Power port Hi all ! .. Hope you can help i have a Packard Bell Easyone 3100 the problem is on the back of the laptop where the cable plugs in to the port..the port is pushed in side ..now at the moment i have to be very careful when useing how to i fix this or fish it out ? a mate told me i might have to replace the motherboard ..if you can help that would be brilliant
  • pants77 Jan 11, 2008
    Thanks for getting back so fast !!
    To bring you up to date i have took the laptop down to the motherboard (lots of screws) and it is the power jack has come away from the board and 2 wires have been solderd on to the motherboard to replace it ..now i have never done any soldering before so i might take it to a shop but then i need to look at the prices any idears for this or for a power jack ?
    Thanks again
  • pants77 Jan 27, 2008
    Thanks again ..i decided in the end to take to a shop ..thay had just opened aweek or so and thay said it would cost 5-10 pounds which i thought was a very good deal and works lovely ..so now ive decided to get wire less router but i dont know which one to get theres one with a usb and another with a card that slots into the laptop help any ideals ?
  • 589 Answers
No, you don't need a new motherboard.
Unless you're comfortable with taking the laptop apart down to the motherboard, and soldering in a new power jack, take it to a repair shop.
Posted on Jan 09, 2008
  • brian c
    brian c Jan 27, 2008
    I would get the PCMCIA card.
    You may also want to see if your laptop is internal wireless capable - internal cards are relatively inexpensive compared to PCMCIA cards or USB adapters.
    As far as the difference between them, it's all personal preference. They both work well when configured correctly. It just depends if you want another cord laying around your computer area, which is why I prefer the internal cards or PCMCIA.
    However, with the USB models, you can move it around for better signals (depending on the length of the wire). Some guys run a 6 foot USB extension wire on them, and put the unit on a window sill, etc.
What mean plug on battery icon when Pc is charged and cable is reamoved
Check the power settings, if they are ok contact Packard bell support as there is problem with the laptop. http://www.packardbell.co.uk/pb/en/GB/content/online-support
Jan 24, 2014 | Packard Bell Computers & Internet
I have no ethernet controller on my laptop packard bell dot se, what to do?
#1 google your specific packard bell model,#2 choose only a packard bell site,#3 select downloads & drivers, #4 again enter your specific model, this will take you to the ethernet controller driver section, after download extract all
Jun 19, 2012 | Packard Bell 1580509280 Network Adapter
Why wot it let my packard bell easynote r4250 connect to a tv through a VGA ports
There is not enough info here. Many things could be wrong. Are you actually plugging the VGA cable into the VGA port on the tv or computer? Does your tv even have a VGA input? Is your tbs input switched to the tv? Please contact me with questions.
Feb 28, 2011 | Packard Bell EASYNOTE R4250 COMPATIBLE...
Im using packard bell butterfly s-fc-002ac laptop..my problem is the battery is not charging even if it is connected to an adapter. the battery status always indicate: 7% available (plugged in, not...
Hi, There is a possibility of problems in:
  1. the adapter that you are using might be defective
  2. or the port for the power is not working
  3. or the battery fault issue
What you can do is to try another outlet to see if the outlet itself is the cause. Cheers!!
Sep 01, 2010 | Packard Bell Computers & Internet
Burnt out power board
I sympathize with your problem, but I think you are knocking at the wrong door. You should contact your local Packard Bell dealer.
Hope it helps
Aug 28, 2009 | Computers & Internet
My packard bell has stoped charging
If your laptop has stopped charging and you've already replaced the AC adaptor, then most likely it's either the battery itself or the power port on your laptop. If the battery was fine up to that point then it's probably not the battery. To replace the power port can sometimes involve soldering the new port onto the motherboard of your laptop so it's usually best left to a professional. The port you can usually find on ebay. I've replaced a few that is just a small power board that plugs into the mainboard but other have to be soldered. It's not really hard to do, but it involves dismantling the whole laptop to gain access to the motherboard and sometimes requires soldering. Sometimes its very obvious and you can tell by trying to move the metal pin in the center of the plug on your laptop where it plugs in. If the center prong moves then it has become detached and must be replaced. If not it could also be a connection problem due to corossion. Without pulling it apart and looking at it, it can be hard to tell. Deptending on the extent of the work, it can cost from 50.00 - 200.00. I hope this helps.
Apr 17, 2009 | Packard Bell Easy One Silver 2120 Notebook
Can someone please tell me where the hard drive of Easy one is?
Take out the floppy drive and it is sat on the top. the floppy drive is the craddle for it.
Apr 17, 2009 | Packard Bell Easy One Silver 2101 Notebook
Ram change on Packard Bell easyone 2120
Memory Upgrade Instructions
128 MB SDRAM on-board, max. 256 MB upgrade (384 MB total), PC-133
Remove the memory module according to these steps:
1. Turn off system power.
2. Remove the battery and disconnect the AC-adapter.
3. Open the top cover.
4. Press the locking latch downward to unlatch the Easy Start panel.
5. Then push it leftward and lift it up from the left side.
6. Slightly lift up the keyboard and disconnect the cable from the system board to free the keyboard.
7. Pull the retaining clips outwards (1) and remove the SO-DIMM module.
Keith Stoffer
Comptia A+ Certified Technician (20+ years)
Oct 30, 2008 | Packard Bell Easy One Silver 2120 Notebook
Pb navigator
I would not recommend it, it is very old software..
Sep 18, 2008 | Packard Bell Easy One Silver 2101 Notebook
Computers & Internet Logo
133 people viewed this question
David Payne
David Payne
