Question about Kenmore 24032\24036 Top Load Washer
I have a kenmore 70 series 110.24712300 washer that wont drain? I had just wsshed a rug in it that lost alot of its "fluff" Do you know what may be the problem, the drian pipe is clear. Thanks
    President:
  • 1,865 Answers
The fluff may be stuck in the propeller; you'll have to disassemble the machine down to the propeller to inspect/clean it
Go to this link and enter your model number, it will provide you with exploded view drawings of your unit to help you with the disassembly
http://www.searspartsdirect.com/partsdirect/index.action
Posted on Nov 16, 2009
Testimonial: "thank you very much <3"
How to remove the timer?
HERE IS A LINK TO YOUTUBE VIDEOS CONCERNING YOUR WASHER..... BUT I DIDNT SEE ANYTHING ABOUT A TIMER. I HAVE REPLACED KENMORE TIMERS....PULL OFF THE KNOB...
REMOVE THE SCREWS THAT HOLD DOWN THE COVER WHERE THE TIMER IS LOCATED.... ONCE YOU HAVE THE COVER OFF..... GET YOUR PHONE OR CAMERA AND TAKE A PICTURE OF WHERE ALL THE DIFFERENT COLORED WIRES ARE LOCATED...SO YOU WONT BE LOST WHEN YOU INSTALL THE NEW TIMER.
https://www.youtube.com/results?search_query=HOW+TO+REMOVE+A+TIMER+Kenmore+Series+70+Washer+Motor+387780
Dec 02, 2014 | Kenmore Series 70 Washer Motor 387780
Kenmore he2t
fluff may have blocked the filter or jammed the drain pump. you need to check these
May 07, 2014 | Washing Machines
How do i determine if my switch is working on my kenmore 70 series washing machine
i think there is some problem in wiring of spin and drain. thats y it works only for washing. current stops after washing. or otherwise click below link and check the manual may be its timer problem
http://www.askmehelpdesk.com/appliances/kenmore-washing-machine-70-series-repair-manual-479481.html
http://www.askmehelpdesk.com/appliances/kenmore-series-70-washer-manual-445690.html
Jan 04, 2012 | Kenmore Washing Machines
Washer wont agitate or stop filling on any setting
Hello Friend, Just replace the water pressure/level switch. Replacement will make it fill correctly and agitate. Happy to help.
Nov 18, 2009 | Kenmore 24712 Top Load Washer
My washer wont spin out
I believe these are made by whirlpool and use a rubber coupling to connect the drive motor . they are five dollars and change in half an hour if your half way mechanical.
Oct 29, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series slow agitator
You have burned the clutch this must be replaced
Jun 09, 2009 | Kenmore 15864/15862 Top Load Washer
Kenmore@Heavy Duty Washer - 70 Series
ck lid switch ..rug may have gotten off balance first spin and broken lid switch
Aug 28, 2008 | Washing Machines
Kenmore 70 series
First thing is to remove the 2 screws from the console, they may be hidden in the front or bacl of console. After removing screws, lightly push the base of the console towards the front of the washer and pick up. This will expose your lid switch connection. Using a jumper wire, jump out the black and white wires then try advancing your washer into spin/drain. The culprit will usually be the lid switch assy.
Apr 04, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
599 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
