Question about Compaq iPAQ H3850 Pocket PC
I have lost my Cd-rom for my ipaq h3850 and i can't get it to sync or get internet. what can i do?
I have lost my cd-rom since then my pocket can not snych
Posted on Nov 30, 2009
I can not figure out how to connect my device to the internet Wi-Fi, I want to go on internet explorer and it won't connect
To send and receive e-mail with Inbox and view Web sites with Pocket Internet Explorer, set up a remote connection using a modem card or an Ethernet/LAN card.
To connect to the Internet with a modem card, you need a phone line, a dial-up Internet Service Provider, and an optional Single-slot or Dual-slot PC Card Expansion Pack or CompactFlash (CF) Card Expansion Pack.
*Insert your modem card
*From the Start menu, tap Settings
*Tap the Connections tab->Connections Icon-->Internet Settings-->Modify-->New
*Enter a name for the connection, select the modem type, and select the correct baud rate for that modem.
I have shared the basic steps..which I refereed using the reference guide for the model that you have specified from this website.This you can easily get my typing "reference guide for Compaq iPAQ H3850 Pocket PC" in Google...and the first link lets you download the PDF..Follow the steps carefully and connect to the internet.To check for the internet speed you can use Scanmyspeed.com which gives you accurate speed results.
Oct 28, 2013 | Compaq iPAQ H3850 Pocket PC
NEED TO DO A HARD RESET ON H3850....
Hello!
To do a full reset, simultaneously press the two outer application buttons and the reset button on the bottom of the handheld for 10 seconds.
This should help!
Mar 15, 2011 | Compaq iPAQ H3850 Pocket PC
Im trying to access the internet through my ipaq 3800, can anyone hekp with this?
hi thanks for using fixya!
If you want to access the internet thru your ipaq, you should first contact your network service provider to send you the GPRS configuration and settings. From then, you may now enjoy the connectivity of your ipaq.
Regards!
Apr 22, 2009 | Compaq iPAQ H3850 Pocket PC
Ipaq 3850
Here's an eBay auction for a the ipaq, cradle and cover, no bids yet.
There are also a number of chargers available. A Google search also returns several vendors for ipaqs and accessories.
Apr 02, 2009 | Compaq iPAQ H3850 Pocket PC
Lost instruction manual for iPAQ H3850 Pocket PC
http://www.kolyasoft.com/pocketpc/ipaq3800specs.pdf
May 14, 2008 | Compaq iPAQ H3850 Pocket PC
Pocket pc 3850
Set it up with what? Do you mean sync with your computer? Are you using USB or Bluetooth?
Best thing to do.
1. Unplug your USB connection from PPC -> Computer
2. Uninstall Activesync if you have it installed
3. Restart your computer
4. Re-install activesync
5. Restart your PPC
6. When asked to connect the PPC connect it via USB
Jan 06, 2008 | Compaq iPAQ H3850 Pocket PC
I can't make my IPAQ pass the align screen
Use Active Sync, explorer the folder contents on the device, move to the windows folder, delete the file welcome.exe. Soft reset and should work.
Sometimes you have to end all Active Sync tasks, rapimgr.exe, wescomm.exe and WCESmgr.exe. After you close all these, reopen Active Sync, should then be abel to connect your device and try again.
-m0gliE
Dec 19, 2007 | Compaq iPAQ H3850 Pocket PC
BLANK Pocket PC ! - iPAQ 3885
Yes, I did. Actully for my model it is at the bottom. I used that along with RESET key - which makes 'Hard Reset' - but the same Red screen remains....
Sep 12, 2005 | Compaq iPAQ H3850 Pocket PC
How to get a CD-ROM program to run?
You're probably going to have to set up an ActiveSync connection between your PC and your 2415, then run the program installer on your PC while you're connected to the iPaq.
Sep 11, 2005 | HP iPAQ HX2415 Pocket PC
Data erased from iPAQ hx4700
If an ipaq loses power , then all data in RAM is lost. It's important to keep it charged. It's also important to do regular backups..... so there are two backup options - one is thru Activesync which will backup to your PC and one is the IPAQ's own backup program which will backup to the IPAQ FILE STORE (area in ROM) or a SD card. I do the Activesync backup every time I sync and then the IPAQ backup about once a week or immediately before a system change. Activesync backup ------------------------ Here is a guide which best explains it http://www.cewindows.net/faqs/activesync/backup.htm this guide suggests doing a full backup, but it's fine to do an incremental backup each sync - this means that only changes will be added to your backup and makes the whole process much quicker. IPAQ Backup ----------------- So under Programs is a program called IPAQ Backup. The default location is IPAQ FILE STORE which is an area in ROM and is not lost thru a power failure nor hard reset. You may also choos to backup to a SD card - a full backup will need roughly 20MB. So in this backup procedure, if you click on 'Browse' you can choose a SD card. A restore can then be performed from the IPAQ FILE STORE or SD card (depending on which location you chose) and so if you are away from your PC, this will be no problem. A restore this way , rather than thru Activesync is also much quicker, so if you have a choice go this route.
Sep 11, 2005 | HP iPAQ HX4700 Pocket PC
Compaq iPAQ H3850 Pocket PC Logo
318 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
