Question about Itronix GoBook III Notebook
Screen is to dark. cannot see letters very well.
  • Itronix Master
  • 5,660 Answers
Suggest you press the Fn key And the key to increase brightness, first. (Should be a key that has a sun icon on it)
Barring this does not increase the visibility of your LCD screen, the I suggest the Backlight is bad, or the Inverter.
The Backlight is a type of CCFL tube (Cold Cathode Fluorescent Lamp) mounted to the LCD screen. The LCD screen needs the light given off of the Backlight.
Replacing the Backlight is a daunting task, and if done wrong, will cause possible damage to the LCD screen.
The LCD screen itself has a thin metal frame holding the components of the LCD screen together. This frame must usually be opened on the side that has the backlight, to access the backlight. The components that make up an LCD screen are fragile, and can easily be damaged.
The Inverter supplies power to the LCD screen, as well as the Backlight.
Inverters do go bad, but commonly it's the Backlight to go first.
This shows a typical Backlight replacement. It IS not an advertisement to attempt this yourself, but a reference tool for information.
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
Posted on Nov 16, 2009
How do you fix a black and white wii screen
What exactly is the screen doing? Is it black? Is it smearing? Is it showing only some letters and then very smudged and very dark letters?
Since it is likely that the screen you are talking about is an LCD or LED device, it is a sandwich device that is made up of various layers of electrically conductive material. The letters are formed via impulses that come to the back of the device and which then light up certain points while leaving others dark. The result is the display.
If the display is smearing, then it is likely that the conductive gel is leaking a bit within its cell-like space or it is likely that the rear electrical contact pad has been damaged, perhaps by an overvoltage condition. In this case, there's not much that you can do, other than replace the device, if that is at all possible (some devices are integrated into the device itself and the only way to repair it is to replace the entire device -- plug-out-plug in).
If the device is black, then it indicates the it is gone and has to be replaced. The same is true only if some segments are showing while others are not.
Let me know if this helps.
Feb 02, 2015 | Nintendo Wii Console
The screen is really dark
Locate the Fn (Function) key on your keyboard. It may be on the bottom left side with dark blue letters. Locate the two "brightness" keys near the top of the keyboard. These will be in the "F" keys, possibly if F6 and F7. They should have little sun pictures or something similar to indicate brightness. Hold down the Fn key while pressing F7, or whichever "F" key your laptop uses to increase brightness. Tap F7 repeatedly until you reach the desired brightness. Fn must be held down as you continue to tap. Hope this helps.
Dec 07, 2012 | Intel EasyNote E4 715 Notebook
The monitor was not bright enough. I can see the screen letter or pictures but display panel is so dark.
Sounds like you have an LCD screen whos backlight has gone. you can replace them but you need to search out the correct size and model for your screen.
try searching ebay
Jun 01, 2011 | Computers & Internet
The background cycles between dark with white letters and bight with dark letters, any idea on how to stop it from cycling and stay on dark background with white letters?
you need to press either the #5 or #6 preset button while the deck is in standby mode. putting the deck in standby mode should tell you which button to press.
Feb 14, 2011 | Pioneer DEH-P4200UB Car CD / USB/ MP3...
My display total dark. but slightly can see letters and all. i changed screen. but problem same. how can i solve that problem
The problem is with the backlighting CCFL tubes, they aren't powered. Take the screen apart and check them - if the tubes are ok then verify the inverters that is powering them.
Oct 21, 2010 | Acer ASPIRE 5720-4649 Notebook
When the screen is dark there are lines that run back and forth across the screen which is only noticable when pitcure is dark immage.
the screen bias needs to be turned down-ehind the front cover which is behind the grille there is a small black square about 3 inch square 6 little knobs sticking out 3 say in small letters screen and 3 say focus, don't adjust the focus just the screen for the coresponding color that shows up when picture is dark.best way to do this is darken the room and put it on video input with no signal if lines are white slowly
adjust 1 color after the other counterclockwise untill
lines disappear if only 1 color shows then only adjust the knob with the matching color. this is a very fine adjustment, to much will make your auto focus stop working. check it after you are done
Jun 20, 2010 | Sony KP-51HW40 51" Rear Projection...
Letters and numbers too light to see properly, especially in class!
Increase screen contrast.
Press [2nd] key and release it.
Press and HOLD the Up Arrow to daraken the screen
Keep pressing Up Arrow until display is dark enough for you.
Jan 22, 2010 | Texas Instruments TI-83 Plus Calculator
My screen went dark suddenly, when I try to restart my computer the screen is tinted red before going dark again. The screen is not completely black as there is letter visible underneath.
From what you are describing, it sounds like the inverter board is failing. This board sits under the LCD screen and is responsible for taking the DC voltage from the battery and AC adapter and converting that voltage to high voltage AC power for the backlight lamp that sits inside the lcd screen. Without that high voltage the screen goes dark. Most inverters do not fail right away, there are voltage fall offs etc. Inverters are approx. 15-20 bucks on ebay, for most laptops, they can be changed out simply by removing the bezel around the screen, unplugging the two connectors on the inverter and changing it out. In most cases except Dell, the inverter is just sitting in there and is not held in by screws.
Nov 30, 2009 | Toshiba Satellite A100-S8111TD Notebook
Garmin eTrex Legend GPS
A dark screen might be the result of a poorly adjusted display contrast. This can be altered by accessing the Setup menu and selecting Display.
Feb 01, 2008 | Garmin eTrex Legend GPS Receiver
Itronix GoBook III Notebook Logo
531 people viewed this question
Top Itronix Computers & Internet Experts
Larry Chandler
ccsi99
justwinwin
Are you an Itronix Computer and Internet Expert? Answer questions, earn points and help others
