04 plate and my cd 5 disc player doesnt work any more each time you press it it just goes back on to the radio instead it is a blaupunkt one aswell.
  • jfjay Dec 29, 2008
    My cd changer is doing the same. All numbers flashing orange to green and won't eject cds. How did you get them out?
  • Hyddgen Mar 31, 2009
    Hi, I have just bought my wife a wee 307 at auction and she was very pleased to notice the 5 disk changer. Unfortunately I now have 5 CDs in there, 5 flashing lights and nothing else. If I press the source button it usually just switches back to radio but every so often I am asked to load a CD. Is there anything I could do to fix this or is there any other systems that would fit in the slot?
    Appreciate any help you can give.
  • david582 Apr 05, 2009
    How do I get the cd changer out of the fascia?
    David
I had the same problem with my 2002 307SW.
I read on another forum to switch ignition off, remove CD changer from dash and disconnect. It then told me to remove the lid from the case unscrewing the screws marke 1 to 5 then remove the Cd's. The only problem with this is you need a special size 'star' driver bit which i did not have at home and could not unscrew them. What i did was to use a terminal screwdriver in the 2 larger screws that fasten the front plastic cover on the unit. Once I had done that I could remove the CD's.
I then connected the changer back up and inserted it back into the dash. I then powered the radio back up anf loaded a CD and the problem had gone away so I loaded the 5 CD slots and everything works fine now.
Posted on Jan 23, 2008
  • 199 Answers
Ok guys thius it how it works.
Blaupunkt supply a repair kit for this unit, this basically is a fix. but only works for 8 out of 10units.
its a pain to fit too.
you have to replace the 3 spindle guides and arms. the part number is : 8619001490 there a reall complicated thing to fit.
i am looking to get a install guide sorted. and will soon be selling the kits on my website
www.carradiospares.co.uk
Regards
Mark
Blue ICE
Posted on Feb 24, 2008
Peugeot 307 Audio
Anything is possible with a bit of fore thought ,take old one out then try to fit the new one the wiring plugs should be the same for two of them but the third one will work the changer so leave that disconnected
Nov 29, 2011 | Blaupunkt IDC-A09 5-Disc CD Changer
My cd changer came with lead that doesnt work where can i get one from?it is a blaupunkt idco4
Simple answer: Ebay!
Search for "changer cable", it will come up as either peugeot or citreon changer cable
Mar 10, 2010 | Blaupunkt IDC-A09 5-Disc CD Changer
Flashing lights on cd changer, Peugeot 307!
There are a few variations of this model eg; IDCA09,IDCA04,Fiat & aftermarket units.As already stated these models do suffer from mechanism faults quite a lot.This is due mostly to the complexity of the mechanics.The flashing lights are a classic symptom of a jammed or broken part of the mechanism.They can however be repaired by certain car audio repair centres here in the UK.I'm afraid unless you know what you're doing then just by stripping the mechanism down is unlikely to cure the faults than can occur.
Feb 03, 2009 | Blaupunkt IDC-A09 5-Disc CD Changer
5 cd changer on a peugeot 307 has all 5 lights flash but will not play
cd changer off set common fault had it happen three times due to buttons being pressed to quick take changer out remove leads for a minute replace them turn on ignition should reset if not cd drive wiil need to be relined see dealer repaired one but really tricki
Dec 14, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
Peugeot 307 Blaupankt CD Changer IDC-A09
Hi, I know this is an old post, but I'll reply, so that other readers may get the benefit of my answer.
2004 was the year that Peugeot/Citroen changed from VAN bus to CAN bus wiring on their stereo's. If your car is before or early 2004 you will need the IDC-A09 blaupunkt in dash changer, which should just plug in and work straight away.
However, If your car is later 2004 onwards you will need the IDC-A04 Blaupunkt changer which will plug in and power up, but will not work properly untill you go to a peugeot dealer and they hook up some diagnostic software to tell the car a changer has been added. Both the IDC-A04 and A09 changers look identical.
I would say that you got the wrong changer, as the IDC-A09 changers in pre/early 2004 should just plug in and work.
Remember: Pre 2004 cars need IDC-A09 (plug and play) and Post 2004 cars need IDC-A04 changer (get pug dealer to reprogram cars computer)...its a costly mistake if you bought the wrong one!
Oct 28, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
Blaupunkt IDC A09
hi whats your email?
will email you.
mark
Jul 19, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
Cd player
hi does it do anythig at all? does it flash?
Mark
Mar 21, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
Regards
Mark
Blue ICE
Nov 06, 2007 | Blaupunkt IDC-A09 5-Disc CD Changer
Cd-changer Blaupunkt IDC-A09
The solution is to disconnect the head unit and the cd changer from each other and from the car itself, leave it for ten minutes. reconnect and turn the ignition on but not the car itself, enter radio code if has one and all should work.
Sep 24, 2006 | Blaupunkt IDC-A09 5-Disc CD Changer
Blaupunkt IDC-A09 5-Disc CD Changer Logo
2,539 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
