Question about Refrigerators
Ice forming on the consensor coils - next to the condensor. Sign of; a). Low freon b). Freon blockage Something else..?
  • m_j_levy Nov 17, 2009
    Thanks for the notes. Productive comments. Model number is GE ZIC36N.
    Additional details:
    1. Inconsistent warm and cold - i.e. was warm 2 days ago, cold now
    2. I have been fiddling with it. Letting it get to room temperature and then turning back on
    3. Repair guy came out - did a Freon test - couldn't get anymore Freon in - though the reading was low pressure
    4. Repair guy speculated a blockage in the freon line ?
    5. I noted the filter on the compressor coils was filthy, filthy - thick with muck. Have cleaned - however the unit has still displayed some inconsistent cooling
    6. Today I noted that the in/out coils to the condensor happened to be touch slightly - at least a copper line was passing them both and touching. I have subsequently seperated them to make sure they are no longer connected
    7. I welcome and will compensate good advice. I really want to know if this guy is just showing age anyone and should be given last rights or... continue to work on repair - it is a nice buit in, so has some value - but not much more patience.
    Look forward to your comments.
    FYI - share with the developers of the site that they need to allow for uploading images. Especially with an easy i-phone plug-in. Trust me, that advice is worth a lot.
  • John Hall May 11, 2010
    Good day, Do you mean the evaporator coils? Never saw ice on a condenser.
  • Refrigerators Master
  • 4,655 Answers
Your condenser should be the warm side and the evaporator is the cold side inside freezer. If missing defrost the coil will cover in snow like looks, if low on freon only a few rows would have clear ice and the remaining rows cold sweat. Most likely you have a defrost problem. If you could get me the model number it would be better for me to locate the true problem. Sea Breeze
Posted on Nov 16, 2009
  • 3 more comments
  • John Tripp
    John Tripp Nov 16, 2009
    Here is where to look for a model number below. If you need to get back with me click=> HERE. Thanks Sea Breeze
  • John Tripp
    John Tripp Nov 17, 2009
    Good number. I believe your defrost timer is worn out and moving slowly. Click Here=> WR9X502 and should be under the refrigerator because that is the only place I could find it in the photos, That model number is also new to me. Let me know and please stop by my=> SITE, Sea Breeze
  • John Tripp
    I know I can get your photo but he iphone part I'm not sure about. This this repairman consider the defrost timer? Sea Breeze
  • John Tripp
    When you find the defrost timer I want you to manually turn it slowly until it stops the compressor. During that time the freezer should be in manual defrost. Make sure the ice and frost is melting listen to the inside of freezer for sounds of sizzling and crackling.
  • John Tripp
    Thanks, For stopping by keep me in your address book, Sea Breeze
Model TFH30PRTA NOT KEEPING ICE CREAM FROZEN
Ice cream will get hard when the temperature is closer to - 20 C or -1 F scale. Water becomes Ice at 0 C or 32 F scale.
Ice cream soft means your freezer is not cooling enough.
You were cleaning the coils? Both condenser and evaporator coils? Cleaning coils and then loosing cooling in the fridge is not a good sign or combination. May be there is a freon leak and the seal system is low on freon now.
Call a service tech to check the seal system.
Unfortunately, if it is a leak you may eventually buy a new fridge after spending money on freon fill up, freon system sealant, leak check etc etc... No good news. Sorry
Oct 25, 2017 | GE Profile Performance 29.8 cu. ft....
Water keep running no ice only making 12 to 15 cubes of ice,
dirty condensor coil, condensor fan motor not working, low on freon,taking in new water during the freeze cycle due to float or unlevel machine.
Sep 24, 2011 | Ice-O-Matic ICEU220HA Undercounter Ice...
Freezer does not stay cold.every 2-3 months I have to remove Ice from The coils behind the freezer panel with a hair dryer. Then it will be ok for another 2-3 months.
check to make sure nothing is blocking the air flow inside the freezer compartment. if the airflow is restricted, condensation will form on the coils and slowly ice over. if you do not have a blockage of airflow, the system may be low on freon which will cause icing on the coils. freon leaks are not common and food blocking the airflow is very common. a third cause could be a weak fan motor. If the fan motor is weakening then airflow will be insufficient. fans are easy and inexpensive to replace on most frig's.
Nov 29, 2010 | Frigidaire FRS26KR4A Side by Side...
Freezing of low pressure pipe 24 BTU
A line or coil freezing is a sign of restricted air flow or low on freon. Make sure the fan that circulates the cold air is working and the filter and coil at the filter are clean. A dirty coil can be cleaned with coil cleaner and a water hose. You will need to remove the unit and take it outside. (window units only) You can buy a bottle of coil cleaner at any hardware store. Follow the instructions on the bottle but basically you spray the coil until soaked wait 5 minutes and flush it clean with water from a hose. Repeat if necessary. Try not to get water and cleaner on the controls. Be careful water will be trapped in the unit you may want to tip it toword the back for 10 minutes or so and if possible let it set outside to dry. Reinstall the unit and put a clean filter on it and give it a try. If ice forms again it is low on freon and will require a repairman to fix it. Freon is a restricted item and you have to have a license to buy it. good luck..
Aug 20, 2010 | Daewoo Heating & Cooling
Low on freon ! Unit runs, but ice forms on short length of pressure line and coil does not get cold.
Yes, this is low on freon and the things you are describing are typical symptoms of that,,,
Dehumidifier is Freezing up and not working
http://www.fixya.com/support/r4662033-dehumidifier_freezing_up_not_working
May 24, 2010 | Haier HDN655E Dehumidifier
Ice is forming on coil fins
Either your coil is dirty or filter is dirty. Worst case your low on freon which would make a coil freeze.But freon doesn't evaporate if your low there must be a slow leak.
May 19, 2010 | LG Heat cool Window Air Conditioner
Ice forms on the coils of a white westinghouse dehumidifier
if the filter is clean than it most likely is low on freon with the right tools you could add freon
Jul 06, 2009 | Dehumidifiers
Either side getting cold
Sorry - maybe I did not exactly understand . Anyway the cooling coil is inside the rear of the freezer and cold air for the fridge is blown from that area for cooling. You need to remove the rear freezer cover panel to check the coils for an ice buildup which stops the air flow and cooling.
If you see no ice then you may well be low on freon and most certainly have a leak. Removing the back will give you access to check those coils for a leak also.
To check freon pressures you need to buy a Bullet tap or two which clamp on the high and low side of the compressor and pierce the pipe like a ice maker water tap except the Bullet tap has aconnection for freon test and refilling hose
May 07, 2009 | Refrigerators
Lights, Fan, Compressor all seem to work. Compressor is HOT.
Anytime you have your symptoms, you are so low on freon that there is no perceptable cooling. If you can put your hand on the compressor "high side" (discharge side and also the smaller refrigerant tube exiting the hermetic compressor) while the compressor has been running a few minutes and it is not hot or very warm to the touch, you are low or out of freon. Refrigerators do not normally utilize expansion valves but have capillary tubes at the inlet to the evaporator coil, which would normally eliminate possible trouble. If your refrigerator does have an expansion valve ahead of the evaporator coil, it could be the culprit, if it "sticks" closed, preventing refrigerant from circulating.
Usually when a refrigerant circuit begins to loose freon, you first notice that "frost" may begin to form on the evaporator coil (refrigerator side). Look in at the rear inside panel of the refrigerator to see if there is a layer or buildup of ice / frost on that panel. That is a sure sign that you are low (but not out of freon).
Usually, there is already a freon service valve for adding refrigerant.
If you are mechanically inclined, I could give you more detailed instructions to "charge" your refrigerator. You must have a freon can tap (for the appropriate refrigerant), a refrigerant hose that mates with the "access valve" on the compressor and to the freon can tap / valve.
Jan 02, 2009 | Kenmore 53642 / 53644 Side by Side...
Gold Star window A/C R5207Y3 Evaporator ice buildup
This is njormally an issue with oversizing but this should have manifested itself the 1st time you used it, unless you have relocated the unit. If you have reinstalled it in its original location and if you have cleaned the coils as required, then you have a low freon issue that only a professional should resolve.
Tip: If the ice is building up in 1 small area and not evenly across the complete evaporator coil, then you definitely are low on freon.
Jun 11, 2008 | Heating & Cooling
Refrigerators Logo
62 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
