Question about Onkyo TX-SR605 Receiver
My Onkyo receiver is stuck on DVD multichannel and will not shutoff and volume is locked in at 45. I am unable to switch the input source, turnoff the receiver, or turn off the unit.
  • 336 Answers
Check for a stuck switch. If all the switch feel okay, Try to reset it. Check your owners manual it may tell you how to do it.
Posted on Nov 16, 2009
I cant get sound from my tv thru my ht-r380 reciever
This is most likely a connection or switch problem:
  • Make sure you are plugged into the appropriate sound out jacks on the TV
  • Make sure you are plugged in to the appropriate sound in jacks on the receiver
  • Make sure the source for the receiver is set correctly
  • ensure volume is set appropriately
  • ensure correct speakers are selected.
If you are playing a DVD, the input to the receiver should come from the DVD player
Jan 10, 2015 | Onkyo Audio Players & Recorders
I turned on my receiver and I do not get any sound, unless I crank up to max and then I get faint audio. The same when I use the head phone jack
NEVER USE MAXIMUM VOLUME FOR TROUBLESHOOTING.
Turn the volume control to something medium.
The errant switch, control or condition may change and you will suddenly release the amp's full power and possibly destroying your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Carefully examine the front panel for clues like a misplaced Source Selection, Mute, Tape Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead' spot through defect or idleness and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
Turn the volume to something reasonable and see if that helped.
Aug 07, 2011 | Onkyo Audio Players & Recorders
Unable to connect a blu ray dvd player to onkyo tx-sr605 via hdmi
Not sure what unable to connect means..but I will assume you have the correct cable.
First make sure you have plugged the from the HDMI cable from the DVD play into the IN 1 HDMI port on the back of your Onkyo
On the Receiver
Enter the Setup mode
Select INPUT OUTPUT ASSIGN
Next make sure the HDMI monitor out is set to YES on the Receiver
Monitor out
HDMI Monitor - YES
Next you need to assign the HDMI INPUT to DVD
HDMI INPUT
DVD - IN1
CBL/SAT - IN2
This may be your issue.
Next step would be to verify your television input settings.
Nice receiver!
Best of luck!
Apr 13, 2011 | Onkyo TX-SR605 Home Theater Receiver 7.1...
I HAVE A ONKYO TX-910 RECEIVER THAT I PURCHASED IN 1993. IT PRESENTLY HAS NO SOUND. SHOWS POWERED UP & REMOTE CONTROL WORKS. HAVE CHECKED ALL THE SPEAKER WIRE CONNECTIONS & THEY ARE FINE. CAN THIS...
Carefully examine the front panel for clues like a misplaced Mute or Tape Monitor control or Multichannel Analog Input selected.
Apr 09, 2011 | Onkyo TX-910 Receiver
My onkyo tx-8222 suddenly stopped amplifying on both speakers and headphones. I can hear music faintly with the volume at max (just the pre-amp?). Time for a new amp?
Never use maximum volume for troubleshooting. The errant switch or control that you eventually find and flip will suddenly release the amp's full power and you'll destroy your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Look for a misplaced Mute or Tape Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead' spot through idleness and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
Feb 21, 2011 | Onkyo TX-8222 Receiver
I have been using dolby 5.1/dts in this machine without any problem till a couple of weeks back but suddenly it does not pick up either mode-all it keeps saying is it is set to dolby pro logic. Any ideas?
Which source(s) do this? Only multichannel digital audio in will light up those modes. Perhaps a setting in your source is the problem or your digital cabling is loose/defective.
http://www.retrevo.com/support/Onkyo-TX-DS676-Receivers-manual/id/365dj193/t/2/
I'd go through the digital input setup to make sure the receiver is set the format to Automatic for everything unless you have an overriding reason to set it manually. Page 29.
Jan 16, 2011 | Onkyo TX-DS676 Receiver
Yamaha RX-V365 unable to receive 5.1 audio from TV with HDMI
If you're expecting multichannel sound FROM THE TV instead of from the source you're watching, it's not gonna happen. TV's are notoriously poor sound sources. This one is no different.
Multichannel TV-related audio is best found at its source - cable / sat / dvd / bd....
I run video-related audio from my video sources directly to my TV and their audio directly to my receiver. Specialization yields best results.
I'd recommend skipping the Receiver for video, too, as it adds a lot of opportunity for HDMI-related incompatibilities and sound syncing problems. The more interconnects in the path, the more distorted it will become and the more opportunities for problems. Plus you can bypass the receiver and listen to lo-fi programming like news and weather through the TV's speakers if you like. Save a buck on electricity.
Just curious, which HDMI on the receiver is connected to your TV? Input or Output?
This note is on Page 11 of the manual:
Audio signals input at the HDMI jack are not output from any speaker terminals but output from the connected video monitor. To enjoy the sound from speakers connected to this unit,
-- make an analog or digital connection besides the HDMI connection (see page 13).
-- mute the volume on the connected video monitor
"Check SP cable." -- The unit is perceiving a short circuit. Are your speaker impedances sufficiently high? Disconnect the Front Right speaker and try raising the volume again. The speaker may be blown or the cable shorting.
Apr 30, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
Receiver acting weiard
Again, onkyo has downloadable cd software (its free) that you run threw cd player via fiber optics that will fix the issue. onkyo.com,choose region,click support at the bottom of page find Download Center or
Software Downloads/Updates: for info. With onkyo its usually a simple chip issue. If that fails , find contact support , e-mail them your issue and simply ask for a downloadable repair disc- I did.
Aug 20, 2009 | Onkyo TX-SR606 Receiver
Assigning inputs or selecting the type of vidio stream i want to use for my dvd player.
Not sure if I understand completely, but if you want to watch a source on DVD then then it needs to have its a/v outputs connected to the DVD inputs on the rear of the receiver.
Aug 22, 2008 | Onkyo TX-SR602 Receiver
I have a Onkyo 805 Receiver that while I was listening to DVD Video in DTS Mode the sound stopped and the TV went to input. I noticed the Display on the Receiver said E2PROM ERROR. Now I can't get anything...
WILL TRY TO GET A SOLUTION FOR YOU IN MORNING CALL ME ON 02870342354 LARRY. I HAVE NOT SEEN THIS ERROR BEFOR AND I SELL ONKYO IN THE SHOP I WORK IN,(LIGHTING,SOUND,AND VISION) IN NORTHERN IRELAND OR EMAIL ME AT LSVNI@YAHOO.CO.UK
RICKY.
Jun 19, 2008 | Onkyo Audio Players & Recorders
Onkyo TX-SR605 Receiver Logo
521 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
