Question about Cell Phones
My ENV 2 wont turn back on
My Env 2 inside screen turned white and then it started turning on and off every few minutes. I took the battery out and put it back in and it worked for a few minutes and then turned off and will not turn back on.
On my env touch there is a black screen wiyh white letters that says battery is requred. i have turned it off and on again nothing changes it
If you do have a battery in the phone, one of two things has probably happened:
1. The battery is not installed all the way, or the contacts are dirty. Turn the phone off, remove the battery, blow some compressed air into the cavity, and wipe down the contacts (on the battery and the phone) with a dry lint-free cloth. Then reinstall the battery and turn the phone on and see what happens.
2. The battery has died. Replace the battery and see if the phone works with a new battery.
Jul 03, 2010 | LG enV Touch VX11000 Cell Phone
Touch screen on my env touch will not work
you can take the battery and the back off the device and place in completely submerged in a bag of white rice and leave it in there for 1 to 2 days this will help absorb the moisture, this should fix it if the water did not damage the circut boards if the water damaged the circut boards then the device is fried
Apr 02, 2010 | LG enV Touch VX11000 Cell Phone
Screen does not light up for code entry
the LG Env Touch Turns it's screen on by motion activation, when you hold it up to your ear, it turns itself off
when you put it in front of you it turns back on
maybe there is something wrong with the tilt in your phone
i have the LG EnV Touch and it is a great phone
maybe you could of dropped it and it wasnt working right now with that feature
Sep 22, 2009 | LG enV Touch VX11000 Cell Phone
Phone stuck on verizon screen
turn the phone off and take the battery out and immediately put the battery back in the phone that usually works on mine
Jul 23, 2009 | LG enV VX9900 Cellular Phone
When I turn my phone on, it comes up with a white screen only. I don't have the model with me. Could it be the battery?
Generaly, the reason for white screen is software or misoperation.
1.Please try to turn off the phone and pull out the battery for a few hours, and then restart the phone.
2. If the screen can be normal sometimes, pls try to "restore the factory setting" by setting. You can find the password on your user manual.
3.Please pull out the SIM card and clean it. Then reinsert it into the phone.
4.By our experience, if several programs opened at the same time, it may cause a white screen. And some files on the phone should not be deleted. This phenomenon may happen to you.
……you may find more details on this :http://www.1010store.com/forum/viewtopic.php?f=2&t=172
May 27, 2009 | LG enV VX9900 Cellular Phone
LG enV 2 not turning back on
If possible take it into your cell providers store and ask them to check it. They should be able to do a battery test and a software check for free of charge. If they are no help check the brass contacts on both your battery and phone. They might be making intermittent contact or be corroded. Also check for water damage. There should be a small sticker, if its pink its water damage. It could also be a defective battery, but don't buy one. Try to find someone that has one and borrow it to test. Good Luck
Apr 18, 2009 | LG enV2 VX9100 Cell Phone Car Charger
I dropped my LG enV into a puddle of water.
Sounds like you will need a new battery. My env2 would only work if plugged into the wall charger after I dropped it in the toilet. I got a new battery and it works fine now!
Mar 12, 2009 | LG enV VX9900 Cellular Phone
Wont turn on - goes to black screen w/ "Verizon Wireless" Logo
its the short circuit in main board chip ic number IC431 OR IC436 check out .that faulty ic needs replacement.
Mar 05, 2009 | LG enV VX9900 Cellular Phone
Battery is required
I already fixed my problem. I'm not sure how...? I just took the battery out a few times and wiped it off with a clean, dry cloth and eventually it started working. Thanks though.
Apr 06, 2008 | LG enV VX9900 Cellular Phone
Cell Phones Logo
91 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
