Question about Sanyo DWM400 DVD Player
Please help i have lost my manual and i am trying to set up the dvd player with the tv and sky
  • Anonymous Apr 28, 2008
    dvd shows black & white
  • 205 Answers
You can find the manual here:
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=b7a9e24543cb9cdef7c4e094fb734a9a&q=Sanyo+DWM-400
They will make you enter your email address if you want to download the manual.
I'm not sure you'll need the manual if you have a newer TV and want to hook this up the way most people do.
Just about all new televisons have a variety of video inputs. Typically you use one for your Cable box, one for your DVD (or VCR). When you wish to watch cable you "tell" your TV you want to view that input and when you want to watch the DVD player you tell the TV that's the input to use. Most Cable Box remotes are set up to control the TV so you can change the input without having to use the original TV remote. You can also, generally, change the TV input from the front panel of the TV set. If you give me the make/model of your TV I may be able to help you figure out how to switch inputs.
But back to the DVD. I downloaded the manual and this DVD can generate output in a few different formats. The easiest will probably be the jacks numbered 2 which is the Audio There are two them, one is RED, and one is WHITE, and jack number 4. This is the Video and will be YELLOW in color. I'll be the DVD player came with a cable set that has three connectors on each end. They will be colored YELLOW, RED, and WHITE.
You should simply need to plug one end of this cable set into the jacks mentioned above on the DVD player and then plug them into one of the inputs on your TV. Pay attention to which TV input you use because you'll need to select that input to watch the DVD.
If you have an older TV we will need to use a different method to hook up the DVD player.
Now for the editorial section. I'm not paid for this. I know it's a strange hobby, but I like helping when I can. If you have more questions please ask before you rate this solution. If anything I've offered here has been helpful I hope you'll rate this solution positively. About half of the solutions I've offered have never been rated. Thanks and good luck.
Posted on Jan 09, 2008
  • Anonymous Jan 10, 2008
    no comments, no questions, no rating....makes you wonder why any of us bother to answer questions...
    New Friend:
I need to hook up my sanyo dmw400 to my new sanyo 32 lcd what cables do I need and how do I hook it up.
Posted on Dec 27, 2009
6ya staff
SOURCE:
I own a Daewoo DH-6100P DVD player/recorder and I am unable to get the set up menu to appear on the TV screen. The TV and DVD player are connected to a Sky Box. Can you help please? Keith Saunders
The model is DH-6100P, 80gb HDD crashed then formatted it. Now no start-up menu, stuck please help with solution or firmware file for re-install if possible.
Feb 28, 2011 | Daewoo Televison & Video
Unable to set TV channels on dvd recorder since connected to Sky box
Actually you don't have to get other devices, Just cables, take the sky box output and connect to AV input of DVR
Feb 18, 2008 | Televison & Video
Useless at setting up. No sound on playback. Blocked timer record
You won`t get round the scan without an aerial.You still can set a recording as long as you set the recording channel as av2.Make sure the scart lead is fully in on dvd and tv,this can lead to no pic but sound,or sound no pic
Oct 27, 2009 | Televison & Video
How do I tune it into Sky channels (lost manual)
i have tried to tune in a sky digibox that have not used for a couple of years,i can only tune in the first 9 chanels for some reason.any clues what i am doing wrong
Apr 13, 2009 | Televison & Video
No suround when watching tv with sky + box,
You will need a DVD player with an optical output, as the sky engineer said. A Co-axial S/PDIF output could also work if your surround sound has that input, however not all units transmit surround encoded sound through the Co-Axial output. Only option really is to upgrade if that doesn't work
Mar 05, 2009 | Televison & Video
Sony DVD RDR-HX650 - set up
Sony UK has info how to hook up this unit. Please check there.
Sep 05, 2008 | Televison & Video
Remote code
You won't be able to use it for your dvd player unfortunately.
The code for sky is 0145.
1) Switch on the TV set
2) Press the TV button on the Sky Remote
3) Hold down the select and red buttons for 2-3 seconds until the LED blinks twice
4) Press the TV button on the Sky Remote again
5) Enter the 4 digit code for your make of TV
6) The LED should blink twice, if not recheck the 4 digit code used and go back to 1
7) Press the standby button on the Sky Remote (The TV should go to standby)
8) Press select to store this setting
If the TV does not go into standby press the TV button then the standby button, then TV then standby, keep repeating this until successful.
Gaz
Jan 14, 2008 | Hitachi CLU-4324UG Remote Control
Omega urc-08 device codes
Original link no longer working. Found this: http://files.remotecentral.com/download/220/urc08-manual.zip.html
Comment if it's wrong one.
Nov 22, 2007 | Televison & Video
Sanyo DWM400 DVD Player Logo
190 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
